2 Replies Latest reply on Dec 12, 2011 6:16 PM by h3lpm3Please
    Namespace causing problems in ArrayCollection
    h3lpm3Please
      I am a real novice so please be patient with me...
      I am using HTTPService to retrieve an XML formatted resultSet. The resultset includes namespaces which, when inserted into an ArrayCollection (for display in a DataGrid), prohibit me from accessing certain Object attributes.
      The XML returned:
      <?xml version="1.0" encoding="UTF-8"?>
      <result xmlns:l="http://www.w3.org/1999/xlink" xmlns:x="http://www.topicmaps.org/xtm/1.0/">
        <head>
          <column>TOPICNAME</column>
          <column>T</column>
        </head>
        <row>
          <value>Aria</value>
          <value>
            <x:topicRef l:href="file:/Users/xxx/Development/Servers/ontopia-5.1.3/apache-tomcat/webapps/omnigator /WEB-INF/topicmaps/ItalianOpera.ltm#Aria"/>
          </value>
        </row>
        <row>
          <value>Opera</value>
          <value>
            <x:subjectIndicatorRef l:href="http://psi.ontopedia.net/Opera"/>
          </value>
        </row>
      I can easily access value[0] without issues, but then I try and extract the href from value[1] I get an error when I debug
      event.itemRenderer.data.value[1].subjectIndicatorRef.l:href = <errors during evaluation>
      [Compiler] Error #1084: Syntax error: expecting rightparen before colon
      The namespace 'l' along with the colon is the variable name. How can I either remove the namespace or reference the href variable without the colon being a problem?
      I apologize if this is a problem I've created myself by using an ArrayCollection rather than some other XML type object but when I did that I couldn't access the value using square brackets [] in my dataProvider/DataGrid
      Thank you for any advice.
