4 Replies Latest reply on Apr 30, 2013 9:26 AM by Joe.Charles
    Read the content of a file (via socket)
    Corwin86
      I need to read the content of a file (.txt, or better, .jpg) and to write it again in another file.
      I have this code (in Javascript):
          conn = new Socket;
          conn.encoding = "BINARY";
          if (conn.open ("127.0.0.1:8888")) {
          conn.timeout=30;
          conn.writeln("GET variousFiles/file.jpg HTTP/1.1");
          reply = conn.read(999999);
          conn.close();
          var file = new File("C:/APPS/New_File.txt");
          file.encoding = 'BINARY';
          var open_file = file.open("w+");
          file.write(reply);
          } else { alert("Errore: " + conn2.error); }
      However my new file is always empty, because I can not read the content of the first file.
      My variable "reply" is always empty.
      Thanks and best regards.
        • 1. Re: Read the content of a file (via socket)
          Bob Stucky Adobe Employee
          First thing I would do is scrap the ES effort for ActionScript. ActionScript has all that stuff built in and ready for use.
          http://www.adobe.com/devnet/creativesuite/cs-extension-builder.html
          http://www.adobe.com/devnet/creativesuite.html
          If that's not possible for you, check your URL ( 127.0.0.1:8888/variousFiles/file.jpg ) in a browser to see what you get back.
          You can also leverage other folks work on HTTP in ExtendScript. This library might help (I've not used it):  http://extendables.org/
          I have a foggy memory of a bug from a number of years ago.
          I belive the case was that an ExtendScript socket set up as a server would not respond to requests from localhost. It's also possible that extendscript's socket object, as a client, might not be able to connect to localhost. I just don't recall the specifics.
          Has anyone out there successfully connected to localhost using an ES Socket?
          Regards
          Bob
          • 2. Re: Read the content of a file (via socket)
            Muppet Mark Level 5
            Have you tried writing reply to the console rather than to file to see if it's empty…? Also I didn't check but shouldn't…
            just be…
            var open_file = file.open('w'); // without the plus
            • 3. Re: Read the content of a file (via socket)
              Corwin86 Level 1
              Hi Bob and Muppet,
              this below is my new code:
                   conn2 = new Socket;
                  if (conn2.open ("127.0.0.1:8888", "BINARY")) {
                  conn2.timeout=6000;
                  conn2.write("GET /Temp1/file.jpg HTTP/1.0\n\n");
                  reply2 = conn2.read(999999);
                  conn2.close();
                  } else { alert("Error: " + conn2.error); }
              This seems to work perfectly, I managed to read the jpg file.
              • 4. Re: Read the content of a file (via socket)
                Joe.Charles
                There is a particular case with sugested function, if content is generated on the fly by the server -php, cgi, etc.-
                In this case, http server doesn´t knows total size of response data, so response shows a chunked transfer-encoding header and data is parted in chunks, each one starting with it´s size, and following the data.
                HTTP/1.1 200 OK
                Date: Tue, 30 Apr 2013 12:43:41 GMT
                Server: Apache/1.3.31 (Win32) mod_fastcgi/2.4.1
                Connection: close
                Transfer-Encoding: chunked
                Content-Type: image/jpeg
                f49
                ÿØÿà  JFIF
                I´m using this function to decode parted response, with initial chunkedString with firs chunk size; in this case, f49:
                PartsSeparator="\r\n";
                function getPartedBody(partedBodyString) {
                    var separatorPosition=partedBodyString.indexOf(PartsSeparator);
                    var chunkSize=new Number("0x"+partedBodyString.substring(0,separatorPosition));
                    separatorPosition+=PartsSeparator.length;
                    var bodyString=new String("BINARY");
                    bodyString="";
                    if (chunkSize>0)
                        bodyString=partedBodyString.substring(separatorPosition,separatorPosition+chunkSize)+
                            getChunkedResponse(partedBodyString.substring(separatorPosition+chunkSize+PartsSeparator. length));
                    return bodyString;
                Hope this helps
                regards
