0 Replies Latest reply on Dec 7, 2011 4:55 AM by Josué Mouco
    Unable to deploy the MSI in Windows 7 64-bit
    Josué Mouco Level 1
      Hi there,
      I try to deploy Adobe Reader 10.1.1 in a new Windows 7 Pro SP1 64-bit installation with the following command line: "msiexec /i AcroRead.msi TRANSFORMS=AcroRead.mst /qn /log log.txt" through MDT 2010. I also tried in a command prompt without sucess. Through MDT I get this result: Application Adobe Reader 10.1.1 returned an unexpected return code: 1603.
      Interesting fact: in a Windows 7 Pro SP1 x86, the Adobe Reader 10.1.1 is installed correctly without any error.
      The log file says:
      === Logging started: 07.12.2011  12:59:57 ===
      Action start 12:59:57: INSTALL.
      Action start 12:59:57: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54.
      Action ended 12:59:57: SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54. Return value 1.
      Action start 12:59:57: ISSetupFilesExtract.
      1: Starting to extract setup files
      1: Getting SUPPORTDIR property :
      1: Extracting SetupFiles to:  C:\Users\ADMINI~1\AppData\Local\Temp\{AC76BA86-7AD7-1033-7B44-AA1000000001}
      1: Getting ISSetupFile table view
      1: Executing ISSetupFile table view
      1: Extracting Setup File:
      1: C:\Users\ADMINI~1\AppData\Local\Temp\{AC76BA86-7AD7-1033-7B44-AA1000000001}\FixTransforms .exe
      1: Setting SUPPORTDIR property to:  C:\Users\ADMINI~1\AppData\Local\Temp\{AC76BA86-7AD7-1033-7B44-AA1000000001}
      1: Setting ISSETUPFILESCOMPLETED property
      Action ended 12:59:57: ISSetupFilesExtract. Return value 1.
      Action start 12:59:57: AppSearch.
      Action ended 12:59:57: AppSearch. Return value 1.
      Action start 12:59:57: LaunchConditions.
      Action ended 12:59:57: LaunchConditions. Return value 1.
      Action start 12:59:57: FindRelatedProducts.
      Action ended 12:59:57: FindRelatedProducts. Return value 1.
      Action start 12:59:57: ValidateProductID.
      Action ended 12:59:57: ValidateProductID. Return value 1.
      Action start 12:59:57: setUserProfileNT.
      Action ended 12:59:57: setUserProfileNT. Return value 1.
      Action start 12:59:57: setAllUsersProfile2K.
      Action ended 12:59:57: setAllUsersProfile2K. Return value 1.
      Action start 12:59:57: IsInstallElevated.
      Action ended 12:59:57: IsInstallElevated. Return value 1.
      Action start 12:59:57: FileTypesOwnerInit.
      ADelRCP logging: : PDF ownership: InitCurrentPDFOwner()
      ADelRCP logging: :    Current owner:
      ADelRCP logging: :       The installing/uninstall app path: "\AcroRd32.exe";  version: 10
      ADelRCP logging: :    The installing/uninstalling product is not the current PDF owner
      ADelRCP logging: :    Installing Reader && [IW_DEFAULT_VERB]= "Read": set [DEFAULT_VERB] ="Read"
      Action ended 12:59:57: FileTypesOwnerInit. Return value 1.
      Action start 12:59:57: WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54.
      Action ended 12:59:57: WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54. Return value 1.
      Action start 12:59:57: WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B 287C203A.
      Action ended 12:59:57: WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B 287C203A. Return value 1.
      Action start 12:59:57: CostInitialize.
      Action ended 12:59:57: CostInitialize. Return value 1.
      Action start 12:59:57: ResolveSource.
      Action ended 12:59:57: ResolveSource. Return value 1.
      Action start 12:59:57: SetSourceDirCustom.
      Action ended 12:59:57: SetSourceDirCustom. Return value 1.
      Action start 12:59:57: ProcessAbcpy.
      CustomAction ProcessAbcpy returned actual error code 1603 but will be translated to success due to continue marking
      Action ended 12:59:57: ProcessAbcpy. Return value 1.
      Action start 12:59:57: SetupPluginsProperties.
      Action ended 12:59:57: SetupPluginsProperties. Return value 1.
      Action start 12:59:57: SupressReboot.
      Action ended 12:59:57: SupressReboot. Return value 1.
      Action start 12:59:57: FileCost.
      Action ended 12:59:57: FileCost. Return value 1.
      Action start 12:59:57: IsolateComponents.
      Action ended 12:59:57: IsolateComponents. Return value 0.
      Action start 12:59:57: CostFinalize.
      Action ended 12:59:57: CostFinalize. Return value 1.
      Action start 12:59:57: SetARPInstallLocation.
      Action ended 12:59:57: SetARPInstallLocation. Return value 1.
      Action start 12:59:57: SetARPReadme.
      Action ended 12:59:57: SetARPReadme. Return value 1.
      Action start 12:59:57: SetARPReadmeEx.
      Action ended 12:59:57: SetARPReadmeEx. Return value 1.
      Action start 12:59:57: FileTypesOwnerSet.
      ADelRCP logging: : PDF ownership: SetCurrentPDFOwner()
      ADelRCP logging: :    Current value of [DEFAULT_VERB]=Read
      ADelRCP logging: : system search and save several properties used by registry installation later
      ADelRCP logging: :    [AS_HKCR_EXE]="C:\Program Files\Adobe\Reader 10.0\Reader\AcroRd32.exe"
      ADelRCP logging: :    [PDFSHELL_LOCALSERVER_COMMAND]="C:\Program Files\Adobe\Reader 10.0\Reader\AcroRd32Info.exe" /PDFShell
      ADelRCP logging: :    [PDF_DEFAULTICON]=C:\Windows\Installer\{AC76BA86-7AD7-1033-7B44-AA1000000001}\PDFFile_8.i co,0
      ADelRCP logging: :    [PDF_PREVIEW_HANDERLER_DLL]=C:\Program Files\Adobe\Reader 10.0\Reader\pdfprevhndlr.dll
      ADelRCP logging: :    [PDF_PREVIEW_HANDERLER_HELPDIR]=C:\Program Files\Adobe\Reader 10.0\Reader\
      ADelRCP logging: :    [PDF_INPROCSERVER_VIEWERPS]=C:\Program Files\Adobe\Reader 10.0\Reader\ViewerPS.dll
      Action ended 12:59:57: FileTypesOwnerSet. Return value 1.
      Action start 12:59:57: Set_PROGID7_ALTERNATE_COMMAND_Reader.
      Action ended 12:59:57: Set_PROGID7_ALTERNATE_COMMAND_Reader. Return value 1.
      Action start 12:59:57: SetODBCFolders.
      Action ended 12:59:57: SetODBCFolders. Return value 0.
      Action start 12:59:57: MigrateFeatureStates.
      Action ended 12:59:57: MigrateFeatureStates. Return value 0.
      Action start 12:59:57: ApplicationsInUse.
      ADelRCP logging: : Process privilege adjusted.
      ADelRCP logging: : Condition not met for AppsInUseEx module entry : AcroRd32dll
      Action ended 12:59:57: ApplicationsInUse. Return value 1.
      Action start 12:59:57: InstallValidate.
      Action ended 12:59:57: InstallValidate. Return value 1.
      Action start 12:59:57: CloseApps.
      Action ended 12:59:57: CloseApps. Return value 1.
      Action start 12:59:57: TransferRegistryCollect.
      Action ended 12:59:57: TransferRegistryCollect. Return value 1.
      Action start 12:59:57: RemoveExistingProducts.
      Action ended 12:59:57: RemoveExistingProducts. Return value 1.
      Action start 12:59:57: ExportCacheBinary.
      Action ended 12:59:57: ExportCacheBinary. Return value 1.
      Action start 12:59:57: SetMoveCacheBinary.
      Action ended 12:59:57: SetMoveCacheBinary. Return value 1.
      Action start 12:59:57: CollectPropertiesMNT.
      Action ended 12:59:57: CollectPropertiesMNT. Return value 1.
      Action start 12:59:57: CollectCustomTablesData.
      Action ended 12:59:57: CollectCustomTablesData. Return value 1.
      Action start 12:59:57: CollectProperties.
      Action ended 12:59:57: CollectProperties. Return value 1.
      Action start 12:59:57: InstallInitialize.
      Action ended 12:59:58: InstallInitialize. Return value 1.
      Action start 12:59:58: RegisterProperties_Rollback.
      Action ended 12:59:58: RegisterProperties_Rollback. Return value 1.
      Action start 12:59:58: RegisterProperties.
      Action ended 12:59:58: RegisterProperties. Return value 1.
      Action start 12:59:58: FixRegPermissions.
      Action ended 12:59:58: FixRegPermissions. Return value 1.
      Action start 12:59:58: FixFilePermissions.
      Action ended 12:59:58: FixFilePermissions. Return value 1.
      Action start 12:59:58: BroadcastUnloadStubMessage.
      Action ended 12:59:58: BroadcastUnloadStubMessage. Return value 1.
      Action start 12:59:58: FileTypesOwnerBackup.
      Action ended 12:59:58: FileTypesOwnerBackup. Return value 1.
      Action start 12:59:58: AllocateRegistrySpace.
      Action ended 12:59:58: AllocateRegistrySpace. Return value 1.
      Action start 12:59:58: ProcessComponents.
      Action ended 12:59:58: ProcessComponents. Return value 1.
      Action start 12:59:58: UnpublishComponents.
      Action ended 12:59:58: UnpublishComponents. Return value 0.
      Action start 12:59:58: MsiUnpublishAssemblies.
      Action ended 12:59:58: MsiUnpublishAssemblies. Return value 1.
      Action start 12:59:58: UnpublishFeatures.
      Action ended 12:59:58: UnpublishFeatures. Return value 1.
      Action start 12:59:58: StopServices.
      Action ended 12:59:58: StopServices. Return value 1.
      Action start 12:59:58: DeleteServices.
      Action ended 12:59:58: DeleteServices. Return value 1.
      Action start 12:59:58: UnregisterComPlus.
      Action ended 12:59:58: UnregisterComPlus. Return value 0.
      Action start 12:59:58: SelfUnregModules.
      Action ended 12:59:58: SelfUnregModules. Return value 1.
      Action start 12:59:58: UnregisterTypeLibraries.
      Action ended 12:59:58: UnregisterTypeLibraries. Return value 1.
      Action start 12:59:58: RemoveODBC.
      Action ended 12:59:58: RemoveODBC. Return value 1.
      Action start 12:59:58: UnregisterFonts.
      Action ended 12:59:58: UnregisterFonts. Return value 1.
      Action start 12:59:58: RemoveRegistryValues.
      Action ended 12:59:58: RemoveRegistryValues. Return value 1.
      Action start 12:59:58: UnregisterClassInfo.
      Action ended 12:59:58: UnregisterClassInfo. Return value 1.
      Action start 12:59:58: UnregisterExtensionInfo.
      Action ended 12:59:58: UnregisterExtensionInfo. Return value 1.
      Action start 12:59:58: UnregisterProgIdInfo.
      Action ended 12:59:58: UnregisterProgIdInfo. Return value 1.
      Action start 12:59:58: UnregisterMIMEInfo.
      Action ended 12:59:58: UnregisterMIMEInfo. Return value 1.
      Action start 12:59:58: RemoveIniValues.
      Action ended 12:59:58: RemoveIniValues. Return value 1.
      Action start 12:59:58: RemoveShortcuts.
      Action ended 12:59:58: RemoveShortcuts. Return value 1.
      Action start 12:59:58: RemoveEnvironmentStrings.
      Action ended 12:59:58: RemoveEnvironmentStrings. Return value 1.
      Action start 12:59:58: RemoveDuplicateFiles.
      Action ended 12:59:58: RemoveDuplicateFiles. Return value 1.
      Action start 12:59:58: RemoveFiles.
      Action ended 12:59:58: RemoveFiles. Return value 1.
      Action start 12:59:58: RemoveFolders.
      Action ended 12:59:58: RemoveFolders. Return value 1.
      Action start 12:59:58: SetupNetscapeRegistry.
