2 Replies Latest reply on Dec 17, 2011 11:49 AM by gkaiseril
    Unbalanced tags
    Lasikboy
      Something to do with body tags on line 187 to 189 i recently removed the old analytics code from body and put new into head. all tags do appear closed. what am i missing please help?
      Also I wanted to remove the white bars between the editable regions
      <!DOCTYPE HTML>
      <html>
      <head>
      <meta charset="UTF-8">
      <!-- TemplateBeginEditable name="doctitle" -->
      <title>Board Certified Los Angeles Cornea and Keratoconus specialist,treats problems of keratoconus with intacs and corneal cross linkage (CXL)</title>
      <!-- TemplateEndEditable -->
      <!-- TemplateBeginEditable name="head" -->
      <style type="text/css">
      body {
                font: 100%/1.4 Verdana, Arial, Helvetica, sans-serif;
                background: #000000;
                margin: 0;
                padding: 0;
                color: #000;
                background-color: #000000;
      ul, ol, dl {
                padding: 0;
                margin: 0;
      h1, h2, h3, h4, h5, h6, p {
                margin-top: 0;
                padding-right: 15px;
                padding-left: 15px;
                font-family: Verdana, Arial, Helvetica, sans-serif;
      a img {
                border: none;
      a:link {
                color: #FFFF00;
                text-decoration: underline;
      a:visited {
                color: #6E6C64;
      a:hover, a:active, a:focus {
                text-decoration: none;
      .container {
                width: 960px;
                margin: 0 auto;
      header {
                background: #ADB96E;
      .sidebar1 {
                float: left;
                width: 180px;
                padding-bottom: 10px;
      .content {
                padding: 10px 0;
                width: 600px;
                float: left;
      aside {
                float: left;
                width: 190px;
                background: #EADCAE;
                padding: 10px 0;
      .content ul, .content ol {
                padding: 0 15px 15px 40px;
      nav ul {
                list-style: none;
                border-top: 1px solid #666;
                margin-bottom: 15px;
      nav ul li {
                border-bottom: 1px solid #666;
      nav ul a, nav ul a:visited {
                padding: 5px 5px 5px 15px;
                display: block;
                width: 160px;
                background: #C6D580;
      nav ul a:hover, nav ul a:active, nav ul a:focus {
                color: #FFF;
      footer {
                padding: 10px 0;
                background: #CCC49F;
                position: relative;
                clear: both;
                background-color: #000033;
      .fltrt {
                float: right;
                margin-left: 8px;
      .fltlft {
                float: left;
                margin-right: 8px;
      .clearfloat {
                clear:both;
                height:0;
                font-size: 1px;
                line-height: 0px;
      header, section, footer, aside, nav, article, figure {
                display: block;
                color: #FFFFFF;
                font-size: large;
                background-color: #000;
      body,td,th {
                color: #F00;
      .container .container h1 em {
                color: #06C;
                background-color: #FFF;
                text-height: max-size;
      </style>
      <!--[if lt IE 9]>
      <script src="http://html5shiv.googlecode.com/svn/trunk/html5.js"></script>
      <![endif]-->
      <script src="SpryAssets/SpryMenuBar.js" type="text/javascript"></script>
      function MM_swapImgRestore() { //v3.0
        var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
      function MM_preloadImages() { //v3.0
        var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
          var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
          if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
      function MM_findObj(n, d) { //v4.01
        var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
          d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
        if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
        for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
        if(!x && d.getElementById) x=d.getElementById(n); return x;
      function MM_swapImage() { //v3.0
        var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
         if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
      </script>
      <link href="SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css">
      <!-- TemplateParam name="OptionalRegion1" type="boolean" value="true" -->
        var _gaq = _gaq || [];
        _gaq.push(['_setAccount', 'UA-27137166-1']);
        _gaq.push(['_trackPageview']);
