1 Reply Latest reply on Dec 14, 2011 10:24 AM by Willam van Weelden
    Robohelp 9: Resizing the search result columns
      We haven't found a way to do this yet, but does anyone know what variable/where I would need to make an edit to change the column spacing for the Topic Title and Search Rank results in a project generated with WebHelp?  The Rank column is given for more width than it needs, and while we can manually resize that column down, each new search resets the width back to the default.  We want more room for the Topic Title and less room for the Rank.
        • 1. Re: Robohelp 9: Resizing the search result columns
          Willam van Weelden Adobe Community Professional & MVP
          You can change this with a small edit to your output files. In your output, go to whfhost.js and go to line 3210. Add the required width there, for example:
          "<TD ID='OdinFtsRank'CLASS='fr_tt' STYLE='cursor:pointer; width:30px;'>"+gsRank+"^</TD>" +
          Just remember this file gets overwritten every time you generate your output. Either make a copy of the file and paste it in your output after generation, or modify your seed file in your RoboHelp install directory, and then RoboHTML\WebHelp5Ext\template_stock.
