6 Replies Latest reply on Feb 5, 2012 3:41 AM by Liphou
    Set Equal Spacing for selected frames Vertical & Horizontal
    csm_phil Level 4
      Hi Scripters All,
      I have troubled in this part? How set the Vertical&Horizontal Space for the selected graphic frames. Any one share your valuable input.
      I understand there is only one way calcuation methods. But i struggled that area Please help its very urgent.
      This is my simple JS and output snapshot in the below.
      app.activeDocument.distribute(app.selection, DistributeOptions.HORIZONTAL_SPACE, undefined, true, 12);
      app.activeDocument.distribute(app.selection, DistributeOptions.VERTICAL_SPACE, undefined, true, 16);
      thx
      csm_phil
        • 1. Re: Set Equal Spacing for selected frames Vertical & Horizontal
          Harbs. Level 6
          You have resizing going on besides distribution...
          If you only need distribution and you want to use ID's built-in functionality, you'll need to do it the same way you would in the UI (i.e. group the different sections first)...
          • 2. Re: Set Equal Spacing for selected frames Vertical & Horizontal
            csm_phil Level 4
            Hi Harbs,
            Thanks for you sharing Idea, Anyway can you please give the simple distribution and ID's Built-in function java script post i will understand.
            And you said group the object after run the script its working fine. I already tried that methods. But the user select all the frames and run the script it will automatically resize this what i need. Can you please help us i am very much strugled in this case.
            I am selecting the all frames how to i know the first two frames in the horizontal and next one is the above horizontal and third one is above middle frame.
            Please help us give the simple code i will learn from you lot of things.
            Harbs:  Any chance to apply the fix space horizontal/vertical using the resize() or reframe() or resolve(),  Can you please look into this problem and help me.
            I am trying the another methods its also not working:
            var myRectangle = app.activeDocument.pages.item(0).rectangles.everyItem();
            var myTransformationMatrix =app.transformationMatrices.add({counterclockwiseRotationAngle:0, horizontalTranslation:12, verticalTranslation:12});
            myRectangle.transform(CoordinateSpaces.INNER_COORDINATES, AnchorPoint.CENTER_ANCHOR, myTransformationMatrix);
            myTransformationMatrix = myTransformationMatrix.translateMatrix();
            I am waiting for your support.
            thx
            csm_phil
            • 3. Re: Set Equal Spacing for selected frames Vertical & Horizontal
              csm_phil Level 4
              Hi Scripters,
              Any one helps out my requirement its very urgent i very struggled with get the final out put.
              thx
              csm_phil
              • 4. Re: Set Equal Spacing for selected frames Vertical & Horizontal
                கற்பனை (Imagine) Level 3
                Hi csm,
                to identifying the object position using the geometricBounds of x and y co-ordinates,  you've to do the calculation for getting the left, right, and middle objects separately.  May be its a complicated task too...
                • 5. Re: Set Equal Spacing for selected frames Vertical & Horizontal
                  csm_phil Level 4
                  Hi Scripters All,
                  I have tried this get the final output still i am struggled with getting the final out with resize or moving methods used the result is none.
                  Please help us any one look this and solve i am tried lot of possibilities, Can you any one check this issue and help me.
                  Harbs: I dont know the resize methods using the coordinates i m write the below js code, Please check and advice to me.
                  var myXVal = 5;
                  var myYVal = 5;
                  var win = new Window('dialog', 'TEST');
                  win.preferredSize = [200,150];
                  win.alignChildren = 'left';
                  win.margins = [18,18,18,18];
                  win.spacing = 18;
                  with(win){
                       win.Grp = add('group');
                       win.Grp.alignment = 'left';
                       win.Grp.orientation = 'row';
                       win.Grp.alignChildren = 'top';
                       with(win.Grp){
                            win.Grp.sText = add('statictext', undefined, 'H Space: ');
                            win.Grp.eText = add('edittext', undefined, myXVal);
                            win.Grp.eText.preferredSize = [145,20];
                       win.Grp1 = add('group');
                       win.Grp1.alignment = 'left';
                       win.Grp1.orientation = 'row';
                       with(win.Grp1){
                            win.Grp1.sText = add('statictext', undefined, 'V Space: ');
                            win.Grp1.eText = add('edittext',undefined, myYVal);
                            win.Grp1.eText.preferredSize = [145,20];
                       var myClickButton = win.add('group');
                       myClickButton.alignment = 'left';
                       myClickButton.orientation = 'row';
                       with(myClickButton){
                            var myCancel = myClickButton.add('button', undefined, 'Cancel');
                            myCancel.preferredSize = [100,20];
                            var myOkButton = myClickButton.add('button', undefined, 'OK', {name:'ok'});
                            myOkButton.preferredSize = [100,20];
                  var myFlg = 1;
                  myCancel.onClick = function () {
                       myFlg = 0;
                       win.close();
                  win.center();
                  win.show();
                  var myHSpaceValue = win.Grp.eText.text;
                  var myVSpaceValue = win.Grp1.eText.text;
                  // GUI input value is 5 mm
                  myHSpaceValue = 5;
                  myVSpaceValue = 5;
                  var mySel = myDoc.selection;
                  if(mySel.length>1){
                       if(myHSpaceValue!='' && myVSpaceValue!=''){
                       for (a=0; a<app.selection.length; a++){
                         oldbounds = app.selection[a].geometricBounds;
                         newbounds = [oldbounds[0]+5, oldbounds[1], oldbounds[2], oldbounds[3]-5];
                         app.selection[a].geometricBounds = newbounds;
                                 // the below line methods is also i tried but not working
                            //myDoc.distribute(mySel, DistributeOptions.HORIZONTAL_SPACE, undefined, true, parseInt(myHSpaceValue));
                            //myDoc.distribute(mySel, DistributeOptions.VERTICAL_SPACE, undefined, true, parseInt(myVSpaceValue));
                  else{
                       exit(0);
                  thx
                  csm_phil
                  • 6. Re: Set Equal Spacing for selected frames Vertical & Horizontal
                    csm_phil Level 4
                    Hi All,
                    It is possible to reduce/increase the space within the inner coordinates spacing to the selected object. this is possible to get this requirement.
                    Please help and advice this requirement.
                    • 7. Re: Set Equal Spacing for selected frames Vertical & Horizontal
                      Liphou Level 1
                      newbounds = [oldbounds[0]+ myXVal, oldbounds[1], oldbounds[2], oldbounds[3]- myYVal];
