10 Replies Latest reply on Dec 12, 2011 5:10 PM by armandix
    how can I do to each Node declared a "menu" show all its children nodes in a dynamic way?
    armandix Level 1
      I develop a piece of code that brings me to an xml, all Nodes i use this code:
      for(var i=0; i< menu_xml.childNodes.length; i++){
      corrent_node = menu_xml.childNodes[i].length;
      corrent_item.action = corrent_node.attributes.action;
      corrent_item.variables = corrent_node.attributes.variables;
      corrent_item.name.text = corrent_node.attributes.name;
      The following xml is returned
      <menu name='Autonomous Photovoltaic Systems'>
           <item name='Autonomus Photovoltaic Systems' action='' variables='SI-SIA'/>
      </menu>
      <menu name='Indoor lighting'>
           <item name='LED 10W' action='' variables='IN-LED'/>
           <item name='LED 3W' action='' variables='IN-LED'/>
           <item name='LED 6W' action='' variables='IN-LED'/>
      </menu>...
      What I need is for each of the nodes highlighted in green to return the child Nodes.
      Example: when I move the mouse over the menu Indoor lighting, the results should be: Indoorlighting | LED 10W> 3W LED> LED 6W
        • 1. Re: how can I do to each Node declared a "menu" show all its children nodes in a dynamic way?
          you should be using something like the following to define corrent_node.  it's not clear what the other left-sides of the assignment operators are.
          corrent_node = menu_xml.childNodes[i].firstChild;
          • 2. Re: how can I do to each Node declared a "menu" show all its children nodes in a dynamic way?
            armandix Level 1
            Kglad can you help me with this ? I can not do.
            First I call the Main Nodes with this code
            where do I add a movieclip and give him a position, in x and y then I compare the attributes with my variables
            corrent_item = corrent_menu.attachMovie("menuit","menu"+i+"_mc", i);
                                corrent_item._x = x + i*corrent_item._width;
                                corrent_item._y = y;
                                //properties from the XML
                                corrent_node = menu_xml.childNodes[i];
            Now that I set for each nodename equal "menu"
            if (menu_xml.childNodes[i].nodeName == "menu"){
            this is my problem Kglad how do I load the nodes of each "menu" please help me!!
            • 3. Re: how can I do to each Node declared a "menu" show all its children nodes in a dynamic way?
              for(var j:Number=0;j<corrent_node.childNodes.length;j++){
              trace(corrent_node.childNodes[j].attributes.name);
              • 4. Re: how can I do to each Node declared a "menu" show all its children nodes in a dynamic way?
                armandix Level 1
                Kglad
                I changed the code, using that one you sent me
                                    //um movie clip para cada item de menu
                                    //attacheMovie(agrega o movieclip da livraria, novo nome dado pelo utilizador, ++ incremento);
                                    // propriedades provenientes do XML
                                    //open a submenu
                                              corrent_item.node_xml = corrent_node.childNodes[j].attributes.name;
                                              corrent_item.onRollOver = corrent_item.onDragOver  = function(){
                                              /*submenu positions */
                                              var px = this._x;
                                              var py = this._y + this._height +2;
                                               trace(corrent_menu);
                                               trace(corrent_item);
                                              //generate submenu
                                              gerar_menu(corrent_menu, "submenu_mc", px, py, 1000, this.menu_xml);
                                              var cor =new Color(this.background);
                                              cor.setRGB(0x767676);
                But when I call the nodes children, he continues to make the same error reproduce de same main menu many times
                what I wanted was for each of the main menu items, call the child Nodes
                • 5. Re: how can I do to each Node declared a "menu" show all its children nodes in a dynamic way?
                  i showed how to parse your xml.
                  but i don't know everything else you're trying to do and from the looks of the code you've posted, and your lack of explanation, i think someone will need to download your source files and correct them for you.
                  • 6. Re: how can I do to each Node declared a "menu" show all its children nodes in a dynamic way?
                    armandix Level 1
                    Kglad if I send you the files you fix them myself?
                    • 7. Re: how can I do to each Node declared a "menu" show all its children nodes in a dynamic way?
                      i don't download and fix files unless i'm hired.
                      free help i only offer via the adobe forums.
                      • 10. Re: how can I do to each Node declared a "menu" show all its children nodes in a dynamic way?
                        armandix Level 1
                        this post is solved,
                        if someone need the code plese contact me
