1 Reply Latest reply on Dec 14, 2011 1:19 PM by DonMitchinson
    Auto expand Spark Datagrid rowcount with dataprovider
    DonMitchinson
      I'm having problems with a datagrid being used inside a VGroup.
      I've set the datagrid display to show one row + the header with the requestedRowCount = -1
      which says it should auto expand if more rows are added.
      When a filter is applied I reset the requestedRowCount to the number of rows + 1 (for the header).
      tracing indicates that the code is getting executed
      However the datagrid rows never change.
      Is this because I'm not using the properties correctly or because it's inside a VGroup?
      Any suggestions would be greatly appreciated... some extracted code is found below..
      // Filter Rentals by Job
      if (arrRentalsByJob.filterFunction == null) arrRentalsByJob.filterFunction = filterByJob;
      trace('Rentals Done');
      arrRentalsByJob.refresh();
      if (arrRentalsByJob.length == 0) {
         trace('adjusting rentals to min - num rentals = ' + arrRentalsByJob.length.toString());
         // Set the DataGrid row count to the array length, plus one for the header.
         dgRentalSummary.requestedRowCount = 2;
      } else {
         trace('adjusting rentals to handle num rentals = ' + arrRentalsByJob.length.toString());
         dgRentalSummary.requestedRowCount = arrRentalsByJob.length + 1;
      dgRentalSummary.invalidateDisplayList();
      <s:DataGrid id="dgRentalSummary" width="811" height="48" dataProvider="{arrRentalsByJob}" editable="false" requestedRowCount="-1" rowHeight="20">
      <s:columns>
        <s:ArrayList>
          <s:GridColumn dataField="rentalCompany" headerText="Rental Company" width="230"></s:GridColumn>
          <s:GridColumn dataField="rentalEquipment" headerText="Rental Equipment" width="500"></s:GridColumn>
          <s:GridColumn dataField="rentalCost" headerText="Cost" labelFunction="displayHours"></s:GridColumn>
      </s:ArrayList>
      </s:columns>
      </s:DataGrid>
        • 1. Re: Auto expand Spark Datagrid rowcount with dataprovider
          DonMitchinson Level 2
          Found the problem - using tip from a previous post.
          Can't actually set an initial "height"for the DataGrid - and I don't need to set the rowCount when I filter.
          So .... this now works ...
          } else {
          <s:columns>
            <s:ArrayList>
          </s:ArrayList>
          </s:columns>
          </s:DataGrid>
