1 Reply Latest reply: Jan 6, 2012 10:59 PM by Kim Isola RSS
    Snap to grid and aligning objects
    _Gosherm_ Community Member
      Is there a way to get horizontal snap to work? It's close, but not close enough to fool the eye. I've got two DIV blocks, one located at x=720, the other at x=721, and I cannot get them on the same x no matter what I try. Help?
        • 1. Re: Horizontal Snap?
          Kim Isola Employee Hosts
          Hi Gosherm,
          A couple of things might help:
          Do you have Snap to Grid turned on? You can find it under the Grid menu:
          Also, here's a tip for aligning the sides of two objects:
          1. Tap to select your first object; then tap and hold on the center handle of the side you want to align the second object to:
          2. Continue to hold, and use another finger to tap the second object. The second object then aligns to the first:
          Let us know if this doesn't work for you. Thanks for posting!
