2 Replies Latest reply on Dec 6, 2011 1:33 PM by ABC9984
    Flex 3 Installation on Lion
    ABC9984
      For whatever reason the installer for Flex 3 -- released in 2009 -- is a PPC application rather than a Universal application. As a result, a product that I purchased just over 2 years ago doesn't work. Is there an alternative way to get this to install that doesn't require a PPC installer? I'm really not interested in an upgrade right now. Flex 3 does what I need it to do.
        • 1. Re: Flex 3 Installation on Lion
          ABC9984 Level 1
          Just for clarification, despite what Adobe says Flex 3 works quite well on Lion -- the installer just won't run. I use it on another computer where it was installed prior to upgrading to Lion.
          • 2. Re: Flex 3 Installation on Lion
            ABC9984 Level 1
            Answered my own question. For those of you with the same challenge, do the following:
            1) Open the Java Preferences App in the "Utilities" folder under "Applications"
            2) Set the 32-bit Java to be the default by dragging it to the top
            3) Mount he Flex 3 installer DMG
            4) Open terminal and type the following commands (exclude the '#'):
            # cd /Volumes/FB3_mac_214193/FB3_Mac_Installer.app/Resources/Java
            # java -classpath ./Execute.zip:./IAClasses.zip:./installscript.zip:. com.zerog.ia.installer.Main
            The installer will run normally with a few visual distortions. When the installation finishes, quit terminal.
