2 Replies Latest reply on Dec 8, 2011 11:55 AM by kh40s z3r0
    Connection problem flex 4, blaze ds and java with spring annotations
    kh40s z3r0
      Hi, i wrote a very simple application with java that i need to connect with a flex application, to this connection i use blazeds and spring annotations
      and when i try to make the connection with flex, i get this error and i have been looking for and answer in internet, i have been doing tutorial but rigth now i don´t know  what´s the problem yet.
      the error is:
      [MessagingError message='Destination 'IndicadorCitaMedicaService' either does not exist or the destination has no channels defined (and the application does not define any default channels.)']
      Couldn't establish a connection to 'IndicadorCitaMedicaService'
      My web.xml  is:
      <!-- servlet para cargar el contexto de spring -->
      <servlet>
      <servlet-name>dispatcherServlet</servlet-name>
      <servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
      <load-on-startup>1</load-on-startup>
      </servlet>
      <!-- begin rds -->
      <servlet>
      <servlet-name>RDSDispatchServlet</servlet-name>
      <servlet-class>flex.rds.server.servlet.FrontEndServlet</servlet-class>
      <init-param>
      <param-name>messageBrokerId</param-name>
      <param-value>_messageBroker</param-value>
      </init-param>
      <init-param>
      <param-name>useAppserverSecurity</param-name>
      <param-value>false</param-value>
      </init-param>
      <load-on-startup>10</load-on-startup>
      </servlet>
      <servlet-mapping id="RDS_DISPATCH_MAPPING">
      <url-pattern>/CFIDE/main/ide.cfm</url-pattern>
      </servlet-mapping>
      <servlet-mapping>
      <url-pattern>/messagebroker/*</url-pattern>
      </servlet-mapping>
        • 1. Re: Connection problem flex 4, blaze ds and java with spring annotations
          kh40s z3r0 Level 1
          my dispatcherServlet-servlet.xml is:
          <flex:message-broker>
          <flex:remoting-service default-channels="my-amf" />
          </flex:message-broker>
          <context:annotation-config />
          <context:component-scan base-package="mx.....indicadores" />
          my services-config.xml is:
          <services>
          <service-include file-path="remoting-config.xml" />
          </services>
          <security />
          <channels>
          <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
          <endpoint
          url="http://{server.name}:{server.port}/{context.root}/messagebroker/amf"
          class="flex.messaging.endpoints.AMFEndpoint" />
          </channel-definition>
          </channels>
          <logging>
          <target class="flex.messaging.log.ConsoleTarget" level="Info">
          <properties>
          <prefix>[BlazeDS] </prefix>
          <includeDate>false</includeDate>
          <includeTime>false</includeTime>
          <includeLevel>false</includeLevel>
          <includeCategory>false</includeCategory>
          </properties>
          <filters>
          <pattern>Endpoint.*</pattern>
          <pattern>Service.*</pattern>
          <pattern>Configuration</pattern>
          </filters>
          </target>
          </logging>
          • 2. Re: Connection problem flex 4, blaze ds and java with spring annotations
            kh40s z3r0 Level 1
            my remoting-config.xml is:
            <adapters>
                    <adapter-definition id="java-object"
                                             class="flex.messaging.services.remoting.adapters.JavaAdapter"
                                             default="true"/>
                </adapters>
                <default-channels>
                    <channel ref="my-amf"/>
                </default-channels>
            my java class is this:
            @Service("IndicadorCitaMedicaService")
            @RemotingDestination(channels = {"my-amf"})
            public class BSIndicadores implements IBSIndicadores {
            @RemotingInclude
            public String sayHello(){
            return "Hello world from Flex";
            and the mxml is:
            xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:services="services.*">
            <fx:Script>
            <![CDATA[
            import mx.controls.Alert;
            import mx.events.FlexEvent;
            protected function form_creationCompleteHandler(event:FlexEvent):void
            sayHelloResult.token = indicadorCitaMedicaService.sayHello();
            </fx:Script>
            <fx:Declarations>
            <services:IndicadorCitaMedicaService id="indicadorCitaMedicaService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
            <s:CallResponder id="sayHelloResult"/>
            </fx:Declarations>
            <mx:Form id="form" creationComplete="form_creationCompleteHandler(event)">
            <mx:FormItem label="SayHello">
            <s:TextInput id="sayHelloTextInput" text="{sayHelloResult.lastResult as String}"/>
            </mx:FormItem>
            </mx:Form>
            </s:Application>
