2 Replies Latest reply on Dec 12, 2011 11:53 AM by thiagollo
    TextInput in List
    thiagollo Level 1
      Hello,
      I have a list with textInput on my mobile project (flex 4.6). But seems to be a crazy behavior on list.
      When i set the value on textInput i take the event normally, but when i scroll the list the value appear on others text input... see the images and the code below:
      1. List with textInput:
      2. The code for that (iconItemRenderer):
      <componentes:IconItemRendererCustomizado xmlns:fx="http://ns.adobe.com/mxml/2009"
                          xmlns:componentes="componentes.*"
                          labelField="nomeFormatado" messageField="mensagem"
                          fontSize="24" messageStyleName="myFontStyle"
                          iconHeight="72" iconWidth="72"
                          dataChange="iconitemrenderercustomizado1_dataChangeHandler(event)"
                          initialize="iconitemrenderercustomizado1_initializeHandler(event)">
          <fx:Script>
              <![CDATA[
                  import mx.events.FlexEvent;
                  import spark.components.Application;
                  import spark.components.NavigatorContent;
                  import spark.components.TextInput;
                  import spark.events.TextOperationEvent;
                  import spark.layouts.HorizontalAlign;
                  import spark.skins.mobile.TextInputSkin;
                  import vo.ProdutoVO;
                  [Bindable]
                  private var txtQtd:TextInput;
                  protected function iconitemrenderercustomizado1_dataChangeHandler(event:FlexEvent):void
                      if(data.arquivo != null) {
                          var loader:Loader = new Loader();
                          loader.contentLoaderInfo.addEventListener(Event.COMPLETE, setIcon);
                          loader.loadBytes(data.arquivo);
                  private function setIcon(event : Event) : void {
                      var info:LoaderInfo = LoaderInfo(event.target);
                      var b : Bitmap = Bitmap(info.loader.content);
                      icone = b.bitmapData;
                      createIconDisplay();
                  private var i:int = 0;
                  protected function iconitemrenderercustomizado1_initializeHandler(event:FlexEvent):void
                      if (!txtQtd) {
                          txtQtd = new TextInput();
                          txtQtd.id = "txt" + i++.toString();
                          txtQtd.width = 70;
                          txtQtd.height = 40;
                          txtQtd.x = this.parent.width-90;
                          txtQtd.y = 25;
                          txtQtd.maxChars = 4;
                          txtQtd.setStyle("skinClass", spark.skins.mobile.TextInputSkin);
                          txtQtd.softKeyboardType = SoftKeyboardType.NUMBER;
                          txtQtd.addEventListener(TextOperationEvent.CHANGE, verificarProduto);
                          this.addChild(txtQtd);
                  override public function set data(value:Object):void
                      if(value != null)
                          super.data = value;
                          if ( value.quantidade > 0) {
                              txtQtd.text = value.quantidade;
                  protected function verificarProduto(event:TextOperationEvent):void
                      ProdutoVO(this.data).quantidade = parseInt( txtQtd.text );
                      if (txtQtd.text != "" && txtQtd.text != "0") {
                          // adiciona ao pedido
                          SFAUtils.getInstance().adicionarProdutoAoPedido(
                              ProdutoVO(this.data),
                              SFA(parentApplication).pedido,
                              SFA(parentApplication).usuario);
                      } else {
                          //remove do pedido, quantidade vazia ou zero
                          SFAUtils.getInstance().removerProdutoDoPedido(
                              SFA(parentApplication).pedido)
          </fx:Script>
      </componentes:IconItemRendererCustomizado>
      3. The value strange behavior:
      Any suggestions what could be????
        • 1. Re: TextInput in List
          Shongrunden Adobe Employee
          I haven't looked very closely at your code, but did notice this:
                          if(value != null)
                              super.data = value;
          If you remember to clear the textinput value when its not > 0 does that help?
                          if(value != null)
                              super.data = value;
                              else {
                                   txtQtd.text = "";
          • 2. Re: TextInput in List
            thiagollo Level 1
            Right there!!!!
            This is a very simple error and i dont even saw.
            Thank you!
