1 Reply Latest reply on Dec 19, 2011 8:23 AM by sadascq
    webservice:how to set "login" & "password" like this... in flex
    sadascq
      Hello, I'm Thai guy ,if any sentence or some grammar  is not correct or mistake ,I'm sorry for that.
      In php, I test my webservice like this:
      ____________________________________________________________________________
      [client-side]
      $client = new SoapClient("plus.wsdl",array(
          "trace" => 1,
          "exceptions" => 0,
          "login"=>"51011111",
           "password"=>"1234"
      $ar= $client->plus(5, 2);
      [server-side]
      function plus($num1,$num2) {
      $h=array();
      $user=trim($_SERVER['PHP_AUTH_USER']);
      $pwd=trim($_SERVER['PHP_AUTH_PW']);
      $h[0]=$user;                  // check sever-side can get user from client
      $h[1]=$pwd;                    // check sever-side can get password from client
      $h[2]=$num1+$num2;
      return $h;
      $server = new SoapServer("plus.wsdl");
      $server->addFunction("plus");
      $server->handle();
      This is basic test for next step of my authentication so It's work.
      but now I wanna use in Flex but I don't know how to set
           "password"=>"1234"
      in the other way I know I should soapheader for authen but I don't know how to use it because
      it's error #1009 and I don't know how to get value(user,pwd) in server-side if use soapheader.
      Thank you very much.
        • 1. Re: webservice:how to set "login" & "password" like this... in flex
          sadascq Level 1
          no one help me- -'
          but now I can figure it out.
          solution:
          private function authAndSend():void
          var encoder:Base64Encoder = new Base64Encoder();
                  encoder
          .encode("someusername:somepassword");
                  ws
          .httpheaders = {Authorization:"Basic " + encoder.toString()};
                  ws
          .send();
          adove code(flex) is equivalent to php code (below)
              "trace" => 1,
              "exceptions" => 0,
              "login"=>"51011111",  //someusername
               "password"=>"1234" //somepassword