      CustomAction SetupNetscapeRegistry returned actual error code 1603 but will be translated to success due to continue marking
      Action ended 12:59:58: SetupNetscapeRegistry. Return value 1.
      Action start 12:59:58: CreateFolders.
      Action ended 12:59:58: CreateFolders. Return value 1.
      Action start 12:59:58: MoveFiles.
      Action ended 12:59:59: MoveFiles. Return value 1.
      Action start 12:59:59: InstallFiles.
      Action ended 12:59:59: InstallFiles. Return value 1.
      Action start 12:59:59: PatchFiles.
      Action ended 12:59:59: PatchFiles. Return value 0.
      Action start 12:59:59: DuplicateFiles.
      Action ended 12:59:59: DuplicateFiles. Return value 1.
      Action start 12:59:59: BindImage.
      Action ended 12:59:59: BindImage. Return value 1.
      Action start 12:59:59: CreateShortcuts.
      Action ended 12:59:59: CreateShortcuts. Return value 1.
      Action start 12:59:59: RegisterClassInfo.
      Action ended 12:59:59: RegisterClassInfo. Return value 1.
      Action start 12:59:59: RegisterExtensionInfo.
      Action ended 12:59:59: RegisterExtensionInfo. Return value 1.
      Action start 12:59:59: RegisterProgIdInfo.
      Action ended 12:59:59: RegisterProgIdInfo. Return value 1.
      Action start 12:59:59: RegisterMIMEInfo.
      Action ended 12:59:59: RegisterMIMEInfo. Return value 1.
      Action start 12:59:59: WriteRegistryValues.
      Action ended 12:59:59: WriteRegistryValues. Return value 1.
      Action start 12:59:59: WriteIniValues.
      Action ended 12:59:59: WriteIniValues. Return value 1.
      Action start 12:59:59: WriteEnvironmentStrings.
      Action ended 12:59:59: WriteEnvironmentStrings. Return value 1.
      Action start 12:59:59: RegisterFonts.
      Action ended 12:59:59: RegisterFonts. Return value 1.
      Action start 12:59:59: InstallODBC.
      Action ended 12:59:59: InstallODBC. Return value 0.
      Action start 12:59:59: RegisterTypeLibraries.
      Action ended 12:59:59: RegisterTypeLibraries. Return value 1.
      Action start 12:59:59: RegisterComPlus.
      Action ended 12:59:59: RegisterComPlus. Return value 0.
      Action start 12:59:59: InstallServices.
      Action ended 12:59:59: InstallServices. Return value 1.
      Action start 12:59:59: DefragmentFiles_InitProgress.
      DefragmentFiles_InitProgress: Starting immediate custom action
      DefragmentFiles_InitProgress: Current UILevel is (2)
      DefragmentFiles_InitProgress: MSI property DefragmentFiles: IMM_SUCCESS;C:\Program Files\Adobe\Reader 10.0\;Software\Adobe\Acrobat Reader\;2;Optimizing performance ...;Completed [1]% of process;NOTE: Installation was successful. However, because your hard drive is fragmented, this application may not be able to launch as quickly as possible. To optimize performance, please defragment your hard drive and then repair this application under Add or Remove Programs in the Control Panel.
      ;|rdr|\ace.dll;|rdr|\acrord32.dll;|rdr|\acrord32.exe;|rdr|\agm.dll;|rdr|\bib.dll;|rdr|\coo ltype.dll;|rdr|\plug_ins\accessibility.api;|rdr|\plug_ins\acroform.api;|rdr|\plug_ins\anno ts.api;|rdr|\plug_ins\checkers.api;|rdr|\plug_ins\digsig.api;|rdr|\plug_ins\escript.api;|r dr|\plug_ins\ia32.api;|rdr|\plug_ins\makeaccessible.api;|rdr|\plug_ins\multimedia.api;|rdr |\plug_ins\pddom.api;|rdr|\plug_ins\ppklite.api;|rdr|\plug_ins\ReadOutLoud.api;|rdr|\plug_ ins\reflow.api;|rdr|\plug_ins\saveasrtf.api;|rdr|\plug_ins\search.api;|rdr|\plug_ins\sendm ail.api;|rdr|\plug_ins\spelling.api;|rdr|\plug_ins\updater.api;|rdr|\plug_ins\eBook.api;|r dr|\plug_ins\weblink.api;|rdr|\plug_ins\dva.api;35029023
      DefragmentFiles_InitProgress: Ending immediate custom action
      Action ended 12:59:59: DefragmentFiles_InitProgress. Return value 1.
      Action start 12:59:59: DefragmentFiles.
      Action ended 12:59:59: DefragmentFiles. Return value 1.
      Action start 12:59:59: StartServices.
      Action ended 12:59:59: StartServices. Return value 1.
      Action start 12:59:59: TransferRegistryApply.
      Action ended 12:59:59: TransferRegistryApply. Return value 1.
      Action start 12:59:59: MoveCacheBinary.
      Action ended 12:59:59: MoveCacheBinary. Return value 1.
      Action start 12:59:59: InstallEnterpriseFiles.
      Action ended 12:59:59: InstallEnterpriseFiles. Return value 1.
      Action start 12:59:59: InstallEnterpriseRegistry.
      Action ended 12:59:59: InstallEnterpriseRegistry. Return value 1.
      Action start 12:59:59: LockRegPermissions.
      Action ended 12:59:59: LockRegPermissions. Return value 1.
      Action start 12:59:59: LockFilePermissions.
      Action ended 12:59:59: LockFilePermissions. Return value 1.
      Action start 12:59:59: SelfRegModules.
      Action ended 12:59:59: SelfRegModules. Return value 1.
      Action start 12:59:59: RegisterUser.
      Action ended 12:59:59: RegisterUser. Return value 1.
      Action start 12:59:59: RegisterProduct.
      Action ended 12:59:59: RegisterProduct. Return value 1.
      Action start 12:59:59: PublishComponents.
      Action ended 12:59:59: PublishComponents. Return value 0.
      Action start 12:59:59: MsiPublishAssemblies.
      Action ended 12:59:59: MsiPublishAssemblies. Return value 1.
      Action start 12:59:59: PublishFeatures.
      Action ended 12:59:59: PublishFeatures. Return value 1.
      Action start 12:59:59: PublishProduct.
      Action ended 12:59:59: PublishProduct. Return value 1.
      Action start 12:59:59: CacheSetupFiles_SetSourceList.
      Action ended 12:59:59: CacheSetupFiles_SetSourceList. Return value 1.
      Action start 12:59:59: ProcessDeleteFilesEx.
      Action ended 12:59:59: ProcessDeleteFilesEx. Return value 1.
      Action start 12:59:59: ProcessDeleteRegistryEx.
      Action ended 12:59:59: ProcessDeleteRegistryEx. Return value 1.
      Action start 12:59:59: ProcessDeleteComponentsEx.
      Action ended 12:59:59: ProcessDeleteComponentsEx. Return value 1.
      Action start 12:59:59: ProcessDeleteProductsEx.
      Action ended 12:59:59: ProcessDeleteProductsEx. Return value 1.
      Action start 12:59:59: CreateDDENameRegistry.
      Action ended 12:59:59: CreateDDENameRegistry. Return value 1.
      Action start 12:59:59: BroadcastReloadStubMessage.
      Action ended 12:59:59: BroadcastReloadStubMessage. Return value 1.
      Action start 12:59:59: UnsetIEKillBit.
      Action ended 12:59:59: UnsetIEKillBit. Return value 1.
      Action start 12:59:59: RestartIEUser.
      Action ended 12:59:59: RestartIEUser. Return value 1.
      Action start 12:59:59: InstallFinalize.
      ADelRCP logging: : PDF ownership: BackupCurrentPDFOwner()
      ADelRCP logging: :    Return: can't find current owner. No need to backup.
      DefragmentFiles: Starting deferred custom action
      DefragmentFiles: MSI property CustomActionData: IMM_SUCCESS;C:\Program Files\Adobe\Reader 10.0\;Software\Adobe\Acrobat Reader\;2;Optimizing performance ...;Completed [1]% of process;NOTE: Installation was successful. However, because your hard drive is fragmented, this application may not be able to launch as quickly as possible. To optimize performance, please defragment your hard drive and then repair this application under Add or Remove Programs in the Control Panel.
      DefragmentFiles: Defragmention process was invoked
      DefragmentFiles: Setting up action data and progress bar ...
      DefragmentFiles: DefragResetProgress disabled
      DefragmentFiles: Finished setting up action data and progress bar
      DefragmentFiles: Ending deferred custom action
      ADelRCP logging: :    CreateDDEReg: current value of [DEFAULT_VERB]=Read
      ADelRCP logging: :    CreateDDEReg: DDE server name value = AcroViewR10
      Action ended 13:00:10: InstallFinalize. Return value 1.
      Action start 13:00:10: ISSetupFilesCleanup.
      1: Deleting Support File:  C:\Users\ADMINI~1\AppData\Local\Temp\{AC76BA86-7AD7-1033-7B44-AA1000000001}\FixTransforms .exe
      Action ended 13:00:10: ISSetupFilesCleanup. Return value 1.
      Action start 13:00:10: RegisterReboot.
      Action ended 13:00:10: RegisterReboot. Return value 1.
      Action start 13:00:10: CleanupRunTime.
      Action ended 13:00:10: CleanupRunTime. Return value 1.
      Action start 13:00:10: DoSubLaunches.
      CustomAction DoSubLaunches returned actual error code 1603 but will be translated to success due to continue marking
      Action ended 13:00:10: DoSubLaunches. Return value 1.
      Action ended 13:00:10: INSTALL. Return value 1.
