Dear All!
I have a sequence with this settings : 1080p 25fps, and same project settings with avchd 1080p.
I put a rolling title to timeline inside in Premiere with same settings.But when I preview a title when the lines moving from bottom to top every line
is moving a lit a bit, more precisely they are shaking. This would be frame settings problem or what?
If you see superficially maybe this invisible, but if I see closer this is annoying.
Please help!
Thanks.
Did you use the Rolling Title Preset?
After you placed that onto your Timeline, did you Render that portion of the Timeline, by setting the WAB (Work Area Bar), and hitting Enter/Return?
If you are using the Rolling Title Preset, and have Rendered, and are still not getting smooth results, I would instead Keyframe the Fixed Effect>Motion>Position, on a static Title. You will still want to Render that Title.
