20 Replies Latest reply: Sep 26, 2012 7:23 AM by Bill Gehrke RSS
    Ram Disk or Ram Cache?
    Rkenosha Community Member
      Hi, everyone. In my new build I am using 64 gig or memory. Has anyone used and found it helpful to use ram disk or ram cache for PPro or AE? If so what did you use to create the disk or cashe. Thanks Roman
        • 1. Re: Ram Disk or Ram Cache?
          wonderspark Community Member
          The problem with RAMdisks on Premiere or After Effects is that it has to be set up before launching the programs, so it's a pain. You have to create the RAMdisk, then launch PPro or AE, assign it as the scratch, and then relaunch. If you reboot, that ramdisk is gone, right? Then you have to remake it before you relaunch PPro or AE, otherwise it will say "I don't have the scratch disk, so I'm going to use space on your C: drive / home directory." (in so many words)
          I considered it, but I shut down every night, and don't feel like going through all that every day. I have a nice little script that makes ramdisk creation that much easier, but just couldn't be bothered, since my RAID works pretty well already. I would love to hear your experiences if you try it. I might use one myself, if it makes a difference.
          • 2. Re: Ram Disk or Ram Cache?
            JEShort01 Community Member
            I tried a RAMDISK to speed up Premiere CS5 for times when the 24GB of on-board RAM was not being fully utilized, however it just slowed things down.
            My suspicion is that Windows can use "unused" RAM for caching, etc. in ways very native to Windows and the RAMDISK setup with its associated overhead is less effective.
            Jim
            • 3. Re: Ram Disk or Ram Cache?
              Crist OC/PC Community Member
              "If you reboot, that ramdisk is gone, right?"
              WRONG. Will work perfectly as a extra HDD. only 30 times faster
              Allready tested...
              • 4. Re: Ram Disk or Ram Cache?
                Dear Jim
                Will you tell me exactly how the Ramdisk Just slowed down thing for you? I'm doing several tests on my news 3930 and I´m really positive.
                My test.:
                20gb ram disk. work fantastic.
                Asus SSD CACHE, Reali not so exacting AS RAM cache is nearly the same but faster. SSD CACHE can be use only for 1 HDD, Ram cache can be aply in ON BOARD RAID, so I let you something to imagine...
                BTW did you try the Ram disk on your 970 or you got a new 39XX,
                When you set the ram cache or ran disk you don't have to be running a 32bit OS. It is very easy, you provably know that Right?
                I'm keep pushing the 3930 up in OC. as I start whit 2 identical pc both are using a corsair h100, and they are @ 4.7 with a very stable temp. I need a bit of time ti put them @ 5ghz which is my target, the I will publish result in the PPBM WITH AND WITHOUT OC and for sure will fine the must optimal  on board HDD config.
                Them later I will try my custom water cooling Sys where I spect +5ghz...
                • 5. Re: Ram Disk or Ram Cache?
                  Great, so you edit in Premiere and After Effects using a RAM disk, and no problems? Guess I'll try it myself. I only have 32GB, so I'll only make a 2GB RAM disk, saving 24GB for Adobe and 6GB for other processes.
                  • 6. Re: Ram Disk or Ram Cache?
                    SuperCache breaks the disk I/O bottleneck by using the computer's RAM to hold or contain the most frequently used disk data. This 'container' is referred to as a cache. With SuperCache, as a program sends and receives disk data, the most frequently used data is read from and written to RAM – not the hard drive – thus accelerating the program's performance. SuperCache implements our patented block-level cache technology to increase performance above that of the operating system’s file-level cache.
                    SuperCache is an excellent choice for these scenarios:
                    1. 1.
                    The data files are larger than available physical memory.
                    1. 2.
                    The data files are located on a disk partition or disk volume that is too large to fit into available physical memory, and cannot be moved to one where they will fit. (For example: Dragon Naturally Speaking v7.3 cannot be configured to place its data on a different drive.)
                    1. 3.