      Property(S): Text = 0
      Property(S): DiskPrompt = [1]
      Property(S): Registration = No
      Property(S): UpgradeCode = {A6EADE66-0000-0000-484E-7E8A45000000}
      Property(S): ROOTDRIVE = C:\
      Property(S): ISSETUPFILESCOMPLETED = Completed
      Property(S): SUPPORTDIR = C:\Users\ADMINI~1\AppData\Local\Temp\{AC76BA86-7AD7-1033-7B44-AA1000000001}
      Property(S): ACTION = INSTALL
      Property(S): UILevel = 2
      Property(S): OriginalDatabase = \\10.41.3.10\DeploymentShare$\Applications\Adobe Reader 10.1.1\AcroRead.msi
      Property(S): DATABASE = C:\Windows\Installer\1621b.msi
      Property(S): COMPANYNAME = EIG
      Property(S): USERNAME = International School of Geneva
      Property(S): MsiRunningElevated = 1
      Property(S): RedirectedDllSupport = 2
      Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
      Property(S): MsiNetAssemblySupport = 2.0.50727.4927
      Property(S): Date = 07.12.2011
      Property(S): VersionNT = 601
      Property(S): LockRegPermissions = CLASSES_ROOT\AcroIEHelper.AcroIEHlprObj@@1@@131097@@CLASSES_ROOT\AcroIEHelper.AcroIEHlprO bj@@22@@983103@@CLASSES_ROOT\AcroIEHelper.AcroIEHlprObj@@26@@131097@@CLASSES_ROOT\AcroIEHe lper.AcroIEHlprObj.1@@1@@131097@@CLASSES_ROOT\AcroIEHelper.AcroIEHlprObj.1@@22@@983103@@CL ASSES_ROOT\AcroIEHelper.AcroIEHlprObj.1@@26@@131097@@CLASSES_ROOT\AcroPDF.FDF@@1@@131097@@ CLASSES_ROOT\AcroPDF.FDF@@22@@983103@@CLASSES_ROOT\AcroPDF.FDF@@26@@131097@@CLASSES_ROOT\A croPDF.FDF.1@@1@@131097@@CLASSES_ROOT\AcroPDF.FDF.1@@22@@983103@@CLASSES_ROOT\AcroPDF.FDF. 1@@26@@131097@@CLASSES_ROOT\AcroPDF.PDF@@1@@131097@@CLASSES_ROOT\AcroPDF.PDF@@22@@983103@@ CLASSES_ROOT\AcroPDF.PDF@@26@@131097@@CLASSES_ROOT\AcroPDF.PDF.1@@1@@131097@@CLASSES_ROOT\ AcroPDF.PDF.1@@22@@983103@@CLASSES_ROOT\AcroPDF.PDF.1@@26@@131097@@CLASSES_ROOT\AppID\Acro PDF.DLL@@1@@131097@@CLASSES_ROOT\AppID\AcroPDF.DLL@@22@@983103@@CLASSES_ROOT\AppID\AcroPDF .DLL@@26@@131097@@CLASSES_ROOT\AppID\{BBAA0E44-3862-490C-8E63-AC2D2D6EF733}@@1@@131097@@CL ASSES_ROOT\AppID\{BBAA0E44-3862-490C-8E63-AC2D2D6EF733}@@22@@983103@@CLASSES_ROOT\AppID\{B BAA0E44-3862-490C-8E63-AC2D2D6EF733}@@26@@131097@@CLASSES_ROOT\CLSID\{06849E9F-C8D7-4D59-B 87D-784B7D6BE0B3}@@1@@131097@@CLASSES_ROOT\CLSID\{06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}@@2 2@@983103@@CLASSES_ROOT\CLSID\{06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}@@26@@131097@@CLASSES_ ROOT\CLSID\{5BB2200E-5672-4A32-902A-5A98DB1C58DC}@@1@@131097@@CLASSES_ROOT\CLSID\{5BB2200E -5672-4A32-902A-5A98DB1C58DC}@@22@@983103@@CLASSES_ROOT\CLSID\{5BB2200E-5672-4A32-902A-5A9 8DB1C58DC}@@26@@131097@@CLASSES_ROOT\CLSID\{CA8A9780-280D-11CF-A24D-444553540000}@@1@@1310 97@@CLASSES_ROOT\CLSID\{CA8A9780-280D-11CF-A24D-444553540000}@@22@@983103@@CLASSES_ROOT\CL SID\{CA8A9780-280D-11CF-A24D-444553540000}@@26@@131097@@CLASSES_ROOT\CLSID\{EE5A151A-AD2A- 4CEE-AD65-228B59F5B4AD}@@1@@131097@@CLASSES_ROOT\CLSID\{EE5A151A-AD2A-4CEE-AD65-228B59F5B4 AD}@@22@@983103@@CLASSES_ROOT\CLSID\{EE5A151A-AD2A-4CEE-AD65-228B59F5B4AD}@@26@@131097@@CL ASSES_ROOT\Interface\{3B813CE7-7C10-4F84-AD06-9DF76D97A9AA}@@1@@131097@@CLASSES_ROOT\Inter face\{3B813CE7-7C10-4F84-AD06-9DF76D97A9AA}@@22@@983103@@CLASSES_ROOT\Interface\{3B813CE7- 7C10-4F84-AD06-9DF76D97A9AA}@@26@@131097@@CLASSES_ROOT\Interface\{6E67BCC1-D776-44BB-9DC8- C09F542C3CB6}@@1@@131097@@CLASSES_ROOT\Interface\{6E67BCC1-D776-44BB-9DC8-C09F542C3CB6}@@2 2@@983103@@CLASSES_ROOT\Interface\{6E67BCC1-D776-44BB-9DC8-C09F542C3CB6}@@26@@131097@@CLAS SES_ROOT\Interface\{E790E1D1-9DE8-4853-8AC6-933D4FD9C927}@@1@@131097@@CLASSES_ROOT\Interfa ce\{E790E1D1-9DE8-4853-8AC6-933D4FD9C927}@@22@@983103@@CLASSES_ROOT\Interface\{E790E1D1-9D E8-4853-8AC6-933D4FD9C927}@@26@@131097@@CLASSES_ROOT\Interface\{EE5A151A-AD2A-4CEE-AD65-22 8B59F5B4AD}@@1@@131097@@CLASSES_ROOT\Interface\{EE5A151A-AD2A-4CEE-AD65-228B59F5B4AD}@@22@ @983103@@CLASSES_ROOT\Interface\{EE5A151A-AD2A-4CEE-AD65-228B59F5B4AD}@@26@@131097@@CLASSE S_ROOT\TypeLib\{05BFD3F1-6319-4F30-B752-C7A22889BCC4}@@1@@131097@@CLASSES_ROOT\TypeLib\{05 BFD3F1-6319-4F30-B752-C7A22889BCC4}@@22@@983103@@CLASSES_ROOT\TypeLib\{05BFD3F1-6319-4F30- B752-C7A22889BCC4}@@26@@131097@@CLASSES_ROOT\TypeLib\{5F226421-415D-408D-9A09-0DCD94E25B48 }@@1@@131097@@CLASSES_ROOT\TypeLib\{5F226421-415D-408D-9A09-0DCD94E25B48}@@22@@983103@@CLA SSES_ROOT\TypeLib\{5F226421-415D-408D-9A09-0DCD94E25B48}@@26@@131097
      Property(S): DefragmentFiles = IMM_SUCCESS;C:\Program Files\Adobe\Reader 10.0\;Software\Adobe\Acrobat Reader\;2;Optimizing performance ...;Completed [1]% of process;NOTE: Installation was successful. However, because your hard drive is fragmented, this application may not be able to launch as quickly as possible. To optimize performance, please defragment your hard drive and then repair this application under Add or Remove Programs in the Control Panel.
      Property(S): MoveCacheBinary = C:\Users\ADMINI~1\AppData\Local\Temp\;C:\Program Files\Adobe\Reader 10.0\Setup Files\{AC76BA86-7AD7-1033-7B44-AA1000000001}\
      Property(S): FileTypesOwnerRestore = AcroExch.FDFDoc@@0@@PDF@@AcroExch.XFDFDoc@@0@@PDF@@AcroExch.XDPDoc@@0@@PDF@@AcroExch.SecS tore@@0@@PDF@@AcroExch.Document.7@@0@@PDF@@AcroExch.Document@@0@@PDF@@.pdf@@0@@PDF@@.secst ore@@0@@PDF@@AFormAut.App@@0@@PDF@@AcroAccess.AcrobatAccess@@0@@PDF@@AcroExch.Profile@@0@@ PDF@@AcroExch.RMFFile@@0@@PDF@@AcroIEHelper.AcroIEHlprObj@@0@@PDF@@AcroPDF.PDF@@0@@PDF@@Ap pID\AcroPDF.DLL@@0@@PDF@@AppID\PDFPrevHndlr.DLL@@0@@PDF@@AppID\{6236FF8C-E747-4173-86D3-99 F511B61DF3}@@0@@PDF@@AppID\{BBAA0E44-3862-490C-8E63-AC2D2D6EF733}@@0@@PDF@@CLSID\{06849E9F -C8D7-4D59-B87D-784B7D6BE0B3}@@0@@PDF@@CLSID\{12BA069D-0FC6-4577-97C6-5DF634CE6E84}@@0@@PD F@@CLSID\{17F2E344-8227-4AA7-A25A-E89424566BBA}@@0@@PDF@@CLSID\{49400A7C-81A8-4F52-8CCE-D5 4739EE87EC}@@0@@PDF@@CLSID\{5BB2200E-5672-4A32-902A-5A98DB1C58DC}@@0@@PDF@@CLSID\{7CD069A1 -50AA-11D1-B8F0-00A0C9259304}@@0@@PDF@@CLSID\{98D9A6F1-4696-4B5E-A2E8-36B3F9C1E12C}@@0@@PD F@@CLSID\{B801CA65-A1FC-11D0-85AD-444553540000}@@0@@PDF@@CLSID\{BD57A9B2-4E7D-4892-9107-9F 4106472DA4}@@0@@PDF@@CLSID\{C523F39F-9C83-11D3-9094-00104BD0D535}@@0@@PDF@@CLSID\{CA8A9780 -280D-11CF-A24D-444553540000}@@0@@PDF@@CLSID\{D38406DA-E8AA-484b-B80D-3D3DBDCC2FB2}@@0@@PD F@@CLSID\{DC6EFB56-9CFA-464D-8880-44885D7DC193}@@0@@PDF@@CLSID\{DF9A1DA0-23C0-101B-B02E-FD FDFDFDFDFD}\AutoTreatAs@@0@@PDF@@CLSID\{DF9A1DA0-23C0-101B-B02E-FDFDFDFDFDFD}\TreatAs@@0@@ PDF@@CLSID\{EE5A151A-AD2A-4CEE-AD65-228B59F5B4AD}@@0@@PDF@@Interface\{17F2E344-8227-4AA7-A 25A-E89424566BBA}@@0@@PDF@@Interface\{36DE898D-AD48-40A5-B4B2-123F916BFBAB}@@0@@PDF@@Inter face\{3B813CE7-7C10-4F84-AD06-9DF76D97A9AA}@@0@@PDF@@Interface\{4A894040-247E-4AFF-BB08-34 89E9905235}@@0@@PDF@@Interface\{5007373A-20D7-458F-9FFB-ABC900E3A831}@@0@@PDF@@Interface\{ 618736E0-3C3D-11CF-810C-00AA00389B71}@@0@@PDF@@Interface\{673E8452-7646-11D1-B90B-00A0C925 9304}@@0@@PDF@@Interface\{7CD069A0-50AA-11D1-B8F0-00A0C9259304}@@0@@PDF@@Interface\{81F9B4 4F-BA3A-4F5D-9B51-090C74A9B3A4}@@0@@PDF@@Interface\{8D46C1B6-BBAB-450D-A61F-4DDC898B21D4}@ @0@@PDF@@Interface\{9B4CD3E6-4981-101B-9CA8-9240CE2738AE}@@0@@PDF@@Interface\{E790E1D1-9DE 8-4853-8AC6-933D4FD9C927}@@0@@PDF@@Interface\{EE5A151A-AD2A-4CEE-AD65-228B59F5B4AD}@@0@@PD F@@Interface\{F9F2FE81-F764-4BD0-AFA5-5DE841DDB625}@@0@@PDF@@MIME\Database\Content Type\application/pdf@@0@@PDF@@MIME\Database\Content Type\application/vnd.adobe.xdp+xml@@0@@PDF@@MIME\Database\Content Type\application/vnd.adobe.xfd+xml@@0@@PDF@@MIME\Database\Content Type\application/vnd.adobe.xfdf@@0@@PDF@@MIME\Database\Content Type\application/vnd.fdf@@0@@PDF@@PDFPrevHndlr.PDFPreviewHandler@@0@@PDF@@PDFPrevHndlr.PD FPreviewHandler.1@@0@@PDF@@SOFTWARE\Classes\AcroBroker.Broker@@2@@PDF@@SOFTWARE\Classes\Ac roBroker.Broker.1\CLSID@@2@@PDF@@SOFTWARE\Classes\AcroBroker.Broker1@@2@@PDF@@SOFTWARE\Cla sses\AcroBroker.Broker\CLSID@@2@@PDF@@SOFTWARE\Classes\AcroBroker.Broker\CurVer@@2@@PDF@@S OFTWARE\Classes\AppID\AcroBroker.EXE@@2@@PDF@@SOFTWARE\Classes\AppID\{F2383816-917A-46CC-A D2A-5013BED3800F}@@2@@PDF@@SOFTWARE\Classes\Interface\{D3F22039-E3CF-4FC4-9A30-426A46056B8 C}@@2@@PDF@@SOFTWARE\Classes\TypeLib\{41738EEA-442F-477F-92CF-2889BD6CD7E7}@@2@@PDF@@SOFTW ARE\Classes\TypeLib\{41738EEA-442F-477F-92CF-2889BD6CD7E7}\1.0@@2@@PDF@@SOFTWARE\Classes\T ypeLib\{41738EEA-442F-477F-92CF-2889BD6CD7E7}\1.0\0@@2@@PDF@@SOFTWARE\Classes\TypeLib\{417 38EEA-442F-477F-92CF-2889BD6CD7E7}\1.0\0\win32@@2@@PDF@@SOFTWARE\Classes\TypeLib\{41738EEA -442F-477F-92CF-2889BD6CD7E7}\1.0\FLAGS@@2@@PDF@@SOFTWARE\Classes\TypeLib\{41738EEA-442F-4 77F-92CF-2889BD6CD7E7}\1.0\HELPDIR@@2@@PDF@@TypeLib\{0F6D3808-7974-4B1A-94C2-3200767EACE8} @@0@@PDF@@TypeLib\{41C5FFFE-36DD-415D-9ED0-2976A342A1C8}@@0@@PDF@@TypeLib\{E64169B3-3592-4 7d2-816E-602C5C13F328}@@0@@PDF
      Property(S): ProcessDeleteFilesEx = Leame.htm@@INSTALLDIR@@drvDX8.x3d@@C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins3d\
      Property(S): RegisterProperties = CACHE_DIR@@C:\Program Files\Adobe\Reader 10.0\Setup Files\{AC76BA86-7AD7-1033-7B44-AA1000000001}\@@ProductName@@Adobe Reader X (10.1.1)@@OriginalDatabase@@\\10.41.3.10\DeploymentShare$\Applications\Adobe Reader 10.1.1\AcroRead.msi@@REMOVE@@@@WindowsFolder@@C:\Windows\@@SetupCacheExport@@Enterprise.m nt@@ALLUSERS@@1@@REINSTALLMODE@@omus@@PLUG_INS@@C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\@@DefragResetProgress@@No@@ALLUSERS_APPDATA_ADOBE@@C:\ProgramData\Ad obe\@@DEFAULT_VERB@@Read@@IS_CURRENT_PDFOWNER@@@@ACTIVE_X@@C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\@@Installed@@@@READER@@C:\Program Files\Adobe\Reader 10.0\Reader\@@ProductCode@@{AC76BA86-7AD7-1033-7B44-AA1000000001}@@INSTALLDIR@@C:\Program Files\Adobe\Reader 10.0\@@DeleteUpdateFolder@@Yes
      Property(S): FileTypesOwnerBackup = AcroExch.FDFDoc@@0@@PDF@@AcroExch.XFDFDoc@@0@@PDF@@AcroExch.XDPDoc@@0@@PDF@@AcroExch.SecS tore@@0@@PDF@@AcroExch.Document.7@@0@@PDF@@AcroExch.Document@@0@@PDF@@.pdf@@0@@PDF@@.secst ore@@0@@PDF@@AFormAut.App@@0@@PDF@@AcroAccess.AcrobatAccess@@0@@PDF@@AcroExch.Profile@@0@@ PDF@@AcroExch.RMFFile@@0@@PDF@@AcroIEHelper.AcroIEHlprObj@@0@@PDF@@AcroPDF.PDF@@0@@PDF@@Ap pID\AcroPDF.DLL@@0@@PDF@@AppID\PDFPrevHndlr.DLL@@0@@PDF@@AppID\{6236FF8C-E747-4173-86D3-99 F511B61DF3}@@0@@PDF@@AppID\{BBAA0E44-3862-490C-8E63-AC2D2D6EF733}@@0@@PDF@@CLSID\{06849E9F -C8D7-4D59-B87D-784B7D6BE0B3}@@0@@PDF@@CLSID\{12BA069D-0FC6-4577-97C6-5DF634CE6E84}@@0@@PD F@@CLSID\{17F2E344-8227-4AA7-A25A-E89424566BBA}@@0@@PDF@@CLSID\{49400A7C-81A8-4F52-8CCE-D5 4739EE87EC}@@0@@PDF@@CLSID\{5BB2200E-5672-4A32-902A-5A98DB1C58DC}@@0@@PDF@@CLSID\{7CD069A1 -50AA-11D1-B8F0-00A0C9259304}@@0@@PDF@@CLSID\{98D9A6F1-4696-4B5E-A2E8-36B3F9C1E12C}@@0@@PD F@@CLSID\{B801CA65-A1FC-11D0-85AD-444553540000}@@0@@PDF@@CLSID\{BD57A9B2-4E7D-4892-9107-9F 4106472DA4}@@0@@PDF@@CLSID\{C523F39F-9C83-11D3-9094-00104BD0D535}@@0@@PDF@@CLSID\{CA8A9780 -280D-11CF-A24D-444553540000}@@0@@PDF@@CLSID\{D38406DA-E8AA-484b-B80D-3D3DBDCC2FB2}@@0@@PD F@@CLSID\{DC6EFB56-9CFA-464D-8880-44885D7DC193}@@0@@PDF@@CLSID\{DF9A1DA0-23C0-101B-B02E-FD FDFDFDFDFD}\AutoTreatAs@@0@@PDF@@CLSID\{DF9A1DA0-23C0-101B-B02E-FDFDFDFDFDFD}\TreatAs@@0@@ PDF@@CLSID\{EE5A151A-AD2A-4CEE-AD65-228B59F5B4AD}@@0@@PDF@@Interface\{17F2E344-8227-4AA7-A 25A-E89424566BBA}@@0@@PDF@@Interface\{36DE898D-AD48-40A5-B4B2-123F916BFBAB}@@0@@PDF@@Inter face\{3B813CE7-7C10-4F84-AD06-9DF76D97A9AA}@@0@@PDF@@Interface\{4A894040-247E-4AFF-BB08-34 89E9905235}@@0@@PDF@@Interface\{5007373A-20D7-458F-9FFB-ABC900E3A831}@@0@@PDF@@Interface\{ 