2 Replies Latest reply on Dec 14, 2011 5:04 PM by areohbee
    xml parsing with LrXml
    meir242
      Hi i hope its the last question for tonight ....
      im trying to parse xml im gettng , i have the flicker example that has some exml paprsing , but it using recurstion .
      i want to understand the basic here .
      say i have this xml :
      <session>
        <id>4</id>
        <message>authentication failure</message>
        <result>error</result>
      </session>
      and i want to get the value of <id> tag , how should i do it with LeXml , yep basic ...
      what i have is :
      // i dont understand this , what does it do ?
      local simpleXmlMetatable = {
          __tostring = function( self ) return self._value end
      local node = LrXml.parseXml( xmlString )
      local session_id = ""
      local type = string.lower( node:type() )
      if type == 'element' then
              local element = setmetatable( {}, simpleXmlMetatable ) < ---- CAN SOMEONE EXPLAIN ME WHAT IT IS ????
              element._name = node:name()
              element._value = node:text()  < -- here im gettnig :  "10 authentication failure error "  , why it gives me all the values ? ?
               local id_node = node:childAtIndex(1)  < -- here i hoping to get the <id> tag but im gettng nil
      end
        • 1. Re: xml parsing with LrXml
          DawMatt Level 3
          You are getting into some pretty advanced topics (metatables) here and it
          is going to be difficult and timeconsuming to answer these questions
          piecemeal.
          I suggest you have a read of some of the Programming in Lua book, which is
          available online. Specifically this section deals with metatables:
          http://www.lua.org/pil/13.html
          Matt
          • 2. Re: xml parsing with LrXml
            areohbee Level 6
            This code works:
            local xmlString = [[
            <session>
              <id>4</id>
            </session>]]
                                local sesnNode = LrXml.parseXml( xmlString )
                                local idNode = sesnNode:childAtIndex( 1 )
                                app:show{ info="ID: ^1", idNode:text() }
            "shows": 'ID: 4'
            As Matt said, I think you really need to read about metatables in the lua manual to understand that other stuff...
            Rob
