3 Replies Latest reply: Dec 12, 2011 3:57 PM by Pak762 RSS
    Parameter register problem?
    Pak762 Community Member
      iam trying to set some parameters of my fragmentshader. First I used the ProgramConstantHelper but it simply is to slow to use in the final program.
      After some errors I couldnt figure out how setting the parameters with setProgramConstantsFromVector works, better said, I did not know which registers I have to set. To find that out I first inspected some values in the debugger and than wrote a little code giving me this output.
      [object BombExplosionShader]
      FragmentParameter: color startRegister: 1 offset: 0
      FragmentParameter: size startRegister: 1 offset: 3
      FragmentParameter: fposition startRegister: 2 offset: 0
      FragmentParameter: resolution startRegister: 2 offset: 2
      FragmentParameter: strength startRegister: 3 offset: 0
      FragmentParameter: thickness startRegister: 3 offset: 1
      first I thought every parameter has its own register, but I was wrong. If the compiler is able to put some parameters into one register, it does.
      this is the code to set the parameters of the vector:
      this.m_parameters[0]= colorR;
      this.m_parameters[1]= colorG;
      this.m_parameters[2]= colorB;
      this.m_parameters[3]= size;
      this.m_parameters[4]= posX;
      this.m_parameters[5]= posY;
      this.m_parameters[6]= resX;
      this.m_parameters[7]= resY;
      this.m_parameters[8]= strength;
      this.m_parameters[9]= thickness;
      The vector is generated with: new Vector.<Number>(12, true);
      and this is the call of setProgramConstantsFromVector:
      this.m_context3D.setProgramConstantsFromVector(Context3DProgramType.FRAGMENT, 1, this.m_parameters);
      can someone tell me what is wrong with the code?