618736E0-3C3D-11CF-810C-00AA00389B71}@@0@@PDF@@Interface\{673E8452-7646-11D1-B90B-00A0C925 9304}@@0@@PDF@@Interface\{7CD069A0-50AA-11D1-B8F0-00A0C9259304}@@0@@PDF@@Interface\{81F9B4 4F-BA3A-4F5D-9B51-090C74A9B3A4}@@0@@PDF@@Interface\{8D46C1B6-BBAB-450D-A61F-4DDC898B21D4}@ @0@@PDF@@Interface\{9B4CD3E6-4981-101B-9CA8-9240CE2738AE}@@0@@PDF@@Interface\{E790E1D1-9DE 8-4853-8AC6-933D4FD9C927}@@0@@PDF@@Interface\{EE5A151A-AD2A-4CEE-AD65-228B59F5B4AD}@@0@@PD F@@Interface\{F9F2FE81-F764-4BD0-AFA5-5DE841DDB625}@@0@@PDF@@MIME\Database\Content Type\application/pdf@@0@@PDF@@MIME\Database\Content Type\application/vnd.adobe.xdp+xml@@0@@PDF@@MIME\Database\Content Type\application/vnd.adobe.xfd+xml@@0@@PDF@@MIME\Database\Content Type\application/vnd.adobe.xfdf@@0@@PDF@@MIME\Database\Content Type\application/vnd.fdf@@0@@PDF@@PDFPrevHndlr.PDFPreviewHandler@@0@@PDF@@PDFPrevHndlr.PD FPreviewHandler.1@@0@@PDF@@SOFTWARE\Classes\AcroBroker.Broker@@2@@PDF@@SOFTWARE\Classes\Ac roBroker.Broker.1\CLSID@@2@@PDF@@SOFTWARE\Classes\AcroBroker.Broker1@@2@@PDF@@SOFTWARE\Cla sses\AcroBroker.Broker\CLSID@@2@@PDF@@SOFTWARE\Classes\AcroBroker.Broker\CurVer@@2@@PDF@@S OFTWARE\Classes\AppID\AcroBroker.EXE@@2@@PDF@@SOFTWARE\Classes\AppID\{F2383816-917A-46CC-A D2A-5013BED3800F}@@2@@PDF@@SOFTWARE\Classes\Interface\{D3F22039-E3CF-4FC4-9A30-426A46056B8 C}@@2@@PDF@@SOFTWARE\Classes\TypeLib\{41738EEA-442F-477F-92CF-2889BD6CD7E7}@@2@@PDF@@SOFTW ARE\Classes\TypeLib\{41738EEA-442F-477F-92CF-2889BD6CD7E7}\1.0@@2@@PDF@@SOFTWARE\Classes\T ypeLib\{41738EEA-442F-477F-92CF-2889BD6CD7E7}\1.0\0@@2@@PDF@@SOFTWARE\Classes\TypeLib\{417 38EEA-442F-477F-92CF-2889BD6CD7E7}\1.0\0\win32@@2@@PDF@@SOFTWARE\Classes\TypeLib\{41738EEA -442F-477F-92CF-2889BD6CD7E7}\1.0\FLAGS@@2@@PDF@@SOFTWARE\Classes\TypeLib\{41738EEA-442F-4 77F-92CF-2889BD6CD7E7}\1.0\HELPDIR@@2@@PDF@@TypeLib\{0F6D3808-7974-4B1A-94C2-3200767EACE8} @@0@@PDF@@TypeLib\{41C5FFFE-36DD-415D-9ED0-2976A342A1C8}@@0@@PDF@@TypeLib\{E64169B3-3592-4 7d2-816E-602C5C13F328}@@0@@PDF
      Property(S): LockFilePermissions = C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\@@1@@1179817@@C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\@@22@@2032127@@C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\@@26@@1179817@@C:\Program Files\Adobe\Reader 10.0\Resource\CMap\@@1@@1179817@@C:\Program Files\Adobe\Reader 10.0\Resource\CMap\@@22@@2032127@@C:\Program Files\Adobe\Reader 10.0\Resource\CMap\@@26@@1179817@@C:\Program Files\Adobe\Reader 10.0\Reader\Adobe.Reader.Dependencies.manifest@@1@@1179817@@C:\Program Files\Adobe\Reader 10.0\Reader\Adobe.Reader.Dependencies.manifest@@22@@2032127@@C:\Program Files\Adobe\Reader 10.0\Reader\Adobe.Reader.Dependencies.manifest@@26@@2032127
      Property(S): ADOBE_COMMON_ACROBAT = C:\Program Files\Common Files\Adobe\Acrobat\
      Property(S): ACTIVE_X = C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\
      Property(S): ProgramFilesFolder = C:\Program Files\
      Property(S): ADOBE = C:\Program Files\Adobe\
      Property(S): CommonFilesFolder = C:\Program Files\Common Files\
      Property(S): ADOBE_COMMON = C:\Program Files\Common Files\Adobe\
      Property(S): AIR = C:\Program Files\Adobe\Reader 10.0\Reader\AIR\
      Property(S): READER = C:\Program Files\Adobe\Reader 10.0\Reader\
      Property(S): TARGETDIR = C:\
      Property(S): ALLUSERSPROFILE = C:\ProgramData\
      Property(S): CommonAppDataFolder = C:\ProgramData\
      Property(S): ALLUSERS_APPDATA_ADOBE = C:\ProgramData\Adobe\
      Property(S): ALLUSERS_APPDATA_ADOBE_ACROBAT = C:\ProgramData\Adobe\Acrobat\
      Property(S): ALLUSERS_APPDATA_ADOBE_ACROBAT_9 = C:\ProgramData\Adobe\Acrobat\10.0\
      Property(S): ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE = C:\ProgramData\Adobe\Acrobat\10.0\Replicate\
      Property(S): ALLUSERS_APPDATA_ADOBE_ACROBAT_9_REPLICATE_SECURITY = C:\ProgramData\Adobe\Acrobat\10.0\Replicate\Security\
      Property(S): PLUG_INS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\
      Property(S): ANNOTATIONS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\
      Property(S): ARM = C:\Program Files\Common Files\Adobe\ARM\
      Property(S): ARM_1.0 = C:\Program Files\Common Files\Adobe\ARM\1.0\
      Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
      Property(S): AppDataFolder = C:\Users\Administrator\AppData\Roaming\
      Property(S): BROWSER = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): BROWSER_IE = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): CACHE_SETUP_FILES = C:\Program Files\Adobe\Reader 10.0\Setup Files\
      Property(S): CACHE_DIR = C:\Program Files\Adobe\Reader 10.0\Setup Files\{AC76BA86-7AD7-1033-7B44-AA1000000001}\
      Property(S): INSTALLDIR = C:\Program Files\Adobe\Reader 10.0\
      Property(S): RESOURCE = C:\Program Files\Adobe\Reader 10.0\Resource\
      Property(S): CIDFONT = C:\Program Files\Adobe\Reader 10.0\Resource\CIDFont\
      Property(S): CMAP = C:\Program Files\Adobe\Reader 10.0\Resource\CMap\
      Property(S): COMMON_ADOBE_HELP = C:\Program Files\Common Files\Adobe\HelpCfg\
      Property(S): COMMON_ADOBE_HELP_CAT = C:\Program Files\Common Files\Adobe\HelpCfg\ca_ES\
      Property(S): COMMON_ADOBE_HELP_CHS = C:\Program Files\Common Files\Adobe\HelpCfg\zh_CN\
      Property(S): COMMON_ADOBE_HELP_CHT = C:\Program Files\Common Files\Adobe\HelpCfg\zh_TW\
      Property(S): COMMON_ADOBE_HELP_CZE = C:\Program Files\Common Files\Adobe\HelpCfg\cs_CZ\
      Property(S): COMMON_ADOBE_HELP_DAN = C:\Program Files\Common Files\Adobe\HelpCfg\da_DK\
      Property(S): COMMON_ADOBE_HELP_DEU = C:\Program Files\Common Files\Adobe\HelpCfg\de_DE\
      Property(S): COMMON_ADOBE_HELP_ENU = C:\Program Files\Common Files\Adobe\HelpCfg\en_US\
      Property(S): COMMON_ADOBE_HELP_ESP = C:\Program Files\Common Files\Adobe\HelpCfg\es_ES\
      Property(S): COMMON_ADOBE_HELP_EUQ = C:\Program Files\Common Files\Adobe\HelpCfg\eu_ES\
      Property(S): COMMON_ADOBE_HELP_FRA = C:\Program Files\Common Files\Adobe\HelpCfg\fr_FR\
      Property(S): COMMON_ADOBE_HELP_HRV = C:\Program Files\Common Files\Adobe\HelpCfg\hr_HR\
      Property(S): COMMON_ADOBE_HELP_HUN = C:\Program Files\Common Files\Adobe\HelpCfg\hu_HU\
      Property(S): COMMON_ADOBE_HELP_ITA = C:\Program Files\Common Files\Adobe\HelpCfg\it_IT\
      Property(S): COMMON_ADOBE_HELP_JPN = C:\Program Files\Common Files\Adobe\HelpCfg\ja_JP\
      Property(S): COMMON_ADOBE_HELP_KOR = C:\Program Files\Common Files\Adobe\HelpCfg\ko_KR\
      Property(S): COMMON_ADOBE_HELP_NLD = C:\Program Files\Common Files\Adobe\HelpCfg\nl_NL\
      Property(S): COMMON_ADOBE_HELP_NOR = C:\Program Files\Common Files\Adobe\HelpCfg\nb_NO\
      Property(S): COMMON_ADOBE_HELP_POL = C:\Program Files\Common Files\Adobe\HelpCfg\pl_PL\
      Property(S): COMMON_ADOBE_HELP_PTB = C:\Program Files\Common Files\Adobe\HelpCfg\pt_BR\
      Property(S): COMMON_ADOBE_HELP_RUM = C:\Program Files\Common Files\Adobe\HelpCfg\ro_RO\
      Property(S): COMMON_ADOBE_HELP_RUS = C:\Program Files\Common Files\Adobe\HelpCfg\ru_RU\
      Property(S): COMMON_ADOBE_HELP_SKY = C:\Program Files\Common Files\Adobe\HelpCfg\sk_SK\
      Property(S): COMMON_ADOBE_HELP_SLV = C:\Program Files\Common Files\Adobe\HelpCfg\sl_SI\
      Property(S): COMMON_ADOBE_HELP_SUO = C:\Program Files\Common Files\Adobe\HelpCfg\fi_FI\
      Property(S): COMMON_ADOBE_HELP_SVE = C:\Program Files\Common Files\Adobe\HelpCfg\sv_SE\
      Property(S): COMMON_ADOBE_HELP_TUR = C:\Program Files\Common Files\Adobe\HelpCfg\tr_TR\
      Property(S): COMMON_ADOBE_HELP_UKR = C:\Program Files\Common Files\Adobe\HelpCfg\uk_UA\
      Property(S): COMMON_LINGUISTIC = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\
      Property(S): COMMON_ADOBE_PROVIDERS = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\
      Property(S): COMMON_ADOBE_PROVIDERS_PROXIMITY = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\
      Property(S): COMMON_ADOBE_PROVIDERS_PROXIMITY_1100 = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\11.00\
      Property(S): COMMON_ADOBE_PROVIDERS_PROXIMITY_1100_NCL3S4PNTX = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\Providers\Proximity\11.00\NC-L3S4PNTX\
      Property(S): COMMON_LINGUISTIC_LANGUAGENAMES = C:\Program Files\Adobe\Reader 10.0\Resource\Linguistics\LanguageNames2\
      Property(S): CommonFiles64Folder = C:\
      Property(S): DOCSETTINGS = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\
      Property(S): DOCSETTINGS_PORTFOLIO = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\
      Property(S): DOCSETTINGS_PORTFOLIO_CHS = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CHS\
      Property(S): DOCSETTINGS_PORTFOLIO_CHT = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CHT\
      Property(S): DOCSETTINGS_PORTFOLIO_CZE = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\CZE\
      Property(S): DOCSETTINGS_PORTFOLIO_DAN = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\DAN\
      Property(S): DOCSETTINGS_PORTFOLIO_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\DEU\
      Property(S): DOCSETTINGS_PORTFOLIO_ENU = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ENU\
      Property(S): DOCSETTINGS_PORTFOLIO_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ESP\
      Property(S): DOCSETTINGS_PORTFOLIO_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\FRA\
      Property(S): DOCSETTINGS_PORTFOLIO_HRV = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\HRV\
      Property(S): DOCSETTINGS_PORTFOLIO_HUN = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\HUN\
      Property(S): DOCSETTINGS_PORTFOLIO_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\ITA\
      Property(S): DOCSETTINGS_PORTFOLIO_JPN = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\JPN\
      Property(S): DOCSETTINGS_PORTFOLIO_KOR = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\KOR\
      Property(S): DOCSETTINGS_PORTFOLIO_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\NLD\
      Property(S): DOCSETTINGS_PORTFOLIO_NOR = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\NOR\
      Property(S): DOCSETTINGS_PORTFOLIO_POL = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\POL\
      Property(S): DOCSETTINGS_PORTFOLIO_PTB = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\PTB\
      Property(S): DOCSETTINGS_PORTFOLIO_RUM = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\RUM\
      Property(S): DOCSETTINGS_PORTFOLIO_RUS = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\RUS\
      Property(S): DOCSETTINGS_PORTFOLIO_SKY = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SKY\
      Property(S): DOCSETTINGS_PORTFOLIO_SLV = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SLV\
      Property(S): DOCSETTINGS_PORTFOLIO_SUO = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SUO\
      Property(S): DOCSETTINGS_PORTFOLIO_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\SVE\
      Property(S): DOCSETTINGS_PORTFOLIO_TUR = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\TUR\
      Property(S): DOCSETTINGS_PORTFOLIO_UKR = C:\Program Files\Adobe\Reader 10.0\Reader\DocSettings\Portfolio\UKR\
      Property(S): DesktopFolder = C:\Users\Public\Desktop\
      Property(S): ESL_DIR = C:\Program Files\Adobe\Reader 10.0\Esl\
      Property(S): FONT = C:\Program Files\Adobe\Reader 10.0\Resource\Font\
      Property(S): FavoritesFolder = C:\Users\Administrator\Favorites\
      Property(S): FontsFolder = C:\Windows\Fonts\
      Property(S): GlobalAssemblyCache = C:\
      Property(S): IDTEMPLATES = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\
