1 Reply Latest reply on Dec 13, 2011 5:40 AM by Pooja Kuber
    Problem splitting a string
    Zolotoj Level 3
      I am having a problem splitting a string.
      Here is my code:
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                     creationComplete="init()"
                     xmlns:s="library://ns.adobe.com/flex/spark">
          <fx:Script>
              <![CDATA[
                  private var helper1:Helpers;
                  private function init():void
                      helper1 = new Helpers();
          </fx:Script>
          <s:layout>
              <s:VerticalLayout/>
          </s:layout>
          <s:HGroup>
              <s:Panel id="Panel1"
                       height="100" width="100"
                       title="Panel 1">
                  <s:Button id="setCB"
                            click="helper1.getChildFromPath(this, 'abc.123')"/>
              </s:Panel>
          </s:HGroup>
      </s:Application>
      package
          import flash.display.DisplayObject;
          import flash.display.DisplayObjectContainer;
          public class Helpers
              public function Helpers()
              public function getChildFromPath(base:DisplayObjectContainer, path:String):void
                  var pathAsArr:Array = path.split(".");
                  // here pathAsArr.length is zero.
      Any idea?
        • 1. Re: Problem splitting a string
          Pooja Kuber
          Hi Zolotoj,
          The code running fine for me. Its splitting the values and thus the array length coming out as 2.
          I followed the following steps:
          Ran the application
          Clicked on the button
          traced the pathAsArr variable
          Is there other test case? Please let me know will try to find out the solution for your issue.
          Thanks and Best regards,
          Pooja Kuber | pkuber@infocepts.com | www.infocepts.com
