I'm trying to get the Mac OSX Hello World example working with Flex SDK 4.6.0. I've changed over all of the places where it has 4.5.1/ etc, got the XCode project to compile properly, but I've got stumped on a problem on step 3. The output I get at the end of step 3 is:
+ '/Applications/Adobe Flash Builder 4.6/sdks/4.6.0/bin/adt' -package -storetype PKCS12 -keystore src/assets/test.pfx -storepass none -target ane airrt.ane src/extension.xml -swc src/assets/com.airrt.extensions.swc -platform MacOS-x86 -C src/assets/platform/mac .
Invalid swc file. The extension NameSpace requires the SWF verison to be 13 or lower.
/Users/owenbennett/Documents/Projects/Flash/Native Extensions OSX/NativeExtensions
Any ideas?
Owen
Nevermind,
Figured it out. Here are the steps I followed, using Flex SDK 4.6.0 and XCode 4.1:
1. 00 - create cert -> go.sh and 01 - create swc -> go.sh and 03 - create ane -> go.sh and 04 - create dmg -> go.sh and 05 - run on adl -> go.sh and goall.sh
change
FLEX_SDK=/Applications/Adobe\ Flash\ Builder\ 4.5/sdks/4.5.1-air3.0
to
FLEX_SDK=/Applications/Adobe\ Flash\ Builder\ 4.6/sdks/4.6.0
2. 02 - create platform extension -> mac -> TestNativeExtension -> TestNativeExtension.xcodeproj
open the project in
...Copy link to clipboard
Nevermind,
change
to
open the project in XCode, select the project root, then TARGETS -> TestNativeExtension -> Build Settings
change Search Paths -> Framework Search Paths
Debug: "$(SYSTEM_APPS_DIR)/Adobe Flash Builder 4.5/sdks/4.5.1-air3.0/runtimes/air/mac"
Release: "$(SYSTEM_APPS_DIR)/Adobe Flash Builder 4.5/sdks/4.5.0-air3.0/runtimes/air/mac"
to
Debug: "$(SYSTEM_APPS_DIR)/Adobe Flash Builder 4.6/sdks/4.6.0/runtimes/air/mac"
Release: "$(SYSTEM_APPS_DIR)/Adobe Flash Builder 4.6/sdks/4.6.0/runtimes/air/mac"
If you want to check it's building OK, make sure to change the target (at the top by the run button) to TestNativeExtension > My Mac 32-bit
3. 03 - create ane -> src -> extension.xml
change
<extension xmlns="http://ns.adobe.com/air/extension/2.5">
to
<extension xmlns="http://ns.adobe.com/air/extension/3.1">
4. 04 - create dmg -> src -> NativeExtensionTest-app.xml and 04 - create dmg -> src -> assets -> NativeExtensionTest-app.xml and 05 - run on adl -> src -> NativeExtensionTest-app.xml
change
<application xmlns="http://ns.adobe.com/air/application/3.0">
to
<application xmlns="http://ns.adobe.com/air/application/3.1">
and that should build for you!
Owen