                    Minimum risk of lost data.
                    Unlike our RamDisk products not all the data will be available in RAM all the time. Some will come from the hard drive. Nonetheless, depending upon the size of the cache and the nature of the disk I/O demands, performance accelerations can be significant and often dramatic.
                    Deferred-write mode
                    By enabling its lazy-write mechanism, SuperCache can also accelerate writing data to disk. This mechanism delays writes to the hard drive. This can 'smooth out' I/O activity on the hard drive. It is important to note that enabling lazy-write increases the risk of data loss in the event of a system crash or power failure. SuperSpeed Software recommends that enabling the lazy-write feature ONLY on systems equipped with an Uninterruptible Power Supply (UPS).
                    SuperCache can be used to cache an entire system drive (e.g. drive C:) including the system pagefile. SuperCache is the appropriate choice when a particular program (e.g. database, game, etc.) needs to access very large amounts data.
                    Support for NUMA
                    Starting with Windows XP x64 through Wndows 7 x64 provides special support for machines with a non-uniform memory architecture (NUMA). When active on such platforms, the memory manager for SuperCache 5examines the processor and memory affinities reported by Windows and the ACPI SRAT, and then optimizes physical memory allocations across the described NUMA nodes. The NUMA support in SuperCache 5 greatly improves the speed of memory allocations and equalizes the distribution of cache allocations among the NUMA nodes. Currently, NUMA support does not include the ability to build caches on specific nodes.
                    New Interface
                    SuperCache 5 now has a more user friendly and informative interface.
                    • Overview of available storage drives in system
                    • Caching graph showing 4 performance items
                    • Configure SuperCache by right clicking a volume
                    • Automatic configuration of boot drive (usually C:) during installation.
                    Added Feature called "Mirror Mode"
                    SuperCache Mirror Mode (formerly a separate product called SuperVolume) allows the user to duplicate anentire volume/partition into RAM. Learn more about Mirror Mode.
                    Click here to download fully-functional trial software.
                    Quick start instructions:
                    There are two ways to configure SuperCache 5(SC5) either from Graphical User Interface(GUI) or via the Command Line Interface(CLI). SuperCache will be automatically enable on the boot volume (usually C:) if this option was selected during installation.
                    To configure or modify caching from the GUI
                    1) Double click the desktop icon.
                    2) Select a volume
                    3) Select either the first menubar icon OR Action -> Cache
                    - OR -
                    To access SC5 from the CLI
                    1) Open a Command Prompt with Administrative privileges
                    2) Type "vfcfg -help" will provide an overview of the command line syntax.
                    • 7. Re: Ram Disk or Ram Cache?
                      Cristo,
                      Good luck with the new build and testing; I'm looking forwards to your findings!
                      Regarding how I "tested" with a RAMDISK, it was by running PPBM5 multiple times using different configurations. For example, set up the RAMDISK and assign media cache and media cache DB to it, etc.
                      Realize too that I am using big, fast arrays already, and only had 24GB of total RAM to play with. On a 48GB system, things could have turned out very differently - my RAMDISK was about 10GB in size, whereas 48GB of RAM would have allowed for a 34GB RAMDISK partition. Bill Gehrke here told me about the program I used; it is called RAMdisk by Dataram.
                      Cheers,
                      Jim
                      • 9. Re: Ram Disk or Ram Cache?
                        @ the moment for me the super cache "RAM CACHE" is showing more cool. I leet you the link so you can try it as well and look the pic above.
                        http://www.superspeed.com/download/trialversions.php
                        Cheers
                        Cristobal
                        • 10. Re: Ram Disk or Ram Cache?
                          Bill Gehrke Community Member
                          Jim, I also found the 24 GB old limitation that RAMDisk was not much help.  Now that I have a 32 GB machine I guess I will have to try that but it will not be until after Christmas.  With 32 GB I can set a 14 GB RAMdisk (enough to hold all of the PPBM project and results) and get some data.  By the way just going from 16 GB to 32 GB improved my PPBM5.5 scpore by more than 5 seconds.
