2 Replies Latest reply on May 28, 2008 12:54 PM by Peter Grainge
    Multiple Versions
    HockeyTime
      Quick question. Can multiple versions of RoboHelp HTML (v5 and v7) be run on the same machine? If so, can I switch back and forth between versions?
        • 1. Re: Multiple Versions
          This question does not relate to the Webhelp output so should be under General Discussion. Leave it now though.
          They can as long as both licences are full versions but not if 7 is an upgrade. Also not if you want to use RH for Word. That does not stop you using RH HTML to generate Word outputs or import from Word.
          • 2. Re: Multiple Versions
            To complete that answer...
            You cannot work on the same project in both versions. You cannot use a version of Word higher than 2003 with X5 and using more than one version of Word can be interesting!
