0 Replies Latest reply on Dec 8, 2011 9:35 PM by depath
    Does Adobe Application Modeling plug-in work for Eclipse 3.7
    depath
      I Installed Flex 4.6 plugin in Eclipse 3.7
      later
      I installed the Adobe Application Modeling plug-in(listed for Eclipse 3.5 For Eclipse 3.5 Download) but could not view the Data Model perspective
      It throws an error
      Could not create the view:An unexpected execption was thrown
      java.lang.NullPointerException
                at com.adobe.model.design.editor.FiberTabbedPropertySheetPage.updateSelectedObjectHolder(Fib erTabbedPropertySheetPage.java:79)
                at com.adobe.model.design.editor.FiberTabbedPropertySheetPage.<init>(FiberTabbedPropertyShee tPage.java:109)
                at com.adobe.model.design.editor.FiberDesignEditor.getAdapter(FiberDesignEditor.java:402)
                at com.adobe.model.editor.FiberXMLEditor.getAdapter(FiberXMLEditor.java:2125)
                at org.eclipse.ui.internal.views.ViewsPlugin.getAdapter(ViewsPlugin.java:103)
                at org.eclipse.ui.views.properties.PropertySheet.doCreatePage(PropertySheet.java:206)
                at org.eclipse.ui.part.PageBookView.createPage(PageBookView.java:408)
                at org.eclipse.ui.part.PageBookView.partActivated(PageBookView.java:751)
                at org.eclipse.ui.views.properties.PropertySheet.partActivated(PropertySheet.java:325)
                at org.eclipse.ui.part.PageBookView.showBootstrapPart(PageBookView.java:920)
                at org.eclipse.ui.part.PageBookView.createPartControl(PageBookView.java:491)
                at org.eclipse.ui.views.properties.PropertySheet.createPartControl(PropertySheet.java:156)
                at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:375)
                at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:229)
                at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
                at org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActive(WorkbenchPage.java:4218)
                at org.eclipse.ui.internal.WorkbenchPage$18.runWithException(WorkbenchPage.java:3277)
                at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
                at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
                at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
                at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
                at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
                at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
                at org.eclipse.ui.internal.Workbench$31.runWithException(Workbench.java:1567)
                at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
                at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
                at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
                at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
                at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
                at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
                at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                at java.lang.reflect.Method.invoke(Unknown Source)
                at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
                at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
                at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
