1. Re: Popular request: How to Share articles via Facebook/twitter/eMail
JulienKraakman May 5, 2012 6:02 AM (in response to Johannes Eckert)Hi Johannes,
Thanks a lot, it is very helpful!
I actually wouldn't be posting here if I wouldn't have a problem with it though.
The thing is, I can't get it to work!
So to clear things up here is my HTML code I'm trying to get working on an InDesign document (based on your HTML 5 template - Facebook like button code within the "body" tag):
<!DOCTYPE html>
HTML5-1file-framework for use in Digital Publishing Suite from Adobe
v0.2-110224 (Tested with drop9)
http://digitalpublishing.tumblr.com
<html laneg="en">
<head>
<!-- title not visible in the viewer unless viewed with a browser / popup -->
<title>HTML5 Framework for DPS</title>
<meta charset="utf-8" />
meta viewport tag
this tag controls the rendering of the html on the devices. it might be handled differntly
between iOS/Android, so be carefull. this is a complete example tag. change for your needs or omit completly.
-Pagination of HTML stacks: omit completly or do not use user-scalable and target-densitydpi
-PinchZoom: use "Scale Content to Fit" in InDesign and use maximum-scale greater than 1.0, do not use user-scalable=no
<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no, target-densitydpi=device-dpi"/>
<!-- your document css -->
<style type="text/css">
/* basic css reset */
body {
margin: 0;
padding: 0;
/* make WebOverlay transparent in InDesign: "Use Transparent Background" */
/* use following line for semi-transparent-background (fourth value is alpha value) */
/* background: rgba(50,150,250,0.5); */
/* your css styles here */
</style>
</head>
<body>
<div id="fb-root"></div>
<script>(function(d, s, id) {
var js, fjs = d.getElementsByTagName(s)[0];
if (d.getElementById(id)) return;
js = d.createElement(s); js.id = id;
js.src = "//connect.facebook.net/nl_NL/all.js#xfbml=1";
fjs.parentNode.insertBefore(js, fjs);
}(document, 'script', 'facebook-jssdk'));</script>
<div class="fb-like" data-href="http://www.website.com/" data-send="true" data-width="450" data-show-faces="true" data-font="tahoma"></div>
</body>
</html>
What I do:
I create an empty frame in my InDesign document.
In the overlay creator I tell it to be a Web Content.
I select the HTML file containing above code.
I update the article in the Folio Builder and test it on the iPad.
The result is actually... nothing. The area in which the frame is, displays a small loading wheel and after that it's totally empty.
What am I doing wrong??
Thanks.
