1 Reply Latest reply on Dec 13, 2011 10:09 PM by Deeptika Gottipati
    FlashBuilder bar chart - data appears only outside chart range
    benn0034
      I'm relatively new to FlashBuilder development and I'm having some issues with a bar chart.  I'm try to create a chart to show the timeline of projects, each with a start and end date.
      (1) The actual bars appear only on the left side of the y-axis.
      (2) If I hover the mouse over the blank chart area, it shows a tip for the bar that is not visible (see screenshot).
      (3) The dates on the x-axis are in descending order and should be in ascending order.
      I would appreciate any help with any of these issues.  Thanks!
      Code to display the chart:
          <s:NavigatorContent id="navProjectChart" label="Project Chart">
              <mx:BarChart id="bcProjectChart" dataProvider="{chartData}"  left="2" top="40" width="710" includeIn="List" paddingRight="5" paddingLeft="5" showDataTips="true" type="clustered" height="505">
              <mx:horizontalAxis>
                  <mx:DateTimeAxis dataUnits="days" title="Timeline" parseFunction="parseDateStringToDate" />
              </mx:horizontalAxis>
              <mx:verticalAxis>
                  <mx:CategoryAxis categoryField="Name" />
              </mx:verticalAxis>
              <mx:series>
                  <mx:BarSeries xField="EndDate" minField="StartDate" fill="{sc1}" stroke="{s1}" />
              </mx:series>
          </mx:BarChart>
          </s:NavigatorContent>
          protected function parseDateStringToDate(s:String):Date
              var newDate:Date = DateFormatter.parseDateString(s);
              trace("Input string: "+s+", Parsed Date: "+newDate);
              return newDate;
        • 1. Re: FlashBuilder bar chart - data appears only outside chart range
          Deeptika Gottipati Adobe Employee
          Can you please send me a sample application at deeptika(at)adobe(dot)com?
          I used the following app and it seems to be working fine
          <?xml version="1.0"?>
          <!-- Simple example to demonstrate the BubbleChart control. -->
                         xmlns:mx="library://ns.adobe.com/flex/mx">
              <fx:Script>
                  <![CDATA[
                      import mx.collections.ArrayCollection;
                      import mx.formatters.DateFormatter;
                      [Bindable]
                      private var chartData:ArrayCollection = new ArrayCollection([
                          {Name: "A1", StartDate: new Date(2011,10,10), EndDate: new Date(2011, 11, 10)},
                          {Name: "A2", StartDate: new Date(2011,7,9), EndDate: new Date(2011, 10, 10)}
                          return newDate;
              </fx:Script>
                      <mx:horizontalAxis>
                          <mx:DateTimeAxis dataUnits="days" title="Timeline" />
                      <mx:verticalAxis>
                      </mx:verticalAxis>
                      <mx:series>
                          <mx:BarSeries xField="EndDate" minField="StartDate"  />
                      </mx:series>
                  </mx:BarChart>
          </s:Application>
          Deeptika
