1 Reply Latest reply on Oct 22, 2013 1:00 PM by Josh_2013
    Android native extention errors
    frank_aq Level 1
      Hi Everyone,
      I'm currently working on creating an Android ANE for native alert popups. I'm now at the point where I think my both my Java and AS3 code is good to go but I'm getting an error when I try to use it.
      Main Thread (Suspended: TypeError: Error #1009: Cannot access a property or method of a null object reference.)
      My problem is I'm really not sure where this error is coming from. My thinking is that I'm not building the ANE file correctly or something is wrong in my extension.xml file but I'm really not too sure.
      I'm going to try to provide as much information as I can about how this project is set up. Right now I'm trying to use this ANE in a small, testing application.
      First, the folder setup:
      ANEextensions-
           Alert_Java (holding my Java project)
                (Android/Java created assets. Not sure if these are important or now. If so I will list them)
                src
                     com
                          fa
                               ne
                                    android
                                         AlertContext.java
                                         AlertExtension.java
                                         ShowAlert.java
           Alert_AS
                bin
                     AlertAndroidAS.swc
                src
                     Alert.as
                     extension.xml
      I'm not going to bother posting my java code as I think it's correct. but if anyone who is willing to invest some time in helping me with this issue wants to take a look please let me know.
      This is my extensions.xml file
      <extension xmlns="http://ns.adobe.com/air/extension/2.5">
      <id>com.fa.alerts</id>
      <versionNumber>1.0</versionNumber>
          <platforms>
              <platform name="Android-ARM">
                  <applicationDeployment>
                      <nativeLibrary>AndroidAlert.jar</nativeLibrary>
                      <initializer>com.fa.ne.android.AlertExtension</initializer>
                      <finalizer>com.fa.ne.android.AlertExtension</finalizer>
                  </applicationDeployment>
              </platform>
          </platforms>
      </extension>
      And this is my Alert.as file:
      package {
          import flash.events.EventDispatcher;
          import flash.external.ExtensionContext;
          public class Alert extends EventDispatcher{
              public static var extContext:ExtensionContext = null
              public function Alert(){
                  super();
                  extContext = ExtensionContext.createExtensionContext("com.fa.alerts", null);
              public static function androidAlert(aTitle:String, aMsg:String, aNeg:String = "Cancel", aPos:String = "Ok"):void{
                  extContext.call("showAlert", aTitle, aMsg, aNeg, aPos);
      And this is my stub app I'm using to test
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:s="library://ns.adobe.com/flex/spark" title="HomeView">
          <fx:Script>
              <![CDATA[
                  protected function spawnAne(event:MouseEvent):void{
                      var a:Alert = new Alert();
                      Alert.androidAlert("test","testing");
          </fx:Script>
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:Button click="spawnAne(event)" />
      </s:View>
      Now clicking on that button is what causes the error.
      I don't have any kind of swc or link between my testing app and the AS3 Alert_AS project. I'm using Flash Builder 4.6 to import the ANE file using the IDE tools.
      To build my ANE I'm using a lightly modified bash script from this post: http://gotoandlearn.com/play.php?id=149 by Lee Brimelow
          # path to YOUR Android SDK
          export AIR_ANDROID_SDK_HOME="my sdk"
          # path to the ADT tool in Flash Builder sdks
          ADT="my adt"
          # native project folder
          NATIVE_FOLDER=Alert_Java
          # AS lib folder
          LIB_FOLDER=Alert_AS
          # name of ANE file
          ANE_NAME=AndroidAlert.ane
          # JAR filename
          JAR_NAME=AndroidAlert.jar
          # cert path
          CERT_NAME=cert.p12
          # cert password
          CERT_PASS=password
          echo "****** preparing ANE package sources *******"
          rm ${ANE_NAME}
          rm -rf ./build/ane
          mkdir -p ./build/ane
          mkdir -p ./build/ane/Android-ARM
          mkdir -p ./build/ane/Android-ARM/res
          # copy resources
          cp -R ./${NATIVE_FOLDER}/res/* ./build/ane/Android-ARM/res
          # create the JAR file
          jar cf ./build/ane/Android-ARM/${JAR_NAME} -C ./${NATIVE_FOLDER}/bin .
          # grab the extension descriptor and SWC library
          cp ./${LIB_FOLDER}/src/extension.xml ./build/ane/
          cp ./${LIB_FOLDER}/bin/*.swc ./build/ane/
          unzip ./build/ane/*.swc -d ./build/ane
          mv ./build/ane/library.swf ./build/ane/Android-ARM
          echo "****** creating ANE package *******"
          "$ADT" -package -storetype PKCS12 -keystore ./cert.p12 -storepass password -tsa none \
              -target ane \
              ${ANE_NAME} \
              ./build/ane/extension.xml \
              -swc ./build/ane/*.swc \
              -platform Android-ARM \
              -C ./build/ane/Android-ARM/ .
          echo "****** ANE package created *******"
      I know this is a bit long but any help would be greatly appreciated! And feel free to let me know if you need some more elaboration
