9 Replies Latest reply on Dec 22, 2011 6:08 PM by DebateBow
    iPhone 4S video
    DebateBow
      I am having trouble importing iPhone 4S video into premiere elements 10.  Each time I follow what would seem to be the appropriate method, I receive the following:
      "The importer reported a generic error."
      Ideas on what can I do to resolve this issue?
      Thanks!
        • 1. Re: iPhone 4S video
          What is the CODEC of that file, and what setting did you use for your project?
          Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
          What is a CODEC... a Primer http://forums.adobe.com/thread/546811
          What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
          Report back with the codec details of your file, use the programs below
          For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
          For Mac http://mediainfo.massanti.com/
          http://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-green-render-bars.html
          Once you know exactly what it is you are editing, report back with that information... and your project setting, and if there is a red line above the video in the timeline, which indicates a mismatch between video and project
          • 2. Re: iPhone 4S video
            the_wine_snob Level 9
            What are the specs. of the iPhone 4S video footage?
            Do you have the latest version of Apple's QuickTime installed?
            Which methods have you used to Import the files?
            Wife has 4S, but she's out of town, with the iPhone, so I cannot test right now.
            • 3. Re: iPhone 4S video
              DebateBow Level 1
              Here's some more information about one particular video clip:
              Per GSPOT Analysis:
              Contianer:
              qt:  Apple Quick Time (.MOV/QT)
              File Type:  QuickTime (.MOV)
              Mime Type:   video/quicktime
              Recommended Display Size: 480 x 272
              Audio
              Codec - mp4a: MPEG-4 AAC LC
              Info 44100Hz 64 kb/s, mono (1/0)
              Video
              Codec avc1
              Name H.264
              Codec status undetermined
              Settings for the project were the flip camera - HD 29.97 - found a tutorial online about Elements 9 and an iphone 4, and tried the same settings - but it wouldn't work.
              Latest version of quicktime is installed.  Will play the video on the computer - just won't import into the program.
              • 4. Re: iPhone 4S video
                bberglindsr Level 1
                Here's the information I get from my iphone 4s video:
                General / Container Stream #1
                          Total Video Streams for this File.................1
                          Total Audio Streams for this File.................1
                          Video Codecs Used.................................AVC
                          Audio Codecs Used.................................AAC LC
                          File Format.......................................MPEG-4
                          Play Time.........................................49mn 11s
                          Total File Size...................................8.21 GiB
                          Total Stream BitRate..............................23.9 Mbps
                          Encoded with......................................5.0.1
                          Encoding Library..................................Apple QuickTime
                Video Stream #1
                          Codec (Human Name)................................AVC
                          Codec (FourCC)....................................avc1
                          Codec Profile.....................................Baseline@L4.1
                          Frame Width.......................................1 920 pixels
                          Frame Height......................................1 080 pixels
                          Frame Rate........................................29.970 fps
                          Total Frames......................................88453
                          Display Aspect Ratio..............................16:9
                          Scan Type.........................................Progressive
                          Color Space.......................................YUV
                          Codec Settings (Summary)..........................1 Ref Frames
                          QF (like Gordian Knot)............................0.383
                          Codec Settings (CABAC)............................No
                          Codec Settings (Reference Frames).................1
                          Video Stream Length...............................49mn 11s 385ms
                          Video Stream BitRate..............................23.8 Mbps
                          Video Stream BitRate Mode.........................VBR
                          Bit Depth.........................................8 bits
                          Video Stream Size.................................8.18 GiB (100%)
                          Video Stream Title................................Core Media Video
                          Date of Original Encoding.........................UTC 2011-12-04 13:44:35
                          Color Primaries...................................BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
                          Transfer Characteristics..........................BT.709-5, BT.1361
                          Matrix Coefficients...............................BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
                Audio Stream #1
                          Codec.............................................AAC
                          Codec (FourCC)....................................40
                          Audio Stream Length...............................49mn 11s 442ms
                          Audio Stream BitRate..............................64.0 Kbps
                          Audio Stream BitRate Mode.........................CBR
                          Number of Audio Channels..........................1
                          Audio Channel's Positions.........................Front: C
                          Sampling Rate.....................................44.1 KHz
                          Audio Stream Size.................................22.1 MiB (0%)
                          Audio Stream Title................................Core Media Audio
                I am able to import the file, but it goes severely out of sync (audio to video) after about 10 minutes
                • 5. Re: iPhone 4S video
                  Nash_John Level 3
                  Hey DebateBow
                  what method have you tried for importing the clips into PrE. Try some other methods, as there exists many. (From File->Get Media, double clicking on the grid of the Media Panel, first copying to hard disk and then importing, drag-drop import), doesany one of them work, and check if you can import your Media into the Elements Organizer.
                  For bberglindsr
                  Have you gone back and checked the original video, if that also had sync problems as i have faced this issue once.
                  • 6. Re: iPhone 4S video
                    bberglindsr Level 1
                    Nash_John
                    I am actually using CS5 Premiere.  When I play a video from the iPhone 4s using QT, perfect sync.  When I input the file into Premiere, gradual unsync to significant after 10 minutes.  I am willing to bet all have this problem.
                    Anyone else tried to edit an iPhone 4s video in premiere?
                    • 7. Re: iPhone 4S video
                      You are in the wrong forum... you need the one for CS5 Premiere Pro... start a new discussion there
                      http://forums.adobe.com/community/premiere/premierepro_current
                      • 8. Re: iPhone 4S video
                        DebateBow Level 1
                        I have tried multiple methods of importing - and none of them seem to work for original video shot on the iphone 4S or the iphone 4.
                        I have been successful in importing video that was put through iMovie on the iPhone, but not raw video shot on the phone.
                        • 9. Re: iPhone 4S video
                          DebateBow Level 1
                          Seems like the best answers is to either:
                          1) import the video clips into iMovie on the iPhone and then export the movie.  That movie can easily be imported into Premiere Elements 10.
                          or
                          2) Put the raw video onto the computer, and import it into Windows Movie Maker - from here, you can export it to a format that will also be recognized by Premiere Elements 10.
                          That's the best solution I have found.
                          AGB
