2 Replies Latest reply on Dec 19, 2011 12:57 PM by thesitedoc
    "Saved Optimized As" images appear pixelated - PS7.0
    thesitedoc
      I am using Image Ready for PS7.0 to create a mouseover effect.  Mouseover the smaller images and the picture in the middle changes to the large view of that picture.  The starting pictures have no/little pixelation.  However, after I finish slicing my graphic so I can make the mouseovers and then "save optimzed as" I upload the images and the html file and the images appear to have some increase pixelation.
      I am accustomed to some increased pixelation when I make an animated graphic because it saves as one big heavy graphic.  Is there a way to not have so much pixlation when I use Image Ready to create mouseovers/rollovers.
        • 1. Re: "Saved Optimized As" images appear pixelated - PS7.0
          Curt Y Level 7
          If you are seeing increased pixelation you must be changing the image size when you "save as".
          See what the size of the first image is and the pixelated ones (image/image size).
          • 2. Re: "Saved Optimized As" images appear pixelated - PS7.0
            thesitedoc Level 1
            Thanks for the response.  I'm not sure if I understand.  I have a 900 x 425 white background on to which I drag about 6, 600 x 420 size pictures into the center.
            Then I make smaller pictures of each picture  that I place on the right hand side to be used for the rollover effect.
            I slice out along the edges of the big pictures so as not to add an excess white space around them and then I slice out the smaller pcitures as well so they became the rollover button.
            The actual size of each pciture really does not become any bigger.