      Property(S): IDTEMPLATES_CAT = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CAT\
      Property(S): IDTEMPLATES_CHS = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CHS\
      Property(S): IDTEMPLATES_CHT = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CHT\
      Property(S): IDTEMPLATES_CZE = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\CZE\
      Property(S): IDTEMPLATES_DAN = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\DAN\
      Property(S): IDTEMPLATES_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\DEU\
      Property(S): IDTEMPLATES_ENU = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ENU\
      Property(S): IDTEMPLATES_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ESP\
      Property(S): IDTEMPLATES_EUQ = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\EUQ\
      Property(S): IDTEMPLATES_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\FRA\
      Property(S): IDTEMPLATES_HRV = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\HRV\
      Property(S): IDTEMPLATES_HUN = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\HUN\
      Property(S): IDTEMPLATES_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\ITA\
      Property(S): IDTEMPLATES_JPN = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\JPN\
      Property(S): IDTEMPLATES_KOR = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\KOR\
      Property(S): IDTEMPLATES_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\NLD\
      Property(S): IDTEMPLATES_NOR = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\NOR\
      Property(S): IDTEMPLATES_POL = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\POL\
      Property(S): IDTEMPLATES_PTB = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\PTB\
      Property(S): IDTEMPLATES_RUM = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\RUM\
      Property(S): IDTEMPLATES_RUS = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\RUS\
      Property(S): IDTEMPLATES_SKY = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SKY\
      Property(S): IDTEMPLATES_SLV = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SLV\
      Property(S): IDTEMPLATES_SUO = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SUO\
      Property(S): IDTEMPLATES_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\SVE\
      Property(S): IDTEMPLATES_TUR = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\TUR\
      Property(S): IDTEMPLATES_UKR = C:\Program Files\Adobe\Reader 10.0\Reader\IDTemplates\UKR\
      Property(S): READER_9.0 = C:\Program Files\Adobe\Reader 10.0\
      Property(S): JAVASCRIPTS = C:\Program Files\Adobe\Reader 10.0\Reader\Javascripts\
      Property(S): LEGAL = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\
      Property(S): LEGAL_CAT = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CAT\
      Property(S): LEGAL_CHS = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CHS\
      Property(S): LEGAL_CHT = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CHT\
      Property(S): LEGAL_CZE = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\CZE\
      Property(S): LEGAL_DAN = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\DAN\
      Property(S): LEGAL_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\DEU\
      Property(S): LEGAL_ENU = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ENU\
      Property(S): LEGAL_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ESP\
      Property(S): LEGAL_EUQ = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\EUQ\
      Property(S): LEGAL_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\FRA\
      Property(S): LEGAL_HRV = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\HRV\
      Property(S): LEGAL_HUN = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\HUN\
      Property(S): LEGAL_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ITA\
      Property(S): LEGAL_JPN = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\JPN\
      Property(S): LEGAL_KOR = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\KOR\
      Property(S): LEGAL_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\NLD\
      Property(S): LEGAL_NOR = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\NOR\
      Property(S): LEGAL_POL = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\POL\
      Property(S): LEGAL_PTB = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\PTB\
      Property(S): LEGAL_RUM = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\RUM\
      Property(S): LEGAL_RUS = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\RUS\
      Property(S): LEGAL_SKY = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SKY\
      Property(S): LEGAL_SLV = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SLV\
      Property(S): LEGAL_SUO = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SUO\
      Property(S): LEGAL_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\SVE\
      Property(S): LEGAL_TUR = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\TUR\
      Property(S): LEGAL_UKR = C:\Program Files\Adobe\Reader 10.0\Reader\Legal\UKR\
      Property(S): LOCALE = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\
      Property(S): LOCALE_CA_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ca_ES\
      Property(S): LOCALE_CS_CZ = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\cs_CZ\
      Property(S): LOCALE_DA_DK = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\da_DK\
      Property(S): LOCALE_DE_DE = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\de_DE\
      Property(S): LOCALE_ES_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\es_ES\
      Property(S): LOCALE_EU_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\eu_ES\
      Property(S): LOCALE_FI_FI = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fi_FI\
      Property(S): LOCALE_FR_FR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fr_FR\
      Property(S): LOCALE_HR_HR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hr_HR\
      Property(S): LOCALE_HU_HU = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hu_HU\
      Property(S): LOCALE_IT_IT = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\it_IT\
      Property(S): LOCALE_JA_JP = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ja_JP\
      Property(S): LOCALE_KO_KR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ko_KR\
      Property(S): LOCALE_NB_NO = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nb_NO\
      Property(S): LOCALE_NL_NL = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nl_NL\
      Property(S): LOCALE_PL_PL = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pl_PL\
      Property(S): LOCALE_PT_BR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pt_BR\
      Property(S): LOCALE_RO_RO = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ro_RO\
      Property(S): LOCALE_RU_RU = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ru_RU\
      Property(S): LOCALE_SK_SK = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sk_SK\
      Property(S): LOCALE_SL_SI = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sl_SI\
      Property(S): LOCALE_SV_SE = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sv_SE\
      Property(S): LOCALE_TR_TR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\tr_TR\
      Property(S): LOCALE_UK_UA = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\uk_UA\
      Property(S): LOCALE_ZH_CN = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_CN\
      Property(S): LOCALE_ZH_TW = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_TW\
      Property(S): LocalAppDataFolder = C:\Users\Administrator\AppData\Local\
      Property(S): MOZILLA_1 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): MOZILLA_2 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): MOZILLA_3 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): MOZILLA_4 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): MOZILLA_5 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): MOZILLA_6 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): MOZILLA_7 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): MOZILLA_8 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): MPP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\
      Property(S): MPP_CZE = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_CZE\
      Property(S): MPP_HRV = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_HRV\
      Property(S): MPP_HUN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_HUN\
      Property(S): MPP_POL = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_POL\
      Property(S): MPP_RUM = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_RUM\
      Property(S): MPP_RUS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_RUS\
      Property(S): MPP_SKY = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_SKY\
      Property(S): MPP_SLV = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_SLV\
      Property(S): MPP_TUR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_TUR\
      Property(S): MPP_UKR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP_UKR\
      Property(S): MULTIMEDIA_MPP_CAT = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_CHS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_CHT = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_DAN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_EUQ = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_JAPN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_KOR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_NOR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_PTB = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_SUO = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MULTIMEDIA_MPP_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Multimedia\MPP\
      Property(S): MyPicturesFolder = C:\Users\Administrator\Pictures\
      Property(S): NETSCAPE_3 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): NETSCAPE_4 = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\
      Property(S): ONLINE_HELP = C:\Program Files\Common Files\Adobe\Help\
      Property(S): ONLINE_HELP_CA_ES = C:\Program Files\Common Files\Adobe\Help\ca_es\
      Property(S): ONLINE_HELP_CA_ES_RDR = C:\Program Files\Common Files\Adobe\Help\ca_es\reader\
      Property(S): ONLINE_HELP_CA_ES_RDRX = C:\Program Files\Common Files\Adobe\Help\ca_es\reader\X\
      Property(S): ONLINE_HELP_CA_ES_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\ca_es\reader\X\using\
      Property(S): ONLINE_HELP_CS_CZ = C:\Program Files\Common Files\Adobe\Help\cs_cz\
      Property(S): ONLINE_HELP_CS_CZ_RDR = C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\
      Property(S): ONLINE_HELP_CS_CZ_RDRX = C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\X\
      Property(S): ONLINE_HELP_CS_CZ_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\cs_cz\reader\X\using\
      Property(S): ONLINE_HELP_DA_DK = C:\Program Files\Common Files\Adobe\Help\da_dk\
      Property(S): ONLINE_HELP_DA_DK_RDR = C:\Program Files\Common Files\Adobe\Help\da_dk\reader\
      Property(S): ONLINE_HELP_DA_DK_RDRX = C:\Program Files\Common Files\Adobe\Help\da_dk\reader\X\
      Property(S): ONLINE_HELP_DA_DK_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\da_dk\reader\X\using\
      Property(S): ONLINE_HELP_DE_DE = C:\Program Files\Common Files\Adobe\Help\de_de\
      Property(S): ONLINE_HELP_DE_DE_RDR = C:\Program Files\Common Files\Adobe\Help\de_de\reader\
