8 Replies Latest reply on Dec 14, 2011 8:18 AM by kglad
    Drag and Drop axis lock
    JohnnyVee1945
      I am creating animations in Flash 5.5 for use in Captivate 5.5.  I have created a drag-and-drop animation for a horizontal line and a vertical line, to act as moveable "straight edges" for use on complicated charts.  How do I lock the horizontal line to just move along the Y axis, and the Vertical line to just move along the X axis?  (I'm a relative newbir working in Flash.)  Thanks for any help.
      John
        • 1. Re: Drag and Drop axis lock
          EvilBartek
          I never used flash for stuff like that but are you using scripts?
          • 2. Re: Drag and Drop axis lock
            are you using as2 or as3?
            • 3. Re: Drag and Drop axis lock
              JohnnyVee1945 Level 1
              I am using AS3 script.  Here is the code I have from a Flash "Snippet":
              /* Drag and Drop
              Makes the specified symbol instance moveable with drag and drop.
              movieClip_1.addEventListener(MouseEvent.MOUSE_DOWN, fl_ClickToDrag);
              function fl_ClickToDrag(event:MouseEvent):void
                  movieClip_1.startDrag();
              stage.addEventListener(MouseEvent.MOUSE_UP, fl_ReleaseToDrop);
              function fl_ReleaseToDrop(event:MouseEvent):void
                  movieClip_1.stopDrag();
              /* Click to Position an Object
              Moves the specified symbol instance to the x-coordinate and y-coordinate you specify.
              Instructions:
              1. Replace the value 200 with the x-coordinate
                 where you want to position the object.
              2. Replace the value 100 with the y-coordinate where you want to position the object.
              /* Drag and Drop
              movieClip_2.addEventListener(MouseEvent.MOUSE_DOWN, fl_ClickToDrag_2);
              function fl_ClickToDrag_2(event:MouseEvent):void
                  movieClip_2.startDrag();
              stage.addEventListener(MouseEvent.MOUSE_UP, fl_ReleaseToDrop_2);
              function fl_ReleaseToDrop_2(event:MouseEvent):void
                  movieClip_2.stopDrag();
              Hope this helps.  Thanks for your interest.
              John
              • 4. Re: Drag and Drop axis lock
                I am using AS3 code.  Here is what I have so far, from a Flash "Snippet":
                /* Drag and Drop
                Instructions:
                /* Drag and Drop
                John
                • 5. Re: Drag and Drop axis lock
                  which movieclip is your vertical line and which is horizontal?
                  • 6. Re: Drag and Drop axis lock
                    Clip 1 is the horizontal line that moves up and down in the Y axis, and clip 2 is the vertical line that moves side to side.
                    That said, I think what I really need is a bounding box, which will achieve the same end, but also keep the lines from going outside the window with the chart, and wandering over the rest of the stage.  I would need a bounding box of 729 wide by 369 high.
                    Thanks again.
                    John
                    • 7. Re: Drag and Drop axis lock
                      iFlashAppsToo Level 3
                      or you could try something like this:
                      movieClip_2.addEventListener(MouseEvent.MOUSE_DOWN, fl_ClickToDrag);
                      var mc:MovieClip;
                          mc = event.target;
                          stage.addEventListener(MouseEvent.MOUSE_MOVE, moveMe);
                      function moveMe(event:MouseEvent){
                          if(mc == movieClip_1){
                               mc.y = mouseY;
                          else{
                               mc.x = mouseX;
                          stage.removeEventListener(MouseEvent.MOUSE_MOVE, moveMe);
                          stage.removeEventListener(MouseEvent.MOUSE_UP, fl_ReleaseToDrop);
                      • 8. Re: Drag and Drop axis lock
                        use:
                        /* Drag and Drop
                            movieClip_1.startDrag(false,new Rectangle(0,0,0,stage.stageHeight));
                        Instructions:
                        /* Drag and Drop
                           movieClip_2.startDrag(false,new Rectangle(0,0,stage.stageWidth,0));
                        John