        (function() {
          var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
          ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
          var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
      </script>
      </head>
      <body onLoad="MM_preloadImages('310 482 1240')">
      <div class="container">
        <header><a href="Newsweek.asp"><img src="droppedImage.png" alt="newsweek features cornea specialist who treats keratoconus with intacs and cross linkage" width="196" height="80"></a><a href="contactus.asp"><img src="message-me_white.png" width="202" height="66"></a>Available Saturdays<a href="#" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Image15','','310 482 1240',1)"><img src="phone_icon.png" alt="call keratoconus specialist avialble for saturday appointments in beverly hills" name="Image15" width="80" height="80" border="0">310 482 1240 </a>Beverly Hills
          <form name="form1" method="post" action="">
          </form>
        </header>
        <div class="sidebar1">
          <aside>
            <iframe src="http://www.facebook.com/plugins/like.php?href=khannavision"
              scrolling="no" frameborder="0"
              style="border:none; width:200px; height:80px"></iframe>
            <p><a href="Selfevaluationforkeratoconuseyedisease.asp"><img src="Treeoflight.jpg" width="168" height="140" alt="OnlineKeratoconusconsult" longdesc="http://www.intacs.com/OnlineKeratoconusconsult"></a></p>
            <p><a href="ScheduleyourkeratoconusExam.asp"><img src="colorbridgekeratoconus.jpg" width="166" height="140" alt="Keratoconusconsultlosangeles"></a></p>
            <p><a href="Californiakeratoconusexpertmagazines.asp"><img src="Sep07-(Page-01).jpg" alt="Beverly hills times features los angeles lasik eye surgeon " width="139" height="162"></a></p>
            <p><span style="font-size:75%"><a href="Awardslosangeleskeratoconus.asp"><img src="RC2011_Winner_EC_4C.png" alt="2011 winner of best lasik eye surgeon in ventura county based on survey of people undergoing laser vision correction and treatment of keratoconus" name="one" width="150" height="150"></a></span></p>
            <p><a href="Templates/wordpress"><img src="blog.jpg" width="155" height="97" alt="Blogkeratoconus" longdesc="http://newintacs.com"></a><a href="Templates/wordpress"></a></p>
            <img src="http://www.youtube-nocookie.com/gen_204?feature=creators_cornier-http%3A//s.ytimg.com/yt/i mg/creators_corner/Watch_me_on_YouTube/200x65_watchmeon_blue.png" style="display: none"/>
            <p><a href="Templates/keratoconusdiscussionforum"><img src="Discussforum.jpg" width="157" height="94" alt="keratoconusdiscussionforum" longdesc="http://newintacs.com/discussionkeratoconus.com"></a></p>
            <p> </p>
          </aside>
        <!-- end .sidebar1 --></div>
        <article class="container">
          <h1 class="container"><em> Khanna Vision Institute Keratoconus</em></h1>
          <ul id="MenuBar1" class="MenuBarHorizontal">
            <li><a href="howtotreat keratoconus.asp" title="Home Page on Keratoconus Disease" class="MenuBarItemSubmenu"><strong>Keratoconus</strong></a>
              <ul>
                <li><a href="Historyofkeratoconusdisease.asp">History</a></li>
                <li><a href="casusesofcornealdiseasekeratoconus.asp" title="Cause and aietiology of keratoconus">Cause</a></li>
                <li><a href="kerstoconusdegenerationPathology.asp">Pathology</a></li>
              </ul>
            </li>
            <li><a href="symptomsofkeratoconuscorneadegeneration.asp" title="Symptoms of Keratoconus" class="MenuBarItemSubmenu"><strong>Symptoms</strong></a>
              <ul>
                <li><a href="symptomsofkeratoconuscorneadegeneration.asp" title="Vision Problems in Keratoconus">Vision Problems</a></li>
              </ul>
            </li>
            <li><a class="MenuBarItemSubmenu" href="signskeratoconusectasiacornea.asp"><strong>Signs</strong></a>
              <ul>
                <li><a href="slitlampsignsofkeratoconus.asp">On Slit Lamp</a>          </li>
                <li><a href="corneatopographydiagnosiskeratoconus.asp">Color Topography</a></li>
                <li><a href="#">Pachymetry</a></li>
              </ul>
            </li>
            <li><a href="#" class="MenuBarItemSubmenu"><strong>Treatment</strong></a>
              <ul>
                <li><a href="Intacsforkeratoconuseyedisease.asp">Intacs</a></li>
                <li><a href="Corneacrosslinkagewithriboflavinlosangeles.asp">Cross-Linking</a></li>
                <li><a href="glassesandcontactlensesfortreatmentofkeratoconus.asp" title="Contact Lenses for Keratoconus">Contact Lenses</a></li>
                <li><a href="glassesandcontactlensesfortreatmentofkeratoconus.asp">Glasses</a></li>