      Property(S): ONLINE_HELP_DE_DE_RDRX = C:\Program Files\Common Files\Adobe\Help\de_de\reader\X\
      Property(S): ONLINE_HELP_DE_DE_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\de_de\reader\X\using\
      Property(S): ONLINE_HELP_EN_US = C:\Program Files\Common Files\Adobe\Help\en_us\
      Property(S): ONLINE_HELP_EN_US_RDR = C:\Program Files\Common Files\Adobe\Help\en_us\reader\
      Property(S): ONLINE_HELP_EN_US_RDRX = C:\Program Files\Common Files\Adobe\Help\en_us\reader\X\
      Property(S): ONLINE_HELP_EN_US_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\en_us\reader\X\using\
      Property(S): ONLINE_HELP_ES_ES = C:\Program Files\Common Files\Adobe\Help\es_es\
      Property(S): ONLINE_HELP_ES_ES_RDR = C:\Program Files\Common Files\Adobe\Help\es_es\reader\
      Property(S): ONLINE_HELP_ES_ES_RDRX = C:\Program Files\Common Files\Adobe\Help\es_es\reader\X\
      Property(S): ONLINE_HELP_ES_ES_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\es_es\reader\X\using\
      Property(S): ONLINE_HELP_EU_ES = C:\Program Files\Common Files\Adobe\Help\eu_ES\
      Property(S): ONLINE_HELP_EU_ES_RDR = C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\
      Property(S): ONLINE_HELP_EU_ES_RDRX = C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\X\
      Property(S): ONLINE_HELP_EU_ES_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\eu_ES\reader\X\using\
      Property(S): ONLINE_HELP_FI_FI = C:\Program Files\Common Files\Adobe\Help\fi_fi\
      Property(S): ONLINE_HELP_FI_FI_RDR = C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\
      Property(S): ONLINE_HELP_FI_FI_RDRX = C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\X\
      Property(S): ONLINE_HELP_FI_FI_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\fi_fi\reader\X\using\
      Property(S): ONLINE_HELP_FR_FR = C:\Program Files\Common Files\Adobe\Help\fr_fr\
      Property(S): ONLINE_HELP_FR_FR_RDR = C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\
      Property(S): ONLINE_HELP_FR_FR_RDRX = C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\X\
      Property(S): ONLINE_HELP_FR_FR_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\fr_fr\reader\X\using\
      Property(S): ONLINE_HELP_HR_HR = C:\Program Files\Common Files\Adobe\Help\hr_hr\
      Property(S): ONLINE_HELP_HR_HR_RDR = C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\
      Property(S): ONLINE_HELP_HR_HR_RDRX = C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\X\
      Property(S): ONLINE_HELP_HR_HR_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\hr_hr\reader\X\using\
      Property(S): ONLINE_HELP_HU_HU = C:\Program Files\Common Files\Adobe\Help\hu_hu\
      Property(S): ONLINE_HELP_HU_HU_RDR = C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\
      Property(S): ONLINE_HELP_HU_HU_RDRX = C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\X\
      Property(S): ONLINE_HELP_HU_HU_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\hu_hu\reader\X\using\
      Property(S): ONLINE_HELP_IT_IT = C:\Program Files\Common Files\Adobe\Help\it_it\
      Property(S): ONLINE_HELP_IT_IT_RDR = C:\Program Files\Common Files\Adobe\Help\it_it\reader\
      Property(S): ONLINE_HELP_IT_IT_RDRX = C:\Program Files\Common Files\Adobe\Help\it_it\reader\X\
      Property(S): ONLINE_HELP_IT_IT_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\it_it\reader\X\using\
      Property(S): ONLINE_HELP_JA_JP = C:\Program Files\Common Files\Adobe\Help\ja_jp\
      Property(S): ONLINE_HELP_JA_JP_RDR = C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\
      Property(S): ONLINE_HELP_JA_JP_RDRX = C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\X\
      Property(S): ONLINE_HELP_JA_JP_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\ja_jp\reader\X\using\
      Property(S): ONLINE_HELP_KO_KR = C:\Program Files\Common Files\Adobe\Help\ko_kr\
      Property(S): ONLINE_HELP_KO_KR_RDR = C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\
      Property(S): ONLINE_HELP_KO_KR_RDRX = C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\X\
      Property(S): ONLINE_HELP_KO_KR_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\ko_kr\reader\X\using\
      Property(S): ONLINE_HELP_NB_NO = C:\Program Files\Common Files\Adobe\Help\nb_no\
      Property(S): ONLINE_HELP_NB_NO_RDR = C:\Program Files\Common Files\Adobe\Help\nb_no\reader\
      Property(S): ONLINE_HELP_NB_NO_RDRX = C:\Program Files\Common Files\Adobe\Help\nb_no\reader\X\
      Property(S): ONLINE_HELP_NB_NO_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\nb_no\reader\X\using\
      Property(S): ONLINE_HELP_NL_NL = C:\Program Files\Common Files\Adobe\Help\nl_nl\
      Property(S): ONLINE_HELP_NL_NL_RDR = C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\
      Property(S): ONLINE_HELP_NL_NL_RDRX = C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\X\
      Property(S): ONLINE_HELP_NL_NL_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\nl_nl\reader\X\using\
      Property(S): ONLINE_HELP_PL_PL = C:\Program Files\Common Files\Adobe\Help\pl_pl\
      Property(S): ONLINE_HELP_PL_PL_RDR = C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\
      Property(S): ONLINE_HELP_PL_PL_RDRX = C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\X\
      Property(S): ONLINE_HELP_PL_PL_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\pl_pl\reader\X\using\
      Property(S): ONLINE_HELP_PT_BR = C:\Program Files\Common Files\Adobe\Help\pt_br\
      Property(S): ONLINE_HELP_PT_BR_RDR = C:\Program Files\Common Files\Adobe\Help\pt_br\reader\
      Property(S): ONLINE_HELP_PT_BR_RDRX = C:\Program Files\Common Files\Adobe\Help\pt_br\reader\X\
      Property(S): ONLINE_HELP_PT_BR_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\pt_br\reader\X\using\
      Property(S): ONLINE_HELP_RO_RO = C:\Program Files\Common Files\Adobe\Help\ro_ro\
      Property(S): ONLINE_HELP_RO_RO_RDR = C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\
      Property(S): ONLINE_HELP_RO_RO_RDRX = C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\X\
      Property(S): ONLINE_HELP_RO_RO_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\ro_ro\reader\X\using\
      Property(S): ONLINE_HELP_RU_RU = C:\Program Files\Common Files\Adobe\Help\ru_ru\
      Property(S): ONLINE_HELP_RU_RU_RDR = C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\
      Property(S): ONLINE_HELP_RU_RU_RDRX = C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\X\
      Property(S): ONLINE_HELP_RU_RU_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\ru_ru\reader\X\using\
      Property(S): ONLINE_HELP_SK_SK = C:\Program Files\Common Files\Adobe\Help\sk_sk\
      Property(S): ONLINE_HELP_SK_SK_RDR = C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\
      Property(S): ONLINE_HELP_SK_SK_RDRX = C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\X\
      Property(S): ONLINE_HELP_SK_SK_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\sk_sk\reader\X\using\
      Property(S): ONLINE_HELP_SL_SI = C:\Program Files\Common Files\Adobe\Help\sl_si\
      Property(S): ONLINE_HELP_SL_SI_RDR = C:\Program Files\Common Files\Adobe\Help\sl_si\reader\
      Property(S): ONLINE_HELP_SL_SI_RDRX = C:\Program Files\Common Files\Adobe\Help\sl_si\reader\X\
      Property(S): ONLINE_HELP_SL_SI_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\sl_si\reader\X\using\
      Property(S): ONLINE_HELP_SV_SE = C:\Program Files\Common Files\Adobe\Help\sv_se\
      Property(S): ONLINE_HELP_SV_SE_RDR = C:\Program Files\Common Files\Adobe\Help\sv_se\reader\
      Property(S): ONLINE_HELP_SV_SE_RDRX = C:\Program Files\Common Files\Adobe\Help\sv_se\reader\X\
      Property(S): ONLINE_HELP_SV_SE_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\sv_se\reader\X\using\
      Property(S): ONLINE_HELP_TR_TR = C:\Program Files\Common Files\Adobe\Help\tr_tr\
      Property(S): ONLINE_HELP_TR_TR_RDR = C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\
      Property(S): ONLINE_HELP_TR_TR_RDRX = C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\X\
      Property(S): ONLINE_HELP_TR_TR_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\tr_tr\reader\X\using\
      Property(S): ONLINE_HELP_UK_UA = C:\Program Files\Common Files\Adobe\Help\uk_ua\
      Property(S): ONLINE_HELP_UK_UA_RDR = C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\
      Property(S): ONLINE_HELP_UK_UA_RDRX = C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\X\
      Property(S): ONLINE_HELP_UK_UA_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\uk_ua\reader\X\using\
      Property(S): ONLINE_HELP_ZH_CN = C:\Program Files\Common Files\Adobe\Help\zh_cn\
      Property(S): ONLINE_HELP_ZH_CN_RDR = C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\
      Property(S): ONLINE_HELP_ZH_CN_RDRX = C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\X\
      Property(S): ONLINE_HELP_ZH_CN_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\zh_cn\reader\X\using\
      Property(S): ONLINE_HELP_ZH_TW = C:\Program Files\Common Files\Adobe\Help\zh_tw\
      Property(S): ONLINE_HELP_ZH_TW_RDR = C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\
      Property(S): ONLINE_HELP_ZH_TW_RDRX = C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\X\
      Property(S): ONLINE_HELP_ZH_TW_RDRX_USING = C:\Program Files\Common Files\Adobe\Help\zh_tw\reader\X\using\
      Property(S): PFM = C:\Program Files\Adobe\Reader 10.0\Resource\Font\PFM\
      Property(S): PLUGINS_3D = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins3d\
      Property(S): PLUGINS_3D_PRC = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins3d\prc\
      Property(S): PLUG_INS_ACROFORM = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\AcroForm\
      Property(S): PLUG_INS_ACROFORM_PMP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\AcroForm\PMP\
      Property(S): PersonalFolder = C:\Users\Administrator\Documents\
      Property(S): PrimaryVolumePath = C:\
      Property(S): ProgramFiles64Folder = C:\
      Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
      Property(S): SASIPREP = C:\Program Files\Adobe\Reader 10.0\Resource\SaslPrep\
      Property(S): SERVICES = C:\Program Files\Adobe\Reader 10.0\Reader\Services\
      Property(S): SERVICES_CA_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ca_ES\Services\
      Property(S): SERVICES_CS_CZ = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\cs_CZ\Services\
      Property(S): SERVICES_DA_DK = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\da_DK\Services\
      Property(S): SERVICES_DE_DE = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\de_DE\Services\
      Property(S): SERVICES_ES_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\es_ES\Services\
      Property(S): SERVICES_EU_ES = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\eu_ES\Services\
      Property(S): SERVICES_FI_FI = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fi_FI\Services\
      Property(S): SERVICES_FR_FR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\fr_FR\Services\
      Property(S): SERVICES_HR_HR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hr_HR\Services\
      Property(S): SERVICES_HU_HU = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\hu_HU\Services\
      Property(S): SERVICES_IT_IT = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\it_IT\Services\
      Property(S): SERVICES_JA_JP = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ja_JP\Services\
      Property(S): SERVICES_KO_KR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ko_KR\Services\
