5 Replies Latest reply on Dec 8, 2011 12:27 AM by yajiv_viki
    Please Help...!!  Is this to possible add data to write excel via java script
    yajiv_viki Level 2
      Team:
      Is this possible to write data to Excel using javascript.
      I have created ScriptUI Dialog window. but i can't able to store datas in Excel.
      I can add data column wise in excel( using writeln comment) but I can't able add data to Row wise.
      Please anyone help me to solve this problem...
      Thanks in Advance.
      -yajiv
      Source Window :
      and the outputs wants......
      save the excel name to the Batch ID..
        • 1. Re: Please Help...!!  Is this to possible add data to write excel via java script
          yajiv_viki Level 2
          Hi Everyone!
          Thanks in Advance...
          -yajiv....
          Code :
          var myAllLinks = myDoc.allGraphics;
          var myLink=new Array()
          var mySeen = Object;
              var myLogFile = new File("~/Desktop/Link Files.xls");
              myLogFile.open("w", undefined, undefined)
              myLogFile.writeln("Link Name");
                for ( i = 1; i < myAllLinks.length; i++ )
                      var myLinkName = myAllLinks[i].itemLink.name;
                      var l=myLinkName.length;
                     var T=myLinkName.substring(l-4);
                      if (T==".tif"){
                          myLogFile.writeln(myAllLinks[i].itemLink.name);
          • 2. Re: Please Help...!!  Is this to possible add data to write excel via java script
            csm_phil Level 4
            Hi Yajiv,
            I have modifed your js code, just i make the change for column wise and row wise.
            Please try.
            var arr=[];
            for ( i = 0; i < myAllLinks.length; i++ ){
                 if (T==".tif"){
                      arr.push(myAllLinks[i].itemLink.name);
            //_______ which thing you need just comment another thing.
            // this is row wise adding
            //myLogFile.writeln(arr.join("\t"));
            // this is column wise adding
            myLogFile.writeln(arr.join("\r"));
            thx
            csm_phil
            • 3. Re: Please Help...!!  Is this to possible add data to write excel via java script
              yajiv_viki Level 2
              Hi csm_phil,
              Thank you so much for your reply.
              its works..!!!
              I have use above your code....
              Thanks lot.
              Is this possible to get specific cell value and update that value..?
              For Ex:
              get C11 and update C11.
              -yajiv
              • 4. Re: Please Help...!!  Is this to possible add data to write excel via java script
                csm_phil Level 4
                Hi Yajiv,
                I am not sure to change the value, but we can read the value of the specified column.
                Please try the below js code.
                var arr=[];
                     var T=myLinkName.substring(l-5);
                     if (T==".jpeg"){
                if (myLogFile != null) {
                     myLogFile.open("r") ;
                     var myExcel = myLogFile.read();
                     myLogFile.close();
                     myExcel = myExcel.split("\t");
                //below line alert the first column contents
                alert(myExcel[0]);
                //below line alert the second column contents
                alert(myExcel[1]);
                thx
                csm_phil
