1 Reply Latest reply on Jan 2, 2012 9:40 PM by $Nith$
    Mass Terminate Process Instances
    Tim Goodman Level 1
      Is it possible to Terminate Process Instances On Mass.  i.e. 100,000+ Process Instances in one go?
      I'm guessing that I'm going to need to break into the java API, unless someone can suggest otherwise:
      http://help.adobe.com/en_US/livecycle/9.0/programLC/help/index.htm?content=001110.html
        • 1. Re: Mass Terminate Process Instances
          $Nith$ Level 4
          There are few ways to do that:
          1. You can use Java API (as you mentioned); can be called within a Java Program
          2. Use WebService API; can be called from within any server side program (e.g. .Net /JSP/Servlet/PHP etc)
          3. You may directly update the status of each process in Database (Highly not-recommended)
          PS: If you want to permanently delete the records from Database, use Process Purge Tool. I hope this will work only on COMPLETED process instances.
          Nith
