2 Replies Latest reply on Dec 7, 2011 6:15 AM by Krishna V
    HTTP GET with authentication does not work in Adobe Indesign javascript
    Krishna V
      Below is that code that am trying to run in Indesign script. The URL http://localhost:4502/content/geometrixx/en/company/news/articles.html directly works in a browser, it gives back the content. But when I try running the below in Indesign, it gives the following result. It does not really give the conent back.
      Indesign script code:
      reply = "";
      conn = new Socket;
      // access Adobe’s home page
      if (conn.open ("localhost:4502")) {
          var request = "GET /content/geometrixx/en/company/news/articles.html HTTP/1.0\n\n" +
                               "Authorization: Basic admin:admin\n";
      conn.write (request); // and read the server’s reply
      reply = conn.read(999999);
      alert(reply);
      conn.close();
      Output in Indesign:
      HTTP/1.1 404 Not Found
      Connection: Close
      Server: Day-Servlet-Engine/4.1.12
      Content-Type: text/html;charset=UTF-8
      Content-Length: 387
      Date: Wed, 07 Dec 2011 03:05:26 GMT
      <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
          <html><head>
          <title>404 Not Found</title>
          </head><body>
          <h1>Not Found</h1>
          <p>The requested URL /content/geometrixx/en/company/news/articles.html was not found on this server.</p>
          <hr>
          <address>ApacheSling/2.2 (Java HotSpot(TM) 64-Bit Server VM 1.6.0_29; Mac OS X 10.7.2 x86_64)</address>
          </body></html>
        • 1. Re: HTTP GET with authentication does not work in Adobe Indesign javascript
          Ten A Adobe Community Professional
          Your code has some problems.
          1. HTTP Request closed 1st line. Server wait and get data while "\n\n" come.
          2. Authorization user name and password string must be encode base64.
          You can read as reference :
          http://en.wikipedia.org/wiki/Basic_access_authentication
          here is a sample request:
          var request = "GET /autharea/index.html HTTP/1.1\n"
                          + "Host: (serverName)\n"
                          + "Content-Type: text/html; charset=UTF-8\n"
                          + "Authorization: Basic "+ encodedData +"\n\n";
          and working code with base64 function
          var authStr = "username:password";
          var encodedData = base64(authStr );
          var reply = "";
          var conn = new Socket;
          if (conn.open ("130.1.6.46:80","UTF-8")) {
              conn.close();
              alert(reply);
          function base64(binaryString) {
              var keyStr = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=";
              var encoded = "";
              var c1, c2, c3;
              var e1, e2, e3, e4;
              var i = 0;
              while(i < binaryString.length) {
                  c1 = binaryString.charCodeAt(i++);
                  c2 = binaryString.charCodeAt(i++);
                  c3 = binaryString.charCodeAt(i++);
                  e1 = c1 >> 2;
                  e2 = ((c1 & 3) << 4) | (c2 >> 4);
                  e3 = ((c2 & 15) << 2) | (c3 >> 6);
                  e4 = c3 & 63;
                  if (isNaN(c2)) {
                      e3 = e4 = 64;
                      } else if (isNaN(c3)) {
                          e4 = 64;
                  encoded = encoded + keyStr.charAt(e1) + keyStr.charAt(e2) +
                      keyStr.charAt(e3) + keyStr.charAt(e4);
              return encoded;
          Ten
          • 2. Re: HTTP GET with authentication does not work in Adobe Indesign javascript
            Krishna V Level 1
            yes, I have figured it out, thank you so much for the help.