      Property(S): SERVICES_NB_NO = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nb_NO\Services\
      Property(S): SERVICES_NL_NL = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\nl_NL\Services\
      Property(S): SERVICES_PL_PL = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pl_PL\Services\
      Property(S): SERVICES_PT_BR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\pt_BR\Services\
      Property(S): SERVICES_RO_RO = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ro_RO\Services\
      Property(S): SERVICES_RU_RU = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\ru_RU\Services\
      Property(S): SERVICES_SK_SK = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sk_SK\Services\
      Property(S): SERVICES_SL_SI = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sl_SI\Services\
      Property(S): SERVICES_SV_SE = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\sv_SE\Services\
      Property(S): SERVICES_TR_TR = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\tr_TR\Services\
      Property(S): SERVICES_UK_UA = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\uk_UA\Services\
      Property(S): SERVICES_ZH_CN = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_CN\Services\
      Property(S): SERVICES_ZH_TW = C:\Program Files\Adobe\Reader 10.0\Reader\Locale\zh_TW\Services\
      Property(S): SPPLUGINS = C:\Program Files\Adobe\Reader 10.0\Reader\SPPlugins\
      Property(S): STAMP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\
      Property(S): STAMP_CAT = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CAT\
      Property(S): STAMP_CHS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CHS\
      Property(S): STAMP_CHT = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CHT\
      Property(S): STAMP_CZE = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\CZE\
      Property(S): STAMP_DAN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\DAN\
      Property(S): STAMP_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\DEU\
      Property(S): STAMP_ENU = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ENU\
      Property(S): STAMP_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ESP\
      Property(S): STAMP_EUQ = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\EUQ\
      Property(S): STAMP_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\FRA\
      Property(S): STAMP_HRV = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\HRV\
      Property(S): STAMP_HUN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\HUN\
      Property(S): STAMP_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\ITA\
      Property(S): STAMP_JPN = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\JPN\
      Property(S): STAMP_KOR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\KOR\
      Property(S): STAMP_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\NLD\
      Property(S): STAMP_NOR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\NOR\
      Property(S): STAMP_POL = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\POL\
      Property(S): STAMP_PTB = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\PTB\
      Property(S): STAMP_RUM = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\RUM\
      Property(S): STAMP_RUS = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\RUS\
      Property(S): STAMP_SKY = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SKY\
      Property(S): STAMP_SLV = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SLV\
      Property(S): STAMP_SUO = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SUO\
      Property(S): STAMP_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\SVE\
      Property(S): STAMP_TUR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\TUR\
      Property(S): STAMP_UKR = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\Annotations\Stamps\UKR\
      Property(S): SendToFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\SendTo\
      Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
      Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
      Property(S): System16Folder = C:\Windows\system\
      Property(S): System64Folder = C:\
      Property(S): SystemFolder = C:\Windows\system32\
      Property(S): SourceDir = \\10.41.3.10\DeploymentShare$\Applications\Adobe Reader 10.1.1\
      Property(S): TRACKER = C:\Program Files\Adobe\Reader 10.0\Reader\Tracker\
      Property(S): TYPESPT = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\
      Property(S): TYPESPT_UNICODE = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\
      Property(S): TYPESPT_UNICODE_ICU = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\ICU\
      Property(S): TYPESPT_UNICODE_MAPPINGS = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\
      Property(S): TYPESPT_UNICODE_MAPPINGS_ADOBE = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\Adobe\
      Property(S): TYPESPT_UNICODE_MAPPINGS_MAC = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\Mac\
      Property(S): TYPESPT_UNICODE_MAPPINGS_WIN = C:\Program Files\Adobe\Reader 10.0\Resource\TypeSupport\Unicode\Mappings\win\
      Property(S): TempFolder = C:\Users\ADMINI~1\AppData\Local\Temp\
      Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
      Property(S): USERPROFILE = C:\Users\Administrator\
      Property(S): VDKHOME = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\
      Property(S): VDKHOME_DEU = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\DEU\
      Property(S): VDKHOME_ENU = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ENU\
      Property(S): VDKHOME_ESP = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ESP\
      Property(S): VDKHOME_FRA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\FRA\
      Property(S): VDKHOME_ITA = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\ITA\
      Property(S): VDKHOME_NLD = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\NLD\
      Property(S): VDKHOME_SVE = C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins\VDKHome\SVE\
      Property(S): WindowsFolder = C:\Windows\
      Property(S): WindowsVolume = C:\
      Property(S): Time = 13:00:11
      Property(S): TTCSupport = 1
      Property(S): ColorBits = 32
      Property(S): TextInternalLeading = 3
      Property(S): TextHeight = 16
      Property(S): BorderSide = 1
      Property(S): BorderTop = 1
      Property(S): CaptionHeight = 22
      Property(S): WindowsFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\
      Property(S): SystemFolder.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\system32\
      Property(S): WinSxsDirectory.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\
      Property(S): payload_ul.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.21022.8_none_bcb86ed6ac711f 91\
      Property(S): payload.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_d08d0375\
      Property(S): WinSxsManifests.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\Manifests\
      Property(S): WinSxsPolicies.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\Policies\
      Property(S): policydir.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
      Property(S): policydir_ul.21022.08.Microsoft_VC90_CRT_x86.RTM.0138F525_6C8A_333F_A105_14AE030B9A54 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
      Property(S): ScreenY = 768
      Property(S): ALLUSERS = 1
      Property(S): Dummy_Microsoft_VC90_CRT_x86.0138F525_6C8A_333F_A105_14AE030B9A54 = 1
      Property(S): WinSxsDirectory.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_94 7B287C203A = C:\Windows\winsxs\
      Property(S): payload_ul.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B287 C203A = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.21022.8_none_60a 5df56e60dc5df\
      Property(S): WinSxsPolicies.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947 B287C203A = C:\Windows\winsxs\Policies\
      Property(S): policydir.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B287C 203A = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_b7353f 75\
      Property(S): WindowsFolder.21022.08.policy_9_0_Microsoft_VC90_CRT_x86.RTM.52105B6B_A3EF_3A90_882A_947B 287C203A = C:\Windows\
      Property(S): Dummy_policy_9_0_Microsoft_VC90_CRT_x86.52105B6B_A3EF_3A90_882A_947B287C203A = 1
      Property(S): ScreenX = 1024
      Property(S): SystemLanguageID = 4108
      Property(S): ComputerName = M91P-7
      Property(S): UserLanguageID = 4108
      Property(S): UserSID = S-1-5-21-3102773726-310897427-2134307747-500
      Property(S): LogonUser = Administrator
      Property(S): MsiTrueAdminUser = 1
      Property(S): AdminUser = 1
      Property(S): VirtualMemory = 5269
      Property(S): PhysicalMemory = 2922
      Property(S): Intel = 6
      Property(S): ShellAdvtSupport = 1
      Property(S): OLEAdvtSupport = 1
      Property(S): GPTSupport = 1
      Property(S): MIN_SYSTEM = C:\Windows\system32\Shdocvw.dll
      Property(S): AS_REPAIR_VERSION_LIST = A
      Property(S): IE_VERSION = 8.0.7601.17514
      Property(S): ProductCode = {AC76BA86-7AD7-1033-7B44-AA1000000001}
      Property(S): ApplicationUsers = AllUsers
      Property(S): AgreeToLicense = No
      Property(S): _IsMaintenance = Reinstall
      Property(S): SetupType = Typical
      Property(S): _IsSetupTypeMin = Typical
      Property(S): ARPCONTACT = Customer Support
      Property(S): ARPHELPLINK = http://www.adobe.com/support/main.html
      Property(S): ARPREADME = C:\Program Files\Adobe\Reader 10.0\Readme.htm
      Property(S): ARPURLINFOABOUT = http://www.adobe.com
      Property(S): ARPURLUPDATEINFO = http://www.adobe.com/products/acrobat/readstep.html
      Property(S): DefaultUIFont = Tahoma8
      Property(S): ErrorDialog = SetupError
      Property(S): INSTALLLEVEL = 100
      Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
      Property(S): Manufacturer = Adobe Systems Incorporated
      Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
      Property(S): ProductID = none
      Property(S): ProductLanguage = 1033
      Property(S): ProductName = Adobe Reader X (10.1.1)
      Property(S): ProductVersion = 10.1.1
      Property(S): ProgressType0 = install
      Property(S): ProgressType1 = Installing
      Property(S): ProgressType2 = installed
      Property(S): ProgressType3 = installs
      Property(S): RebootYesNo = Yes
      Property(S): ReinstallModeText = omus
      Property(S): TRACKINGKEY = Software\Adobe\Acrobat Reader\7.0
      Property(S): ARPPRODUCTICON = SC_Reader.ico
      Property(S): Cancel = 0
      Property(S): RadioGroup = 0
      Property(S): TypicalText = 0
      Property(S): ARPCOMMENTS =
      Property(S): ERROR_MIN_OVER_BIG = Setup has detected that you already have a more functional product installed.  Setup will now terminate.
      Property(S): SecureCustomProperties = DEFAULT_VERB;ACTIONPROPERTY;ELEMENTS;RDRMIN;RDRBIG;RDRBIG_8X;RDRBIG_9X;RDRBIG_10X;UT_FRB; UT_FRS;UT_AT;UT_AP1;UT_AP2;UT_AS1;UT_AS2;UT_A3D;UT_6X;UT_7X;UT_MM61;UT_MM62;UT_MM63;UT_EB6 1;UT_EB62;UT_EB63;AS_OPTIMIZE_ENABLED;ACROBAT_APP_PATH;AS_HKCR_EXE;PDFSHELL_LOCALSERVER_CO MMAND;PDF_DEFAULTICON;PDF_PREVIEW_HANDERLER_DLL;PDF_PREVIEW_HANDERLER_HELPDIR;DISABLE_PDFO WNERSHIP_RESTORE;PDF_INPROCSERVER_VIEWERPS;READER_PATH
      Property(S): BrandName = Adobe Reader X (10.1.1)
      Property(S): ISVROOT_PORT_NO = 0
      Property(S): IsMinIE_Message = requires Internet Explorer 6.0 or greater.  Please visit www.microsoft.com to upgrade Internet Explorer.
