4 Replies Latest reply on Dec 7, 2011 5:39 PM by t4sca
    Adobe AIR communicate with PHP
    Yue_Hong Level 1
      How can I have Adobe AIR program to communicate with PHP? For example, I need my app to get some value from PHP and display it. I have tried with "webservice" and using the example I found here: http://dimuthuc.blogspot.com/2008/01/php-webservice-consume-from-flex.html. But it doesn't work, and it shows "Error #1088: The markup in the document following the root element must be well-formed."
      How can I get it works? Is there any other good example? Thanks.
        • 1. Re: Adobe AIR communicate with PHP
          Claudiu Ursica Level 4
          This sounds like a server side error or null value to me. Debug it on php side....
          C
          • 2. Re: Adobe AIR communicate with PHP
            Yue_Hong Level 1
            My php is exactly the same as from the example from http://dimuthuc.blogspot.com/2008/01/php-webservice-consume-from-flex.html.
            I am totally no idea how Flex work with PHP. Will Flex able to grape a value of the PHP which I simply do an echo on PHP side?
            Here is my flex AIR code:
            <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                   xmlns:mx="library://ns.adobe.com/flex/mx">
                <fx:Declarations>
                    <!-- Place non-visual elements (e.g., services, value objects) here -->
                    <s:WebService id="service" wsdl="http://localhost/online/test.php"
                                  useProxy="false" showBusyCursor="true" result="service_resultHandler(event)" fault="service_faultHandler(event)" />
                </fx:Declarations>
                <fx:Script>
                    <![CDATA[
                        import mx.controls.Alert;
                        import mx.rpc.events.FaultEvent;
                        import mx.rpc.events.ResultEvent;
                        private function callService():void
                            service.loadWSDL();
                            service.greet(input.text);
                        protected function service_resultHandler(event:ResultEvent):void
                            // TODO Auto-generated method stub
                            result.text = event.result.toString();
                        protected function service_faultHandler(event:FaultEvent):void
                            Alert.show(event.fault.faultString, event.fault.faultCode);
                </fx:Script>
                <s:Panel id="pnlMain" x="10" y="10" width="450" height="250" title="My Greeting Client">
                    <s:TextArea x = "10" y="15" id="input" editable="true" width="400" height="50" />
                    <s:TextArea x = "10" y="100" id="result" editable="false" width="400" height="50" />
                    <s:Button x="10" y="170" label="Call WebService"
                               id="butJSDisplay" click="callService()"/>
                </s:Panel>
            </s:WindowedApplication>
            PHP file:
            <?php
            /** greet function
              * @param string $name
              * (map to xs:string)
              * @return string $greetReturn
            function greet($name)
               $result = array ('greetReturn' => "Greetings, ".$name);
               return $result;
            $operations = array('greet' => 'greet');
            $parameters = array('greet' => 'MIXED');
            $service = new WSService(array
                           'operations' => $operations,
                           'opParams' => $parameters
            $service->reply();
            • 3. Re: Adobe AIR communicate with PHP
              You need to debug the php side first see if the name gets from flex to php, and then if so move on towards building the response. I don't have php installed here so i cannot run it (; .
              C
              • 4. Re: Adobe AIR communicate with PHP
                t4sca Level 1
                That blog post made my head hurt.
                * My ActionScript Call.
                private function getData(event:Event):void
                          busyIndicator.visible = true;
                          var _params:Object = new Object();
                          _params.CustomerID = data.Customer.ID;
                          var _getData= new HTTPService();
                          _getData.url = "http://" + FlexGlobals.topLevelApplication.SERVER + "/GetData.php";
                          _getData.method="POST";
                          _getData.addEventListener(FaultEvent.FAULT, fhHttpService);
                          _getData.addEventListener(ResultEvent.RESULT, rhGetData);
                          _getData.send(_params);
                * PHP : If it's simple data I usually just echo as is, if it's somewhat complex data, I get PHP to create xml, and echo the xml.
                echo ($Data);
