1 Reply Latest reply on Dec 15, 2011 1:36 AM by flexercised
    A really simple XML Question
    QuadWord
      i want to use XML to save some configuration for elements in my app.
      in my example i want to add 6 additional configuration sets to one "main" XML. each set can be config1 or config2.
      In this case i added 3x config1 and 3x config2. if i trace my results i do not only get the wrong order of elements but also some "strange" binding behavior.
      Of course this is a simplified example. my configuration sets are more complex (this is why i use seperate xml-objects for each config).
      Can someone tell me how this is supposed to work ?
      thanks,
      quadword
                                       xmlns:s="library://ns.adobe.com/flex/spark" applicationDPI="160" creationComplete="init();">
        <fx:Declarations>
        <fx:XML id="mainConfig" format="e4x">
                <allConfigSets>
                          <viewconfig>Baseconfig</viewconfig>
                </allConfigSets>
        </fx:XML>
        <fx:XML id="configSet1" format="e4x">
                <configSet><viewconfig>Set1</viewconfig></configSet>
        </fx:XML>
        <fx:XML id="configSet2" format="e4x">
                <configSet><viewconfig>Set2</viewconfig></configSet>
        </fx:XML>
        </fx:Declarations>
        <fx:Script>
                          <![CDATA[
                                    private function init(): void {
                                              mainConfig.appendChild(configSet1.viewconfig);
                                              mainConfig.appendChild(configSet2.viewconfig);
                                              // trace1 (see below): trace shows wrong order of elements
                                              trace (mainConfig);
                                              // trace2:(see below): changing data on original configSet seems to bind into mainConfig
                                              configSet1.viewconfig = "-";
                                              trace (mainConfig);
        </fx:Script>
      </s:Application>
      Trace1:
      <allConfigSets>
      </allConfigSets>
      Trace2:
      <allConfigSets>
        <viewconfig>-</viewconfig>
      </allConfigSets>
