1. Re: My spry horizontal menu drops then returns when clicked?
SnakEyez02 Dec 7, 2011 7:03 AM (in response to INTYME1985)Although I'm not quite sure why you need the table, that is the cause of the problem. The table's width is 990px, the two cells combine to be 944px (494px and 450px). Then you have an unnecessary set of P tags on line 354 that can be deleted. Then should the menu be overlapping the header image or immediately after because that will make a difference for how to change the end of the code. And lastly, you should add the attribute "no-repeat" to your background for the header in the CSS because on the right hand side I can see your header repeating and it doesn't feel like it should be.
2. Re: My spry horizontal menu drops then returns when clicked?
INTYME1985 Dec 7, 2011 7:47 AM (in response to SnakEyez02)Thank you SnakEyez02,
I made the changes you suggested. The spry horizontal menu should be below the header background image. Also, I put the Facebook plugins into a table, for lack of better understanding of controlling it's placement. I would like both Facebook buttons to be even along the top.
When I opened the template this morning, the last spry menu option (Testimonials) suddenly word wrapped (?) and began a second line under the first menu item (Contact). So I played with adjusting it's width and font size. I haven't made any other template changes in 6 months and don't know why it "word wrapped"?
Thank you again for your help.
JM
3. Re: My spry horizontal menu drops then returns when clicked?
SnakEyez02 Dec 7, 2011 8:53 AM (in response to INTYME1985)Ok. Put the menu (ul) inside a div just after your header div. And be sure to delete that extra set of P tags I was talking about. They still appear on the site and are adding space that is unnecessary. Also if you are going to use a table, just add the "valign=top" to the table cell (td) so that they line up. It would look better that way.
