When I run the Flash Installer, it consistantly stops at 12% with the message "Download timeout". I have already uninstalled my older version of Flash. I have check all of the obvious solutions and need to install Flash for my IE8.
lew
Win XP 32-bit
IE8
Dial-up Connection
See solution in this post: http://forums.adobe.com/message/4075640#4075640 (Press the "End" key to jump to the bottom of the page)
If you have neither of the security apps mentioned, look for a similar option to disable the file shield scanner.
Message was edited by: Xircal
I'm also having this 12% timeout problem. I have disabled Norton 360 anti-virus and firewall to no avail. I previiously has a 10 version of Flash which worked perfectly-but had to uninstall it in order to load 11. Now I have nothing. Any ideas?
Dell Inspiron
IE8
XP32
dsl
Thank you so much, Xircal. That did the trick. It was an unchecked box in my AVG. I never connected the wording "timeout" with the security shield.
You're welcome.
