2 Replies Latest reply on Dec 19, 2011 12:26 PM by Bogoljubow
    Adjust FX Render Quality
    Bogoljubow
      In Avid you have the choice between different render options for your fx.
      Is there something similar in Premiere Pro?
      szenario: you want to expert render the fx in your sequence for final output. You are in any dv format project, but of course want to render in 1:1 or DNxHD to avoid further compression by rendering in dv quality.
      What do you do in Premiere Pro?
      Thanks for your input!
        • 1. Re: Adjust FX Render Quality
          Jim_Simon Level 8
          You'll need to use a Desktop/Cistom sequence if you want to change the render codec used.  The presets all have fixed codecs, and none of them are lossless.
          (On a side note, DNxHD is not lossless either.)
          • 2. Re: Adjust FX Render Quality
            Bogoljubow Level 1
            It has not to be "lossless". But ideally it should not be rendered in dv.
            What's about a workaround, maybe transfering the final program in a new project which allows better render quality?
            Jim Simon wrote:
            You'll need to use a Desktop/Cistom sequence (...)
            How do I create such a sequence - and what is it? (No search results)
            thx
