2 Replies Latest reply on Dec 19, 2011 2:31 PM by Alberti
    What to do about these pesky drop-downs if generating ePub output?
    Alberti Level 1
      I maintain a large RH9 WebHelp Pro project with several hundred topics and probably thousands of DHTML dropdowns.
      My employers are now asking me about the possibility of "mobilising" the project. I understand that the ePub format does not handle dropdowns.
      What are my options? Is there a scripting solution that would automatically convert all my dropdowns to mini-topics? Any other ideas?
      Mike
        • 1. Re: What to do about these pesky drop-downs if generating ePub output?
          Willam van Weelden Adobe Community Professional & MVP
          ePub 2 does not support scripting. You can create an ePub with dropdowns and some readers may keep working, but don't count on it.
          There is no scripting solution to convert your dropdowns automatically yet. I'm sure it can be done, but that will require some scripting. You also have to determine whether you want to patch the output only or whether you want to patch the source itself.
          Another option is to remove the drop-downs from your output by using CBT, but that's quite a lot of work for hundreds of dropdowns. You may be able to do that with a script.
          Just remember that the ePub script generates the output for you. When you want the ePub script to patch your HTML, you'll need to modify the default ePub script.
          Greet,
          Willam
          • 2. Re: What to do about these pesky drop-downs if generating ePub output?
            Alberti Level 1
            The dilemma is that the content of these dropdowns is essential, so the CBT option -- publishing to ePub without the converted drop-down content -- is not useful. Bummer.