                          • 11. Re: Ram Disk or Ram Cache?
                            Well I squeezed the RAMdisk test in and could not find any improvement over the the testing of PPBM5.5 with 32 GB of RAM.  With the RAMdisk software set to allocate 14 GB to the RAMdisk and the remaining 18 GB used as regular RAM I got statistically the same results as I got running the test with 3 each 1 TB 7200 rpm drives in RAID 0.  Why did I use three drives?  My drives are the older 7200.12 Seagate drives so I wanted to emulate two of the newer ones when they again become cost effective.  The newer 1 TB/platter 64 MB cache Seagate drives are much faster but until hard drive get back to "normal" I have to improvise.
                            • 12. Re: Ram Disk or Ram Cache?
                              Jim I got a fantastic result. 115 sec aprox. And is not yet the final
                              tunning. I believe can make it 15% faster :). My pc is running just @ 4.8,
                              I'm sure I will rise 5.2 @ least.
                              Note.: I used a Gtx 275
                              • 13. Re: Ram Disk or Ram Cache?
                                Cristo,
                                Simply incredible!!! That is fantastic and quite interesting news indeed; and with a lowly GTX 275 no less .
                                Did you use any hard drives?
                                Was it CS5 or CS5.5?
                                Regards,
                                Jim
                                • 14. Re: Ram Disk or Ram Cache?
                                  Jim it was in PP 5.5, the suit is install on a SSD and project disk
                                  ramdisk. I have a lot of info to share, let me make mor test them I'll
                                  inform every one.
                                  • 15. Re: Ram Disk or Ram Cache?
                                    Studio North Films Community Member
                                    Looks very interesting,
                                    please foward further information once you have done more tests.
                                    • 16. Re: Ram Disk or Ram Cache?
                                      msvideo_uk Community Member
                                      What was the outcome of the RAM disk and SSD cache tests? Is there a config that is worthwhile for real world PPro project use?
                                      • 17. Re: Ram Disk or Ram Cache?
                                        mahinthan5 Community Member
                                        Why would you need it?
                                        I agree Ram is faster than SSD. But the cache / scratch or what ever will be used only once the RAM fills in any program. So when the system can automatically do the task why are you willing taking additional difficulties for same objective in different path? That's why no consumer os manufactures doesn't provide any utilities like this.
                                        If you feel the need of scratch / cache Install more Ram. There is no point doing this kind of Ram disk Drive for caching purpose. It is like taking the half of the avilable cache and keep it to acces in diffrent way.
                                        I will say the only need for Ram disk will be when ever you want to prolong the life time of SSD by routing the temp files on it. But i thing nowadays even that might not worth doing since SSD prices are falling
                                        If i am wrong in some thing educate me
                                        • 18. Re: Ram Disk or Ram Cache?
                                          Why do we need another cache scheme since Windows OS has already implemented a file-system level cache?
                                          • Some applications bypass the file-system level cache.
                                          • Windows caches all data, while FancyCache can cache on behalf of a specified volume/disk in which users are interested. Given same size of system memory, the latter has a higher hit-rate.
                                          • FancyCache can utilize the OS Invisible Memory on 32-bit Windows as a cache medium.
                                          • FancyCache can utilize SSD (Solid-state Drive) as a cache medium, as ReadyBoost does.
                                          • 19. Re: Ram Disk or Ram Cache?
                                            Fabio Pis Community Member
                                            Bill, are you sure for this?
                                            I am using supercache with a ram disk of 18 gb and PPBM fails with sheep sound on disk test.
                                            I have realized that ram is saturated by this test and i can't beat Cristobal PPBM5 result with "only" 32 gb installed on my system! :-)
                                            • 20. Re: Ram Disk or Ram Cache?
                                              Well I do not have time to repeat the test now as my 32 GB motherboard is involved with another project right now but I am positive of those results.  But for the RAM caching I was using Dataram RamDisk.
