6 Replies Latest reply on Aug 6, 2006 2:07 AM by Newsgroup_User
    CFObject
    Level 7
      Can someone point me to a good place to learn more about accessing a CFC in
      an CFObject and how to pass variables to it. Also how to access the output
      to use on a page.
      Wally Kolcz
      Developer / Support
        • 1. Re: CFObject
          Level 7
          As a general rule of thumb, your first port of call for any question
          regarding CFML usage should be livedocs. And the search button.
          Start here:
          http://livedocs.macromedia.com/coldfusion/7/htmldocs/00000304.htm
          Follow the links on the page.
          Having read that stuff, it should become fairly clear. If not... post
          another question :-)
          Adam
          • 2. Re: CFObject
            Level 7
            Sorry, I had looked at CFObject. I was confused on if you can do dot
            notation to locate the CFC outside of the main directory. I was doing it
            with CFScript and creating an object there, but I am a little lost on the
            LiveDoc examples of how to use it.
            "Adam Cameron" <adam_junk@hotmail.com> wrote in message
            news:19ymzth287zla$.15muli16bwlhx.dlg@40tude.net...
            > Start here:
            > Adam
            • 3. Re: CFObject
              Level 7
              Well the first example at that URL does it, so I should think it's OK (I
              never use <cfobject>, in favour of always using createObject(), myself).
              The computer will not blow up if you get something wrong. So a good thing
              to do is to TRY your supposition, and see if it works. And if it errors,
              usually the error messages are helpful.
              My uninformed but educated (if that's not an oxymoron) opinion is that
              <cfobject> should work exactly like createObject() does, and you'd use the
              same dotted-path in <cfobject> that you would with createObject().
              It would be easiy enough for you to put this to the test, I think..?
              Adam
              • 4. Re: CFObject
                Level 7
                Ok, I cannot figure out how to locate the CFC using the CFObject. I tried
                this:
                <cfobject name="ListProjects" component="sf_main.components.SingleProjects">
                <cfinvoke component="#ListProjects#" method="ListProjects"
                returnvariable="LProjects">
                But apparently that is all wrong. I used the example from the LiveDoc and
                tried to modify it to work:
                <cfobject name="quoteService" component="nasdaq.quote">
                <cfinvoke component="#quoteService#" method="getLastTradePrice"
                symbol="macr" returnVariable="res">
                When I was using the CFScript method:
                <cfscript>Projects=createObject("Component","sf_main.components.SingleProjects");</cfscrip t>
                It found the component just fine, but I cannot figure out how to take the
                info that is supplied by the CFC and display it on the page.
                This CFC method does not need any arguments, but others do and I don't know
                how to pass an argument through this.
                • 5. Re: CFObject
                  Level 7
                  > <cfscript>Projects=createObject("Component","sf_main.components.SingleProjects");</cfscri pt>
                  <cfscript>
                  // create the component, located in mapped dir "CFC", in sub dir "boardfusion"
                  // the init() function inits the CFC & returns the CFC via "return this"
                  i18nUtils=createObject("component","cfc.boardfusion.i18nUtil").init();
                  // pass in current datetime as argument
                  now=i18nUtils.toEpoch(now());
                  // or you can name your arguments
                  now=i18nUtils.toEpoch(thisDate=now());
                  // no args
                  locales=i18nUtils.getLocales();
                  // args from the "form" scope
                  lang=i18nUtils.showLanguage(form.thisLocale);
                  country=i18nUtils.showCountry(form.thisLocale);
                  </cfscript>
                  • 6. Re: CFObject
                    Level 7
                    > this:
                    If you browse directly to the CFC in question, the very first thing it
                    displays is its path.
                    It seems like you've sussed that out given, you can instatiate the CFC with
                    a createObject() call. I do have to wonder why - if you have a working
                    createObject() call - you are even bothering with <cfobject>, to be honest.
                    But anyway...
                    You create an instance of your object:
                    <cfobject name="myObj" component="path.to.the.cfc.file">
                    You call your method:
                    <cfset myResult = myObj.myMethod()>
                    Where "myMethod" is one of your <cffunction> names.
                    You call your method which takes arguments:
                    <cfset myOtherResult = myObj.myOtherMethod(someArgument=somevalue)>
                    Where "someArgument" is one of your method's <cfargument> names.
                    Adam
