10 Replies Latest reply on Aug 25, 2017 9:34 AM by badpsymon
    Export single page PDF, with page number for name
    Lisa_811
      Not sure if this is best done in InDesign or Acrobat, I'm starting here.
      I have a 100+ page document. I need each page to be a separate PDF. However, I need the PDFs to be named the page number. My page numbers for this document start with 3781, so the first page needs to be 3781.pdf (not [my document]_1.pdf)
      I'm thinking a script is the best way??
      Lisa
        • 1. Re: Export single page PDF, with page number for name
          TᴀW Adobe Community Professional & MVP
          Hi Lisa,
          What I would do is:
          1. Create the PDF in InDesign
          2. Open in Acrobat, and go to the Extract Pages option, and choose
          extract as separate pages. (Best is to save all these pages in a
          separate folder)
          3. Open Bridge and navigate to the folder and select all the PDFs you've
          just made.
          4. Right click (on a pc) and select Batch Rename from the context menu.
          5. Choose to rename according to sequence number. Next to that there's a
          field where you can type the start number.
          6. Done! (You can click on preview first to see if it's going to work).
          Easier to do than to describe.
          HTH,
          Ariel
          • 2. Re: Export single page PDF, with page number for name
            Lisa_811 Level 1
            Holy cow! I Never thougt of Bridge! It worked, thank you so much!!
            • 3. Re: Export single page PDF, with page number for name
              Welcome. Nice to shake the dust off Bridge occasionally.
              Ariel
              • 4. Re: Export single page PDF, with page number for name
                It can be trivially scripted, nevertheless.
                • 5. Re: Export single page PDF, with page number for name
                  Colin Flashman Adobe Community Professional
                  @ OP
                  OR, could use Scott Zanelli's PEU (Page Exporter Utility) to make single page PDFs directly from indesign (eliminating step 2) and then go to bridge and carry on ariel's suggestion. scott's script can be found at: http://indesignsecrets.com/page-exporter-utility-peu-5-script-updated-for-cs3.php
                  @ Jongware
                  a scripted solution would be AWESOME though!!!
                  • 6. Re: Export single page PDF, with page number for name
                    cdflash wrote: [..]
                    @ Jongware
                    Really, it's trivial. Fill in your Favourite Preset in the first line and your export path in the 2nd, and you're good to go.
                    var pdfPreset = "[Press Quality]";
                    var exportPath = "/c/temp";
                    for (aPage=0; aPage < app.activeDocument.pages.length; aPage++)
                    app.pdfExportPreferences.pageRange = app.activeDocument.pages[aPage].name;
                    app.activeDocument.exportFile (ExportFormat.PDF_TYPE, File(exportPath+"/"+app.activeDocument.pages[aPage].name+".pdf"), false, pdfPreset);
                    • 7. Re: Export single page PDF, with page number for name
                      Lisa_811 Level 1
                      Jongware...this is EXACTLY what I was trying to do! I'm not that good at script writing, so what I tried didn't work. I missed the "pageRange" part, I think. Thank you SO much, I knew it should have been pretty straight forward.
                      Ariel, I'm still thankful to you for bringing up Bridge...there are other tasks we do with renaming documents that this will be very helpful for!
                      • 8. Re: Export single page PDF, with page number for name
                        monettevelasco Level 1
                        Wow. Years later, this thread will help me.
                        Is there a quick and dirty way to rename the files so they are the page range? I want it to go from "j2eic" to "5-15.pdf"
                        Also, is there a way in Bridge during Batch Rename to have it add the first page number to the filename?
                        • 9. Re: Export single page PDF, with page number for name
                          mwolowicz Level 1
                          I have an even more complicated request.  Let me see if I can explain what I need.
                          We create postcards for a client, then print and mail them. Each postcard is double sided (Front and Back), and each post card has a unique number as a code, but all postcards in the file do not have sequential numbers.  Our InDesign files are set up like this:
                          Page        Page Name      Postcard
                          1              A1                      CODETEXT1
                          2              B1                      CODETEXT1
                          3              A2                      CODETEXT2
                          4              B2                      CODETEXT2
                          5              A3                      CODETEXT3
                          6              B3                      CODETEXT3
                          7              A5                      CODETEXT5
                          8              B5                      CODETEXT5
                          9              A7                      CODETEXT7
                          10            B7                      CODETEXT7
                          11              A13                      CODETEXT13
                          12            B13                      CODETEXT13
                          In this example I have one InDesign document, which contains 6 postcards total.  There are 12 actual pages in InDesign (no spreads). Each pair is one post card front and back. Each postcard is given a prefix code like FSRT, which is printed on the back of the postcard and after the code name goes the "page number" as assigned in InDesign.  This is why the pages are labeled with different prefixes for front and back, because you cannot have two page 13s in InDesign, so we have A13 (front) and B13 (back).
                          The goal is to export from InDesign separate PDFs for each postcard, meaning a 2 page PDF, that is labeled with the correct prefix and the correct postcard code number.
                          This means I would end up with these 6 different PDFs:
                          FSRT1.pdf
                          FSRT2.pdf
                          FSRT3.pdf
                          FSRT5.pdf
                          FSRT7.pdf
                          FSRT13.pdf
                          I tried the Page Exporter Utility, but the problem here is that in this example, page 11 and page 12 have technically the same "page number" assigned in InDesign (13), therefore I end up having PDFs with only the backs of each postcard, because the fronts get overwritten once the backs are saved.  Also, I cannot use this to export 2 pages into one single PDF, but rather all pages individually.
                          I tried the Split PDF utility, which is great because I am able to export 2 pages into one PDF.  However, I am stuck having to keep the Original Name of the file, wether it is before or after the file labeling, and I can't use the page numbers to name the files either.
                          There has to be a better way for me to accomplish this, since this example is pretty basic and easy to rename manually,  but we deal with other files that have over 50 postcards (100 pages), not in chronological or sequential number order, and some that have 3 pages each, instead of 2 (Front, Back + Magnet of postcard).
                          So, basically what I need is a scrip that lets me export PDFs from InDesign directly or using the Adobe Acrobat Pro Split Pages Feature, but that lets me choose how many pages to export for each PDF and also use the page number of the first page of the set only to name the file, and let me add a specific prefix without using the file name at all.
                          Wow that's a lot to ask, I guess.
                          If anyone out there can help us, I appreciate it
                          MW
                          PS: I don't know how to write Scripts or make my own and how to add it.
                          • 10. Re: Export single page PDF, with page number for name
                            badpsymon
                            @Jongware: I don't write scripts. Is it as simple as copy/pasting the below into a file and saving it as an .applescript file and copying it to the InDesign script folder? If no, could you please provide a usable file? Thank you.
                            1. var pdfPreset = "[Press Quality]"
                            2. var exportPath = "/c/temp"
                            3. for (aPage=0; aPage < app.activeDocument.pages.length; aPage++)
                            4. app.pdfExportPreferences.pageRange = app.activeDocument.pages[aPage].name;
                            5. app.activeDocument.exportFile (ExportFormat.PDF_TYPE, File(exportPath+"/"+app.activeDocument.pages[aPage].name+".pdf"), false, pdfPreset);
