2 Replies Latest reply on Dec 8, 2011 5:49 PM by PixelArtisan
    Display Color Management Simulated Rec709 differs from ProRes Output
    PixelArtisan
      Okay. I've read the Adobe white paper on proper Color Management workflow about a dozen times now, and I'm still getting some inconsistencies in my render outputs.
      DPX footage assigned a Kodak 5218/7218 Profile
      Project Settings: ProPhoto RGB
      Linearized Working Space
      Match Legacy AE QT Gamma Adjustments
      Output Profile: HDTV (Rec. 709)
      I'm outputting to a ProRes 4444 file.
      My problem arises from using the Simulate Output>Rec709 option in AE. I cannot get the output to look like this simulated color. Isn't that supposed to work?
      I can match the output to AE when I turn off Color Management and apply a Color Profile Converter effect, but there is a shift in color when viewing Simulated Color vs. using the Color Converter Effect. Even in AE the Converter Effect looks different than Simulated Color.
      I was under the impression that the point of the Simulated Output and Display Color Management options were to avoid having to do this. Should I change my workflow and just use the Converter Effect on all my comps? Or do I have a setting wrong somewhere? Has anyone else come across a discrepancy like this?