                <li><a href="Corneatransplantforkeratoconus.asp">Cornea Transplant</a></li>
              </ul>
            </li>
            <li><a href="#" class="MenuBarItemSubmenu"><strong>Before &amp; After</strong></a>
              <ul>
                <li><a href="Testimonialsforkeratoconusintacs.asp">Testimonials</a></li>
                <li><a href="BeforeandAfterintacs.asp">Topography</a></li>
              </ul>
            </li>
          </ul>
          <section><form method="get" action="http://www.google.com/search">
      <tr>
        <td>
          <p>   </p>
          <p> </p>
          <p>
            <input type="text"   name="q" size="25"
      maxlength="255" value="" />
            <input type="submit" value="Eye Search" />
            <a href="http://www.youtube.com/khannalasik"><img src="http://s.ytimg.com/yt/img/creators_corner/Watch_me_on_YouTube/200x65_watchmeon_blue.png" alt="Subscribe to me on YouTube to learn about  intacs and cross linking for keratoconuseye surgery and hear keratoconustestimonials and reviews"/></a>      <a href="Financingforkeratoconuscarecredit.asp"><img src="Care Credit.gif.png" alt="care creit can help finance laser eye vision correction" width="215" height="75"></a></p></td></tr>
        <td align="center" style="font-size:75%">
      <input type="checkbox"  name="sitesearch"
      value="newintacs.com" checked />
        The Keratoconus Expert<br />
        <tr><div id="google_translate_element"></div><script>
      function googleTranslateElementInit() {
        new google.translate.TranslateElement({
          pageLanguage: 'en',
          gaTrack: true,
          gaId: 'UA-27137166',
          layout: google.translate.TranslateElement.InlineLayout.SIMPLE
        }, 'google_translate_element');
      </script><script src="//translate.google.com/translate_a/element.js?cb=googleTranslateElementInit"></scrip t>
      </td></tr></table>
          </form>
            <h2><!-- TemplateBeginEditable name="EditRegion4" -->EditRegion4<!-- TemplateEndEditable --></h2>
            <form name="form2" method="post" action="">
              <p>
                <label for="text box1"></label>
              <!-- TemplateBeginEditable name="EditRegion5" -->EditRegion5<br>
              <br>
              <br>
              <!-- TemplateEndEditable --></p>
            </form>
            <!-- TemplateBeginEditable name="EditRegion3" -->
            <p>EditRegion3</p>
            <p> </p>
            <form name="form3" method="post" action="">
              <p> </p>
              <!-- TemplateBeginEditable name="EditRegion6" -->
                <p>EditRegion6</p>
              <p>
                <label for="text 3"></label>
              </p>
              <p>  </p>
            </form>
            <form name="form4" method="post" action="">
              <p> </p>
              <!-- TemplateBeginEditable name="EditRegion7" -->EditRegion7<!-- TemplateEndEditable -->
              <p>
                <label for="text 4"></label>
              </p>
              <p>  </p>
            </form>
            <p> </p>
            <!-- TemplateEndEditable --></section>
          <section>
          </section>
          <section>
            <h2> </h2>
      </section>
          <section>
            <h2> </h2>
      </section>
        <!-- end .content --></article>
      <aside>
          <h4><!-- TemplateBeginIf cond="OptionalRegion1" --><!-- TemplateBeginEditable name="EditRegion10" --><!-- TemplateEndEditable --><!-- TemplateEndIf --></h4>
          <p> </p>
      </aside>
        <!-- TemplateBeginEditable name="EditRegion8" --><img src="DSC00655.JPG" alt="famous people and hollywood actors like Joe Pesichi meet beverly hills keratoconus expert" width="265" height="178"><!-- TemplateEndEditable --><!-- TemplateBeginEditable name="EditRegion9" --><img name="" src="DORRIS.JPG" width="248" height="177" alt="Dorris eddy famous hollywood celebrity with los angeles keratoconus expert"><!-- TemplateEndEditable --><img src="ABO.jpg" alt="american board of opthalmology certifies eye doctors who may do lasik and treat keratoconus with c3r and new intacs" name="one" width="167" height="123"><img src="BHtimes.png" alt="beverly hills lasik brett michaels, kobe bryant" name="" width="138" height="152"><img src="Daily News_BEST09.jpg" alt="Readers choice for best laser and keratoconus vision correction surgeon in los angeles" width="150" height="88"><img src="YHC MAGAZINE- JUNE ISSUE COVER.jpg" alt="your health connection westlake village lasik; allieviate problems of keratoconus" width="130" height="160">
        <footer>
          <p>Beverly Hills </p>
      </footer>
      <!-- end .container --></div>
      var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", {imgDown:"SpryAssets/SpryMenuBarDownHover.gif", imgRight:"SpryAssets/SpryMenuBarRightHover.gif"});
      </body>
      </html>
