1 Reply Latest reply on Dec 5, 2012 11:17 AM by roymeo_
    Adobe AIR 2.0 Problems communicating with Native Process
      I am new to actionscript programming and AIR applications. I am trying to communicate with an external .exe, 'ngspice.exe' the ngspice application in windows operating system. I am able to open the application but when I try writing to the standard input stream, I don't see the program responding the data send to the input stream . Also when I run a simulation using the interface provided by the application itself, I am not able to recieve any responses when I try to trace from the standard output stream of the process. But when I exit the program, the event listener is working and traces the output of the code with which the application exited. I want to provide spice with netlist and commands from my AIR app and have the outputs from spice received back on my app. The code that I am using is as follow:
           import flash.desktop.*;
           import flash.events.*;
           import flash.filesystem.*;
           var process:NativeProcess;
                     trace("NativeProcess not supported.");
           function setupAndLaunch():void
                var executablePath:String="C:/Spice/bin/ngspice.exe";
                var nativeProcessStartupInfo:NativeProcessStartupInfo = new NativeProcessStartupInfo();
                var file:File=new File(String(executablePath));
                var args:Vector.<String> = new Vector.<String>();
                //This parameter is to open ngspice in pipe mode
                var parametersString:String="-p";
                     var parameters:Array;
                     parameters = parametersString.split(" ");
                for each(var parameter:String in parameters){
                     nativeProcessStartupInfo.arguments = args;
                     process=new NativeProcess();
                     process.addEventListener(IOErrorEvent.STANDARD_INPUT_IO_ERROR, onIOError);
                     process.addEventListener(ProgressEvent.STANDARD_INPUT_PROGRESS, standardInputProgress);
                //why isn't the following line working??
            function standardInputProgress(evt:ProgressEvent):void
                function onOutputData(event:ProgressEvent):void
                          trace("Got:",process.standardOutput.readUTFBytes(process.standardOutput.bytesAv ailable));
                function onErrorData(event:ProgressEvent):void
                          trace("ERROR -",process.standardError.readUTFBytes(process.standardError.bytesAvailable));
                function onExit(event:NativeProcessExitEvent):void
                          trace("Process exited with ",event.exitCode);
                function onIOError(event:IOErrorEvent):void
      Please help me out.
      Thanks in advance
