34 Replies Latest reply on Dec 23, 2011 8:21 PM by kglad
    Cant hide or get rid of pre loader bar. Please help
    Joey_Feliney
      [b]Ok why wont this work?
      Trying to do a
      Navigation bar button , to preloader to abour me page with a photo component.
      Not on the pre loader page the bar works, only it wont disappear.[/b]
      [pre]s[color=blue]iteLoader.loadMovie("AboutMe5.swf",4);
      Frame_movie._alpha = 100;
      loadingBar._alpha = 100;
      loadingBar._xscale = 1;
      loadingBar.onEnterFrame = function()
          kBytesLoaded = this._parent.siteLoader.getBytesLoaded() / 1024;
          kBytesTotal = this._parent.siteLoader.getBytesTotal() / 1024;
          percentage = Math.round(kBytesLoaded / kBytesTotal * 100);
          this._xscale = percentage;
      if ("percentage" ==99) {
          loadingBar._alpha=0;
          Frame_movie._alpha=0;
              delete this.onEnterFrame;
      [/color]
      }[/pre]
      [b]The nav bar has the following script[/b]
      [pre][color=blue] Button_AboutMe.onRelease = function(){
      unloadMovie(4);
      loadMovie("AboutMe_Loader.swf",4);
      }[/color][/pre]
      [b]The loaded film used to just have  as the script [/b]
      [color=blue]stop();[/color]
      [b]now I added this script to the final AboutMe5.swf file to try and hide the bar but does not work, also tried using different layers and the unloadMovie(4); script. It did not work.
      [/b]
      [pre][color=blue] unloadMovie(4);
      loadingBar._alpha=25;
      Frame_movie._alpha=25;
      SiteLoader._alpha = 10
      //    loadingBar._alpha=1;
      //    this._alpha=1;
          //Frame_movie._alpha=1;[/color][/pre]
      [b]Now Frame_move is a mov (and tried button) and  the laoding bar is a mov file. I can make these fade by adusting the alpah but this only works accross the film. I cannot trigger it with the line.
      [/b]
      [color=blue][pre]if ("percentage" ==99) {[/pre][/color]
      Ive tried with and without single and double quotes. and plane.
      tried replacing percentage with
      this._xscale
      loading bar
      Nothing works.
      it appears to be the if script thats the problem not triggering the fad or gettig red of the pre loader altogether.
      Please help
        • 1. Re: Cant hide or get rid of pre loader bar. Please help
          use:
          if (percentage >=99) {
          • 2. Re: Cant hide or get rid of pre loader bar. Please help
            Joey_Feliney Level 1
            Already tried that it says syntax error on that line
            • 3. Re: Cant hide or get rid of pre loader bar. Please help
              copy and paste the code you're using.
              • 4. Re: Cant hide or get rid of pre loader bar. Please help
                siteLoader.loadMovie("AboutMe5.swf",4);
                if (percentage >= 99) {
                Also tried
                if (percentage = 99) {
                if (percentage == 99) {
                if ('percentage' == 99) {
                if ("percentage"== 99) {
                if (this._xscale = 99) {
                • 5. Re: Cant hide or get rid of pre loader bar. Please help
                  the site is www.chriscreativity.com
                  Once I get the about me pre loader it will be copied to others.
                  Also any advice on website please?
                  • 6. Re: Cant hide or get rid of pre loader bar. Please help
                    1.  make sure you're publishing for as2.
                    2. copy and paste the complete error message when using the code i suggested.  highlight the line of text mentioned in the error message.
                    • 7. Re: Cant hide or get rid of pre loader bar. Please help
                      Scene=scene 1, layer=Actions, frame=1, line 11  Syntax error
                      line 11 was Function loadingBar.onEnterFrame():
                      I then altered the scrtipt to this which got rid of the error but now no pre loader bar at all:-
                      if the if line is
                      You get no bar
                      if I write the line as
                      You get stuck with the bar perminantly
                      Now how do i get the bar pre loading and loose it when loaded please.
                      ***************************************current script****************
                      //Function loadingBar.onEnterFrame():
                      //delete this.onEnterFrame;
                          delete Frame_movie;
                      • 8. Re: Cant hide or get rid of pre loader bar. Please help
                        i don't see
                        in your original post so i don't see how the correction i suggested would cause that error.  ie, don't make changes to suggestions and then report errors as if the suggestion caused the error.