      Property(S): ISLANGFLAG = ENU
      Property(S): FilesLabel = 0
      Property(S): DisallowRunFromSource = 1
      Property(S): AppsInUseSilentAbort = A process is running that cannot be shut down by Setup.  Please either close all applications and run Setup again, or restart your computer and run Setup again.
      Property(S): ENABLE_CACHE_FILES = YES
      Property(S): OLE_VERB_OPEN = &Open,0,2
      Property(S): REINSTALLMODE = omus
      Property(S): Elevated = 1
      Property(S): ENABLE_OPTIMIZATION = YES
      Property(S): ERROR_DEFRAG_MSG = Optimizing performance ...
      Property(S): ERROR_DEFRAG_ADTEMPLATE = Completed [1]% of process
      Property(S): ERROR_CANNOT_OPTIMIZE_DISK = NOTE: Installation was successful. However, because your hard drive is fragmented, this application may not be able to launch as quickly as possible. To optimize performance, please defragment your hard drive and then repair this application under Add or Remove Programs in the Control Panel.
      Property(S): EULA_ACCEPT = YES
      Property(S): DISABLE_BROWSER_INTEGRATION = NO
      Property(S): AcroIEHelper_Description = Adobe PDF Reader Link Helper
      Property(S): DEFAULT_VERB = Read
      Property(S): ADMIN_INSTALL = NO
      Property(S): AdminProperties = ADMIN_INSTALL
      Property(S): REMOVE_PREVIOUS = YES
      Property(S): SYNCHRONIZER = YES
      Property(S): OpenWith = Open with Adobe Reader X
      Property(S): SetupCacheExport = Enterprise.mnt
      Property(S): LC_UNSUPPORTED_OS = This application cannot be installed on this operating system. Setup will now terminate. Please refer to the minimum system requirements at http://www.adobe.com/go/reader_system_reqs.
      Property(S): ApplicationList = 0
      Property(S): DEFAULT_ATTACHMENT_WHITELIST = version:1|.ade:3|.adp:3|.app:3|.arc:3|.arj:3|.asp:3|.bas:3|.bat:3|.bz:3|.bz2:3|.cab:3|.ch m:3|.class:3|.cmd:3|.com:3|.command:3|.cpl:3|.crt:3|.csh:3|.desktop:3|.dll:3|.exe:3|.fxp:3 |.gz:3|.hex:3|.hlp:3|.hqx:3|.hta:3|.inf:3|.ini:3|.ins:3|.isp:3|.its:3|.job:3|.js:3|.jse:3| .ksh:3|.lnk:3|.lzh:3|.mad:3|.maf:3|.mag:3|.mam:3|.maq:3|.mar:3|.mas:3|.mat:3|.mau:3|.mav:3 |.maw:3|.mda:3|.mdb:3|.mde:3|.mdt:3|.mdw:3|.mdz:3|.msc:3|.msi:3|.msp:3|.mst:3|.ocx:3|.ops: 3|.pcd:3|.pi:3|.pif:3|.prf:3|.prg:3|.pst:3|.rar:3|.reg:3|.scf:3|.scr:3|.sct:3|.sea:3|.shb: 3|.shs:3|.sit:3|.tar:3|.taz:3|.tgz:3|.tmp:3|.url:3|.vb:3|.vbe:3|.vbs:3|.vsmacros:3|.vss:3| .vst:3|.vsw:3|.webloc:3|.ws:3|.wsc:3|.wsf:3|.wsh:3|.z:3|.zip:3|.zlo:3|.zoo:3|.pdf:2|.fdf:2 |.jar:3|.pkg:3|.tool:3|.term:3
      Property(S): EXEC_MENU_WHITELIST = Close|GeneralInfo|Quit|FirstPage|PrevPage|NextPage|LastPage|ActualSize|FitPage|FitWidth|F itHeight|SinglePage|OneColumn|TwoPages|TwoColumns|ZoomViewIn|ZoomViewOut|ShowHideBookmarks |ShowHideThumbnails|Print|GoToPage|ZoomTo|GeneralPrefs|SaveAs|FullScreenMode|OpenOrganizer |Scan|Web2PDF:OpnURL|AcroSendMail:SendMail|Spelling:Check Spelling|PageSetup|Find|FindSearch|GoBack|GoForward|FitVisible|ShowHideArticles|ShowHideF ileAttachment|ShowHideAnnotManager|ShowHideFields|ShowHideOptCont|ShowHideModelTree|ShowHi deSignatures|InsertPages|ExtractPages|ReplacePages|DeletePages|CropPages|RotatePages|AddFi leAttachment|FindCurrentBookmark|BookmarkShowLocation|GoBackDoc|GoForwardDoc|DocHelpUserGu ide|HelpReader|rolReadPage|HandMenuItem|ZoomDragMenuItem|CollectionPreview|CollectionHome| CollectionDetails|CollectionShowRoot|&Pages|Co&ntent|&Forms|Action &Wizard|Recognize &Text|P&rotection|&Sign && Certify|Doc&ument Processing|Print Pro&duction|Ja&vaScript|&Accessibility|Analy&ze|&Annotations|D&rawing Markups|Revie&w
      Property(S): PDF_Integration = 1
      Property(S): Browser_Integration = 2
      Property(S): ARPNOREPAIR = 1
      Property(S): ActionTextLabel = 0
      Property(S): CurrentPdfOwner = 0
      Property(S): ReadmeHtml = Readme.htm
      Property(S): OprimizeError2 = 0
      Property(S): ReaderProcessPopup = 0
      Property(S): BrandNameMajorVer = Adobe Reader X
      Property(S): DefragResetProgress = No
      Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
      Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
      Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
      Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
      Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
      Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
      Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
      Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
      Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
      Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
      Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
      Property(S): IS_SQLSERVER_AUTHENTICATION = 0
      Property(S): IS_SQLSERVER_USERNAME = sa
      Property(S): _5789b66a5ab8e = {AC76BA80-0010-7AD7-0000-000000000000}
      Property(S): AttentionCloseReader = 0
      Property(S): RunTimeProperties = CACHE_DIR;ProductName;OriginalDatabase;REMOVE;WindowsFolder;SetupCacheExport;ALLUSERS;REI NSTALLMODE;PLUG_INS;DefragResetProgress;ALLUSERS_APPDATA_ADOBE;DEFAULT_VERB;IS_CURRENT_PDF OWNER;ACTIVE_X;Installed;READER;ProductCode;INSTALLDIR
      Property(S): DV = 10.0
      Property(S): MSIRESTARTMANAGERCONTROL = Disable
      Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
      Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
      Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
      Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
      Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
      Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
      Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
      Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
      Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
      Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
      Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
      Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
      Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
      Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
      Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
      Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
      Property(S): RestartManagerOption = CloseRestart
      Property(S): AppsInUseUnknownAcrobatApps = Applications that are using Adobe Reader or Adobe Acrobat
      Property(S): EmbdUI = 1
      Property(S): ADOBE_LINK = http://www.adobe.com
      Property(S): _WebLinkChecked = 0
      Property(S): CurrentProduct = 0
      Property(S): DWUSLINK = CEFB870FBECC80BF79AC97C8298C978FD9DCB78FCEDC5098CE8B974F99DBF0F8CEEC50A809AC
      Property(S): PROCESSPATHWITHID = %s with process ID: %d
      Property(S): LANG_LIST = ENU,FRA,DEU,JPN,ITA,ESP,NLD,PTB,SVE,DAN,SUO,NOR,CHS,CHT,KOR,BGR,CZE,ETI,HRV,HUN,LTH,LVI,P OL,RUM,RUS,SKY,SLV,TUR,UKR,EUQ,CAT
      Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
      Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
      Property(S): UNKNOWNPROCESSWITHID = Unknown process with process ID: %d
      Property(S): Square = 1
      Property(S): ISReleaseFlags = ENU,READERBIG
      Property(S): ARPINSTALLLOCATION = C:\Program Files\Adobe\Reader 10.0\Reader\
      Property(S): REBOOT = ReallySuppress
      Property(S): PROGID7_ALTERNATE_COMMAND = C:\Program Files\Adobe\Reader 10.0\Reader\AcroRd32.exe
      Property(S): SourceDirCustom = \\10.41.3.10\DeploymentShare$\Applications\Adobe Reader 10.1.1\
      Property(S): Privileged = 1
      Property(S): RecentFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent\
      Property(S): PrintHoodFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
      Property(S): NetHoodFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
      Property(S): RemoteAdminTS = 1
      Property(S): MsiNTProductType = 1
      Property(S): ServicePackLevelMinor = 0
      Property(S): ServicePackLevel = 1
      Property(S): WindowsBuild = 7601
      Property(S): VersionMsi = 5.00
      Property(S): CLIENTPROCESSID = 2512
      Property(S): PackageCode = {364B464D-6DBD-4D57-AC60-ED8CCED960B1}
      Property(S): CURRENTDIRECTORY = \\10.41.3.10\DeploymentShare$\Applications\Adobe Reader 10.1.1
      Property(S): TRANSFORMS = \\10.41.3.10\DeploymentShare$\Applications\Adobe Reader 10.1.1\AcroRead.mst
      Property(S): ProductState = -1
      Property(S): CLIENTUILEVEL = 3
      Property(S): VersionDatabase = 300
      Property(S): PackagecodeChanging = 1
      Property(S): MsiLogFileLocation = \\10.41.3.10\DeploymentShare$\Applications\Adobe Reader 10.1.1\log.txt
      Property(S): IW_DEFAULT_VERB = Read
      Property(S): CostingComplete = 1
      Property(S): SOURCEDIR = \\10.41.3.10\DeploymentShare$\Applications\Adobe Reader 10.1.1\
      Property(S): SourcedirProduct = {AC76BA86-7AD7-1033-7B44-AA1000000001}
      Property(S): ALLOW_LOCKDOWN_BROWSE = YES
      Property(S): ALLOW_LOCKDOWN_MEDIA = YES
      Property(S): OutOfDiskSpace = 0
      Property(S): OutOfNoRbDiskSpace = 0
      Property(S): PrimaryVolumeSpaceAvailable = 0
      Property(S): PrimaryVolumeSpaceRequired = 0
      Property(S): PrimaryVolumeSpaceRemaining = 0
      Property(S): AS_HKCR_EXE = "C:\Program Files\Adobe\Reader 10.0\Reader\AcroRd32.exe"
      Property(S): PDFSHELL_LOCALSERVER_COMMAND = "C:\Program Files\Adobe\Reader 10.0\Reader\AcroRd32Info.exe" /PDFShell
      Property(S): PDF_DEFAULTICON = C:\Windows\Installer\{AC76BA86-7AD7-1033-7B44-AA1000000001}\PDFFile_8.ico,0
      Property(S): PDF_PREVIEW_HANDERLER_DLL = C:\Program Files\Adobe\Reader 10.0\Reader\pdfprevhndlr.dll
      Property(S): PDF_PREVIEW_HANDERLER_HELPDIR = C:\Program Files\Adobe\Reader 10.0\Reader\
      Property(S): PDF_INPROCSERVER_VIEWERPS = C:\Program Files\Adobe\Reader 10.0\Reader\ViewerPS.dll
      Property(S): ProductToBeRegistered = 1
      MSI (s) (90:18) [13:00:11:310]: Product: Adobe Reader X (10.1.1) -- Installation operation completed successfully.
      MSI (s) (90:18) [13:00:11:310]: Windows Installer installed the product. Product Name: Adobe Reader X (10.1.1). Product Version: 10.1.1. Product Language: 1033. Manufacturer: Adobe Systems Incorporated. Installation success or error status: 0.
      === Logging stopped: 07.12.2011  13:00:11 ===
      I hope you will be able to help me,
