8 Replies Latest reply on Dec 17, 2011 1:29 PM by Harbs.
    session engine problem in jsxbin
    கற்பனை (Imagine) Level 3
      Hi All,
      I've created the UI script - window type "palette",  while run the script (.jsx format) from the InDesign Script panel, my palette visible to me.  If i convert the script from .jsx to .jsxbin format, place the binary file in InDesign script panel folder then  run the script (.jsxbin format) the palette visible and immediately hidden.
      I couldn't able to identify where the memory leaks occured ?
      Test case code:
      #target indesign
      #targetengine testsession
      var myWindow = new Window ("palette", "Form");
      var myInputGroup = myWindow.add ("group");
      myInputGroup.add ("statictext", undefined, "Name:");
      var myText = myInputGroup.add ("edittext", undefined, "Hello World!");
      myText.characters = 20;
      myText.active = true;
      var myButtonGroup = myWindow.add ("group");
      myButtonGroup.alignment = "right";
      myWindow.show ();
      Thanks in advance.
      Imagine
