3 Replies Latest reply on Dec 9, 2011 9:31 AM by Deadmaxx2011
    Rendering Issue with Premiere Pro CS5
    Deadmaxx2011
      I'm having a problem with Premiere Pro CS5 when I render anything with the 'Video Transitions' between two sources. I have a 10 sec file I'm trying to render and at 7 sec I have one source change to something else. When I go to render it, it gets to the spot where the 'video transition' is and the video render completes... when I go to play it back, the video cuts off RIGHT after transition completes so my video is only 8 sec long instead of 10 sec. If I remove the transition effect the file will render fine with no problems, and it doesn't seem to matter which transition I choose as well. Any help would be great, thanks.
      Brian Blake
