1 Reply Latest reply on Dec 9, 2011 7:03 AM by Rod@FOF
    Windowed stage jumping between movie files
    BG Solutions
      OK, I’ve been in Flash land for a few years now and it seems I’ve forgotten the basics…
      I’m revising an old Director project that links between multiple movies. If the stage window is moved by the user, when the projector loads a new movie there is a brief flash of the stage in the center of the monitor before it can be correctly positioned.
      The stub projector is set to “Centered” and “Run in a Window”.
      Within the stub I have the following:
      global gStageRect
      gStageRect = (the stage).rect
      I have the following two behaviors in a shared cast linked to all movie files:
      on prepareMovie
           global gStageRect
           (the stage).rect = gStageRect
      End
      on moveWindow
           global gStageRect
           if the frame > 0 then
           end if
      end
      As I mentioned, when jumping from one movie to the next the stage will briefly flash centered in the monitor before the prepareMovie script puts it back where it belongs. Is there an earlier event than prepareMovie that has access to the stage rect?
