2 Replies Latest reply on Dec 18, 2011 7:11 AM by Jeff Bellune
    using graphics as buttons
    buddhanature37
           Hi
      I am using Flash Pro and I want to create a desktop application that uses the graphics on stage to launch web pages when the user clicks on each individual graphic. I am very new to Flash Pro could anyone point me in the right direction? Thanks!
      Heather
        • 1. Re: using graphics as buttons
          buddhanature37 Level 1
          Ok I think I figured it out. I converted the graphics to a movie symbol rather than a button and it seems to do what I want. If anyone has any other suggestions I would still appreciate them... Heather
          • 2. Re: using graphics as buttons
            Jeff Bellune Level 6
            Moderator's note: user AtonMusic posted potentially useful info over in the Premiere Pro forum, so I'm attaching it to this thread:
            AtonMusic said:
            "You wanna assign evenListeners to ALL your graphics... The eventlistener will check to see when the user hoovers or presses THAT particular graphic.
            For the evenListener you will create a Function... Something like this:
            a var is a varialble... You will create ALL THIS in Actionscript 3... So you will need to learn that a bit.. Lynda.com is a good source !
            You will need to a piece of graphic that has an instance name of "GRAPHICBUTTON"
            This is a function that will go to adobe.com
            var ADDRESS:String = "https://www.adobe.com";
            var getADDRESS:URLRequest = new URLRequest(ADDRESS);
            getADDRESS.method = URLRequestMethod.POST;
            GRAPHICBUTTON.addEventListener(MouseEvent.MOUSE_UP, goToADDRESS);
            function goToADDRESS(e:MouseEvent):void
                        navigateToURL(getADDRESS);
