7 Replies Latest reply on Jan 8, 2012 3:00 PM by welchphoto
    no audio when exporting to tape
    friar_tuck66
      I am attempting to export a SD 4:3 sequence to DVcam tape using a Sony DSR-40 via firewire. After changing the MPE to software only, I'm getting a video signal to tape, but no audio. Sequence and deck are both set to 48k...seems like i must be missing something. Any thoughts?
        • 1. Re: no audio when exporting to tape
          Jim_Simon Level 8
          Audio is normally set to play back on the computer.  Change that in the Playback Settings so it goes out over FireWire.
          • 2. Re: no audio when exporting to tape
            friar_tuck66 Level 1
            I'm not sure where to do that. I had looked at audio output mapping under
            preferences and changed to "map output for: Audio Out" but as soon as i close
            the preferences tab and open it back up, it reverts to the default "Premier Pro
            WDM Sound"...and still plays back on speakers but not on tape deck. What am I
            missing?
            • 3. Re: no audio when exporting to tape
              cvid01 Level 4
              On the program monitor, just below the monitor is an icon (with three circles, just above the camera icon), click on it and then click on "Player settings.." at the bottom. It is there that you choose which audio to use.
              • 4. Re: no audio when exporting to tape
                got it...many thanks for your help!
                • 5. Re: no audio when exporting to tape
                  welchphoto Level 1
                  I have the same problem.
                  I can export the video to my sony HDV DVCAM recorder but no audio.
                  I can import video and audio but no audio on export or directly from the time line.
                  I have set the playback to External Device Audio.
                  When I play the timeline I have audio on my speakers and I have the meter within premiere showing audio.
                  I use a Windows 7 64 bit 12 gigs of memory computer with CS5.
                  I have a matrox RTx2 but for this I am using a premiere NTSC DV sequence.
                  The audio driver is RealTek High Definition Audio
                  Map Output for: Premiere Pro WDM Sound
                  Audio Hardwear>Default Device: Premiere Pro WDM Sound
                  Any Ideas?
                  Dennis
                  • 6. Re: no audio when exporting to tape
                    The playback settings need to be set to "external device audio"...you can get to
                    those settings by going to sequence/settings, then click the playback settings
                    button to open the playback settings dialogue box.   (or as cvid01 mentioned, on
                    the program monitor, just below the monitor is an icon with three  circles just
                    above the camera icon that you can click to open a dialogue box with a "Player
                    settings" option at the bottom.) just under where it says aspect file
                    conversion, there is the option to select desktop audio or external device
                    audio...select external device.
                    After making this change, I was able to export both audio and video to tape, but
                    not without difficulty. It appears to me that export to tape is more of an
                    afterthought with this software. I have yet to be able to make it export to a
                    specific time code...it always slips 10-20 frames...sometimes it just stops
                    before completing the export. Thank goodness we are moving to file based show
                    delivery, since i see no way to deliver a properly formatted broadcast master
                    using this software.
                    • 7. Re: no audio when exporting to tape
                      welchphoto Level 1
                      In my post I have pointed out that I already have the playback to External Device Audio.
                      That was the first thing I checked.
                      Anyone have any other ideas?
                      Dennis
