2 Replies Latest reply on Dec 18, 2011 4:15 PM by GX_Tidus
    External preloader question
    GX_Tidus
      Hello there i got a question and i would be gratefull if you could help me out.
      I've got an external preloader from this tutorial http://doogog.com/actionscript-3-external-preloader.html
      and i would like to merge it with an preloader from oxylusflash (its a premium preloader)
      heres the code from the preloader
      [code]
      // import eaze tween
      import aze.motion.EazeTween;
      import aze.motion.easing.Elastic;
      // change this to make it play or stop the parent of finish
      // after the loading is done the parent will play or stop to the next frame
      var onFinishPlayParent:Boolean = false;
      // set the position of the preloader
      var xPos:int = (stage.stageWidth - 48)/2;
      var yPos:int = (stage.stageHeight - 48)/2;
      // stop the loader's parent
      var parentMc:MovieClip = MovieClip(this.parent);
      parentMc.stop();
      // stop the loader
      stop();
      this.x = xPos;
      this.y = yPos;
      var balls:Array = [ball1, ball2, ball3, ball4, ball5, ball6, ball7, ball8];
      var done:Array = [false, false, false, false, false, false, false, false];
      for (var i:int =0; i< balls.length; i++)
          balls[i].visible = false;
          balls[i].scaleX = balls[i].scaleY = 0.15;
      // start a 100ms timer
      var updateTimer:Timer = new Timer(100);
      updateTimer.addEventListener(TimerEvent.TIMER, update);
      updateTimer.start();
      // updates the preloader
      function update(e:Event)
          var percentage:int;
          percentage = Math.floor(stage.loaderInfo.bytesLoaded*100/stage.loaderInfo.bytesTotal);
          display.text = String(percentage);
          if(percentage >12 && done[0] == false)
              balls[0].visible = true;
              done[0] = true;
              new EazeTween(balls[0]).to(0.5,{scaleX:1, scaleY:1}).easing(Elastic.easeOut);
          if(percentage >24 && done[1] == false)
              balls[1].visible = true;
              done[1] = true;
              new EazeTween(balls[1]).to(0.5,{scaleX:1, scaleY:1}).easing(Elastic.easeOut);
          if(percentage >36 && done[2] == false)
              balls[2].visible = true;
              done[2] = true;
              new EazeTween(balls[2]).to(0.5,{scaleX:1, scaleY:1}).easing(Elastic.easeOut);
          if(percentage >48 && done[3] == false)
              balls[3].visible = true;
              done[3] = true;
              new EazeTween(balls[3]).to(0.5,{scaleX:1, scaleY:1}).easing(Elastic.easeOut);
          if(percentage >60 && done[4] == false)
              balls[4].visible = true;
              done[4] = true;
              new EazeTween(balls[4]).to(0.5,{scaleX:1, scaleY:1}).easing(Elastic.easeOut);
          if(percentage >72 && done[5] == false)
              balls[5].visible = true;
              done[5] = true;
              new EazeTween(balls[5]).to(0.5,{scaleX:1, scaleY:1}).easing(Elastic.easeOut);
          if(percentage >84 && done[6] == false)
              balls[6].visible = true;
              done[6] = true;
              new EazeTween(balls[6]).to(0.5,{scaleX:1, scaleY:1}).easing(Elastic.easeOut);
          if(percentage >96 && done[7] == false)
              balls[7].visible = true;
              done[7] = true;
              new EazeTween(balls[7]).to(0.5,{scaleX:1, scaleY:1}).easing(Elastic.easeOut);
          if(percentage >= 100)
              updateTimer.removeEventListener(TimerEvent.TIMER, update);
              updateTimer.stop();
              updateTimer = null;
              // play or stop on the next frame for the loade parent
              if(!onFinishPlayParent)
                  parentMc.gotoAndStop(parentMc.currentFrame+1);
              else
                  parentMc.gotoAndPlay(parentMc.currentFrame+1);
              new EazeTween(this).to(1,{alpha:0})
      [/code]