                        what's the trace output (copy and paste), using:
                        siteLoader.loadMovie("AboutMe5.swf");
                        trace(this+" "+this._xscale);
                            delete Frame_movie;
                        • 9. Re: Cant hide or get rid of pre loader bar. Please help
                          Tried it. it did not work First:
                              delete Frame_movie;
                          If left as it was the bar does not move and does not disappear
                          this produced the output
                          _level0.loadingBar 100
                          But no loading bar at all. Likewise: (the rest is left constant just changing the bottom section)
                          //    loadingBar._alpha=0;
                          //    Frame_movie._alpha=0;
                             delete Frame_movie;
                             delete loadingBar;
                          and this produces a adding out output ie
                          _level0.loadingBar2 but no bar
                          //   delete Frame_movie;
                          //   delete loadingBar;
                          the following just produced 3 lines of _level0.loadingBar 100,and no bar
                          unloadMovie(loadingBar);
                          unloadMovie(Frame_movie);
                          • 10. Re: Cant hide or get rid of pre loader bar. Please help
                            if I change the If statement to
                            if (percentage == 100) {
                               delete Frame_movie;
                               delete loadingBar;
                            //unloadMovie(loadingBar);
                            //unloadMovie(Frame_movie);
                            this has a constant bar and you get 3 lines of
                            It has a constant on bar that does not dissappear
                            loadingBar.onEnterFrame = function(){
                            The above appears to work with the bar moving then diappearing when i use the test movie simulate download. But only at slow speed ie 56k
                            If I just do just testmovie or set the speed to dsl  the bar does not diasspear when its supposed to. Why different effects ie bar or no bar dependant on speed?
                            when uploaded online the same file does not show the loading bar just the frame..
                            Im confused whey is same script actign differently
                            • 11. Re: Cant hide or get rid of pre loader bar. Please help
                              you're making this more difficult than it should be.  again,
                                  delete Frame_movie;
                              • 12. Re: Cant hide or get rid of pre loader bar. Please help
                                _l
                                • 13. Re: Cant hide or get rid of pre loader bar. Please help
                                  Now the above was a regualr download speed, ie just set to test movie. The below was 56k speed. Note when slowed you have an incremental section. Now this mirrors when the bar works . It tends to only workd with slow speeds on simulate download.
                                  In neither case with a straight copy and paste of your script could a pre loading bar could be seen.
                                  _level0.loadingBar 2
                                  _level0.loadingBar 3
                                  _level0.loadingBar 4
                                  _level0.loadingBar 5
                                  _level0.loadingBar 6
                                  _level0.loadingBar 7
                                  _level0.loadingBar 8
                                  _level0.loadingBar 9
                                  _level0.loadingBar 11
                                  _level0.loadingBar 12
                                  _level0.loadingBar 13
                                  _level0.loadingBar 14
                                  _level0.loadingBar 15
                                  _level0.loadingBar 16
                                  _level0.loadingBar 17
                                  _level0.loadingBar 18
                                  _level0.loadingBar 19
                                  _level0.loadingBar 20
                                  _level0.loadingBar 21
                                  _level0.loadingBar 22
                                  _level0.loadingBar 23
                                  _level0.loadingBar 24
                                  _level0.loadingBar 25
                                  _level0.loadingBar 26
                                  _level0.loadingBar 28
                                  _level0.loadingBar 29
                                  _level0.loadingBar 31
                                  _level0.loadingBar 32
                                  _level0.loadingBar 33
                                  _level0.loadingBar 35
                                  _level0.loadingBar 36
                                  _level0.loadingBar 37
                                  _level0.loadingBar 38
                                  _level0.loadingBar 40
                                  _level0.loadingBar 42
                                  _level0.loadingBar 44
                                  _level0.loadingBar 46
                                  _level0.loadingBar 48
                                  _level0.loadingBar 49
                                  _level0.loadingBar 51
                                  _level0.loadingBar 53
                                  _level0.loadingBar 56
                                  _level0.loadingBar 57
                                  _level0.loadingBar 59
                                  _level0.loadingBar 60
                                  _level0.loadingBar 61
                                  _level0.loadingBar 65
                                  _level0.loadingBar 67
                                  _level0.loadingBar 69
                                  _level0.loadingBar 71
                                  _level0.loadingBar 76
                                  _level0.loadingBar 78
                                  _level0.loadingBar 84
                                  _level0.loadingBar 88
                                  _level0.loadingBar 90
                                  _level0.loadingBar 92
                                  _level0.loadingBar 93
                                  _level0.loadingBar 94
                                  _level0.loadingBar 95
                                  _level0.loadingBar 97
                                  _level0.loadingBar 99
                                  • 14. Re: Cant hide or get rid of pre loader bar. Please help
                                    is the frame that contains that code looping?
