5 Replies Latest reply on Dec 11, 2011 10:40 PM by AlastairJMoore
    Custom components and the navigator object
    AlastairJMoore
      Hi all,
      I'm starting on a mobile project which is a ViewNavigator based application. I've created a custom component which contains a button. I'd like the button to be able to use the pushView method however as it's a custom component, it doesn't appear to recognise the navigator object. If anyone has any advice/tips on how I might go about this, it'd be greatly appreciated!
        • 1. Re: Custom components and the navigator object
          Flex harUI Adobe Employee
          The button is a custom component or the view is?  What line of code causes and error and what is the error?
          • 2. Re: Custom components and the navigator object
            AlastairJMoore Level 1
            The button sits in a custom component - actually in a datarenderer. Code looks like:
            <s:DataRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                    xmlns:s="library://ns.adobe.com/flex/spark">
              <fx:Script>
                                <![CDATA[
                                          import mx.utils.ObjectUtil;
                                          protected function button1_clickHandler(event:MouseEvent):void
              </fx:Script>
              <fx:Declarations>
              </fx:Declarations>
                      <s:Button label="{data.firstName}" click="button1_clickHandler(event)" width="150" height="150" />
            </s:DataRenderer>
            which is being called from a View. There's no error, I'm simply unable to/unsure how to access the navigator object so I can push a new view onto the stack from within that component.
            Cheers!
            • 3. Re: Custom components and the navigator object
              One of the reasons it isn’t obvious is because it isn’t recommended.
              The clickHandler should probably just dispatch a custom event from the owner, which should be the containing component.
                  owner.dispatchEvent(new Event(“buttonInRendererClick”));
              Then the document containing the component, which is more likely to be a navigator, determines what to do.
              • 4. Re: Custom components and the navigator object
                Ah great stuff. That's even more useful! Thanks very much! I'll try it out.
                Ok, that's not quite working although I guess it's because I'm having the incorrect "owner" try and fire off an event. When I do a trace('owner'), the console reports:
                Main0.ViewNavigatorApplicationSkin2.navigator.ViewNavigatorSkin4.contentGroup.Friends115.S kinnableContainerSkin118.contentGroup._Friends_DataGroup1
                Is there a quick method to get to the view rather than something like owner.parent.parent.parent (etc.)?
                • 5. Re: Custom components and the navigator object
                  It could well be the case I'm going about this the wrong way But apart from this issue, it appears to be working.
