19 Replies Latest reply on Dec 14, 2011 4:20 PM by kglad
    thumbnails problems
    melas076 Level 1
      dear all,
      I would like to know if you could tell me how to solve this issue for thumbnails.
      I want the 4th thumbnails will be on the second line and not on the 1st line....
      i will appreciate your help!
      Regards,
      MELAS
      this is my code :
      stop();
      function loadXML(loaded) {
      if (loaded) {
      xmlData = this.firstChild;
      links = [];
      description = [];
      thumbnails = [];
      a =[];
      total = xmlData.firstChild.childNodes.length;
      for (i=0; i<total; i++) {
      links[i] = xmlData.firstChild.childNodes[i].attributes.datas;
      description[i] = xmlData.firstChild.childNodes[i].attributes.label;
      thumbnails[i] = xmlData.firstChild.childNodes[i].attributes.thumbs;
      a[i] = xmlData.firstChild.childNodes[i].attributes.folder;
      thumbnails_fn(i);
      initPreloading();
      //firstImage();
      } else {
      content = "file not loaded!";
      xmlData = new XML();
      xmlData.ignoreWhite = true;
      xmlData.onLoad = loadXML;
      xmlData.load("data.xml");
      function thumbnails_fn(k) {
      var bb = xmlData.firstChild.childNodes[k].attributes.label;
      this.thumbnail_mc.createEmptyMovieClip("t"+k, this.thumbnail_mc.getNextHighestDepth());
      this.thumbnail_mc._quality = "BEST";
      thumbnail_mc.createTextField("title_txt"+k, thumbnail_mc.getNextHighestDepth(), 0, -30, 150, 20);
      //thumbnail_mc["title_txt"+k].border = true;
      thumbnail_mc["title_txt"+k]._x = (thumbnail_mc["title_txt"+k]._width+40)*k ;
      thumbnail_mc["title_txt"+k].setNewTextFormat(txt_fmt);
      thumbnail_mc["title_txt"+k].text = bb ;
      tlistener = new Object();
      tlistener.onLoadInit = function(target_mc) {
      target_mc._x = (eval("this.thumbnail_mc.t"+k)._width+40)*k;
      target_mc.pictureValue = k;
      trace(k);
      target_mc.onRelease = function() {
      aa = xmlData.firstChild.childNodes[k].attributes.datas;
      getURL("javascript:launch('"+aa+"')");
      target_mc.onRollOver = function() {
      this._alpha = 100;
      //this._width =;
      target_mc.onRollOut = function() {
      this._alpha = 80;
      image_mcl = new MovieClipLoader();
      image_mcl.addListener(tlistener);
      image_mcl.loadClip(thumbnails[k], "thumbnail_mc.t"+k);
      LOADmc._x=(alignmc.width-LOADmc._width);
      LOADmc._y=(alignmc.height-LOADmc._height);
        • 1. Re: thumbnails problems
          you want every 4th thumbnail on a 2nd line below the first line?
          • 2. Re: thumbnails problems
            melas076 Level 1
            yes, i want every 4th thumbnail on new line below the previous line......
            • 3. Re: thumbnails problems
              so, all thumbnails are on line 1 except every 4th which appear below the previous lowest line?  ie, if you have 12 thumbnails, you'll have 4 lines, correct?
              and, you want every 4 thumbnail to be at the far-left?
              • 4. Re: thumbnails problems
                melas076 Level 1
                so, all thumbnails are on line 1 except every 4th which appear below the previous lowest line?  ie, if you have 12 thumbnails, you'll have 4 lines, correct? yes correct....