                                    • 15. Re: Cant hide or get rid of pre loader bar. Please help
                                      Not that i can see
                                      There are 2 frames.
                                      Frame one
                                      frame 2
                                      stop();
                                      So should not loop.
                                      As said whats strange is if you click test move you are stuck with the bar.
                                      if you simulate download as a slow speed it seems to work but with an output like above.
                                      Surely it should just be slower/
                                      Also of it goes straight to 100 it would miss the 99 bar hider
                                      But if you set it to 100 you dont get a bar at all
                                      and >= does not work at all
                                      Also flash keeps crashing sayign a script is goign to make it run slowly do you want to abort the script? whatever you say it crashes and quits
                                      • 16. Re: Cant hide or get rid of pre loader bar. Please help
                                        copy and paste the trace() output from:
                                        stop();
                                        if(kBytesLoaded>100){
                                        loadingBar.swapDepths(this._parent.getNextHighestDepth());
                                        loadingBar.removeMovieClip();
                                        Frame_movie.swapDepths(this._parent.getNextHighestDepth());
                                        Frame_movie.removeMovieClip();
                                        this._parent.nextFrame();
                                        • 17. Re: Cant hide or get rid of pre loader bar. Please help
                                          Tried it. No output at all. And I see the frame before nd after buut no progress bar
                                          • 18. Re: Cant hide or get rid of pre loader bar. Please help
                                            I turned the greater than to less than sign on line
                                            &got output
                                            _level0.loadingBar 0
                                            _level0.loadingBar 27
                                            _level0.loadingBar 39
                                            _level0.loadingBar 41
                                            _level0.loadingBar 58
                                            _level0.loadingBar 63
                                            _level0.loadingBar 66
                                            _level0.loadingBar 70
                                            _level0.loadingBar 77
                                            _level0.loadingBar 83
                                            _level0.loadingBar 87
                                            _level0.loadingBar 91
                                            _level0.loadingBar 98
                                            • 19. Re: Cant hide or get rid of pre loader bar. Please help
                                              just copy and paste.  don't change anything:
                                              stop();
                                              if(kBytesLoaded>1){
                                              • 20. Re: Cant hide or get rid of pre loader bar. Please help
                                                The loading bar works  but the frame does not dissapear which is the frame mov
                                                • 21. Re: Cant hide or get rid of pre loader bar. Please help
                                                  copy and paste:
                                                  stop();
                                                  if(kBytesLoaded>1){
                                                  trace(Frame_movie+" "+this._parent.getNextHighestDepth());
                                                  • 22. Re: Cant hide or get rid of pre loader bar. Please help
                                                    Output
                                                    undefined undefined
                                                    And you get stuck with the white frame around the loading bar
                                                    see www.chriscreativity.com
                                                    • 23. Re: Cant hide or get rid of pre loader bar. Please help
                                                      what flash player version are you publishing for?
                                                      and copy and paste:
                                                      stop();
                                                      trace(Frame_movie);
                                                      if(kBytesLoaded>1){
                                                      • 24. Re: Cant hide or get rid of pre loader bar. Please help
                                                        The result is the same as before. If I just test movie I see a white frame for the bar (the Frame_Movie) under the loaded content
                                                        Output
                                                        _level0.Frame_button
                                                        If I simulate download I see the loading bar move but then it disappears leaving the frame. under the loaded content
                                                        Ive checked to see if it was left over shape frame under the frame button symbol (ie the frame dissapearign but leaving a drawing) but that was already cleared, i have aslo done a version where the frame mov is replaced by a frame button here
                                                        OUTPUT
                                                        There was no different to how they worked
                                                        stop();
                                                        trace(Frame_movie);
                                                        //Frame_movie._alpha = 100;
                                                        Frame_button._alpha = 100;
                                                        if(kBytesLoaded>1){
                                                        //Frame_movie.swapDepths(this._parent.getNextHighestDepth());
                                                        Frame_button.swapDepths(this._parent.getNextHighestDepth());
                                                        //Frame_movie.removeMovieClip();
                                                        Frame_button.removeMovieClip()
                                                        Your script
                                                        stop();
                                                        trace(Frame_movie);
                                                        if(kBytesLoaded>1){
                                                        Produced the output
                                                        undefined
                                                        the flash publisher is set to flash 10 action script 2
                                                        • 25. Re: Cant hide or get rid of pre loader bar. Please help
                                                          that's illogical:
                                                          //your code
                                                          stop();
                                                          trace(Frame_movie);  // output:  _level0.Frame_button, makes no sense
                                                          //my code
                                                          stop();
                                                          trace(Frame_movie); // output:  undefined, also makes no sense.