                • 5. Re: thumbnails problems
                  if(k%4==3){
                  thumbnail_mc["title_txt"+k]._x=0;  // if you want far-left for every 4th
                  var gapY:Number = thumbnail_mc["title_txt"+k]._height+40;
                  thumbnail_mc["title_txt"+k]._y=gapY*Math.ceil(k/4);
                  var gapY:Number =
                  trace(k);
                  this._alpha = 100;
                  //this._width =;
                  this._alpha = 80;
                  • 6. Re: thumbnails problems
                    melas076 Level 1
                    i put on my code and tried but the image is still on the 1st line.
                    but the text title is on the 2nd line
                    • 7. Re: thumbnails problems
                      use:
                      var tlistener:Object = new Object();
                      var image_mcl:MovieClipLoader = new MovieClipLoader();
                      var mc:MovieClip=this.thumbnail_mc.createEmptyMovieClip("t"+k, this.thumbnail_mc.getNextHighestDepth());
                      mc.kvar=k;
                      var target_mc:MovieClip=mc.createEmptyMovieClip("target",0);
                      image_mcl.loadClip(thumbnails[k], target_mc);
                      target_mc._x = target_mc._width+40)*target_mc.kvar;
                      if(target_mc._parent.kvar%4==3){
                      target_mc._x=0;  // if you want far-left for every 4th
                      var gapY:Number = target_mc._height+40;
                      target_mc._y=gapY*Math.ceil(target_mc._parent.kvar/4);
                      trace(target_mc._parent.kvar);
                      aa = xmlData.firstChild.childNodes[this._parent.kvar].attributes.datas;
                      this._alpha = 100;
                      //this._width =;
                      this._alpha = 80;
                      • 8. Re: thumbnails problems
                        melas076 Level 1
                        now, it is titles are in the 1st line.
                        and only 2 pictures are in the 1st and 2nd line.
                        • 9. Re: thumbnails problems
                          what's the trace output and what's the value of total?
                          • 10. Re: thumbnails problems
                            melas076 Level 1
                            how to do that?
                            • 11. Re: thumbnails problems
                              you have a trace():
                              that should cause output in your output panel.  do you see any output when you test?
                              • 12. Re: thumbnails problems
                                melas076 Level 1
                                yes i see the output and see in below :
                                3
                                2
                                1
                                0
                                what can i do else?
                                • 13. Re: thumbnails problems
                                  and what's the value of total? (use the trace function.)
                                  • 14. Re: thumbnails problems
                                    melas076 Level 1
                                    it gives me only this:
                                    3
                                    2
                                    1
                                    0
                                    • 15. Re: thumbnails problems
                                      melas076 Level 1
                                      can you verifiy if it is correct that i did or not?
                                      but it works well that i see !
                                      stop();
                                      if (loaded) {
                                      links = [];
                                      description = [];
                                      thumbnails = [];
                                      a =[];
                                      thumbnails_fn(i);
                                      initPreloading();
                                      //firstImage();
                                      } else {
                                      if(k%4==3){
                                      var gapY:Number = thumbnail_mc["title_txt"+k]._height+100;
                                      var gapY:Number =
                                      target_mc._alpha = 80;
                                      if(k%4==3){
                                      var gapY:Number = target_mc._height+30;
                                      target_mc._y=gapY*Math.ceil(k/4);
                                      trace(k);
                                      this._alpha = 100;
                                      this._xscale *= 1.2;
                                      this._yscale *= 1.2;
                                      this._quality = "BEST";
                                      this._alpha = 80;
                                      this._width = 150;
                                      this._height = 113;
                                      • 16. Re: thumbnails problems
                                        what's the trace output using:
                                        stop();
                                        if (loaded) {
                                        links = [];
                                        description = [];
                                        thumbnails = [];
                                        a =[];
                                        trace("total "+total);
                                        thumbnails_fn(i);
                                        initPreloading();
                                        //firstImage();
                                        } else {
                                        if(k%4==3){
                                        var gapY:Number =
                                        if(k%4==3){
                                        trace(k);
                                        this._alpha = 100;
                                        this._alpha = 80;
                                        this._width = 150;
                                        this._height = 113;
                                        • 17. Re: thumbnails problems
                                          melas076 Level 1
                                          it gives me this : total 4
                                          • 18. Re: thumbnails problems
                                            ok, so you should see 3 items on the first line and the 4th item below those 3.  is that what you see?