                                                          so, you don't have a movieclip named Frame_movie.
                                                          • 26. Re: Cant hide or get rid of pre loader bar. Please help
                                                            The below is something that seems to semi work.
                                                              [CODE]stop();
                                                              //trace(Frame_button);
                                                              percentage = 1;
        Frame_button._alpha=0;
                                                              //unloadMovie(Frame_button);
                                                              }[/CODE]
                                                              If
                                                               the percentage line is
                                                               Then in the test movie control test shows the bar under the loaded page.
                                                               output
                                                               [CODE]_level0.loadingBar 100
                                                               _level0.loadingBar 30
                                                               _level0.loadingBar 99[/CODE]
                                                               Id you go to simulate download and set slower speed you see it work and disappear.
                                                               but if you set it to
                                                               or
                                                               Then you get stuck with the bar and frame whihc stays and the output is
                                                            • 27. Re: Cant hide or get rid of pre loader bar. Please help
                                                              I was trying to see if it would work with the frame being a button not a movie symbol
                                                              So tried making a frame button to try and fade it thats all. It made no difference.
                                                              The above seems to work the best but It appears to work in a simulated download then it loads the bar then removes it but if just test movie you get stuck with the bar.
                                                              Any idea why this works differently?
                                                              also why does the loading bar not start at 0? why 100 then 0 then go up?
                                                              I can change it back to a movie
                                                              • 28. Re: Cant hide or get rid of pre loader bar. Please help
        is there a way I can sent the fla and swf files? and photos
        • 29. Re: Cant hide or get rid of pre loader bar. Please help
        Ive made a temp yahoo account to act as a cloud drive to transfer the flash files with photos so you can see whats happening. you can download the files here.
        Dont use your email use the accounts own email below so it only sends to itself for security
        adobeforumfiletransfer@yahoo.co.uk
        Pass
        PreLoader
        • 30. Re: Cant hide or get rid of pre loader bar. Please help
        use:
        stop();
        loadingBar.onEnterFrame = function() {
        kBytesLoaded = this._parent.siteLoader.getBytesLoaded()/1024;
        kBytesTotal = this._parent.siteLoader.getBytesTotal()/1024;
        if (kBytesLoaded>1) {
        percentage = Math.round(kBytesLoaded/kBytesTotal*100);
        if (percentage>=99) {
        p.s.  please mark helpful/correct responses.
        • 31. Re: Cant hide or get rid of pre loader bar. Please help
        Im looking at the output either
        100
        100
        100
        or when simulating download
        100
        100
        100
        then
        1
        2
        3
        4
        etc
        And wonderign how do we get it to start at 0 not 100
        As then can set the percentage to change at 100
        • 32. Re: Cant hide or get rid of pre loader bar. Please help
        siteLoader has to be an empty movieclip.
        then you can use:
        if (kBytesLoaded>0) {
        • 33. Re: Cant hide or get rid of pre loader bar. Please help
        THANK YOU VERY VERY MUCH
        Finally got it working.
        What on earth were we doing wrong all this time?
        Could you explain that so know what Im doing for next time rather than cutting and pasting your script please. Think others would benefir from that.
        the working script is
        stop();
        siteLoader.loadMovie("Aboutme5.swf",4);
        Left it on the yahoo email drop box mentioned above
        • 34. Re: Cant hide or get rid of pre loader bar. Please help
        you had numerous problems which i was correcting one or two at a time.  but then you would regress and fail to continue using correct code so you would re-introduce a previously solved problem.
        the last problem was caused by removing loadingBar before all the code was executed.
