3 Replies Latest reply on Dec 30, 2011 3:51 AM by VenkatAtluru1440
    Issues with Trial Version 4.6
    VenkatAtluru1440
      Hi....
      When i am using the flash builder 4.6 trial version i am getting the following problem
      I am trying to exeicute TourdeFlex example related to SQL Database Usage i am getting this error in Flash Builder .Please help
      DescriptionResourcePathLocationType
      Unable to locate specified base class 'spark.components.WindowedApplication' for component class 'views.DtabaseExampleHomeView'.DtabaseExampleHomeView.mxml/DtabaseExample/src/viewsUnknownFlex Problem
        • 1. Re: Issues with Trial Version 4.6
          VenkatAtluru1440 Level 1
          Does the trial version provide full functionality or it only provides limited features?
          • 2. Re: Issues with Trial Version 4.6
            DonMitchinson Level 2
            Trial version is Premium - will revert back to Standard if Standard license is used after Trial is finished.
            If that's an actual copy/paste of the error message it looks like the example has a typo.
            'views.DtabaseExampleHomeView'. probably shoul dbe 'views.DatabaseExampleHomeView'.
            maybe check to see if the src  path /DtabaseExample/src/views exists?
            • 3. Re: Issues with Trial Version 4.6
              1)unable to populate database values at  speak  List in flash Builder4.6  The fallowing code is used
              <fx:Script>
                <![CDATA[
                 import mx.collections.ArrayCollection;
                 private function getIteamCategory():void {
                 avar sqlConnection:SQLConnection = new SQLConnection();
                var resultSet:SQLResult = null ;
                var dataList:ArrayCollection = new ArrayCollection();
                sqlConnection.open(File.applicationStorageDirectory.resolvePath("IDatabase.db"));
                var stmt:SQLStatement = new SQLStatement();
                stmt.sqlConnection = sqlConnection;
                 stmt.text="SELECT  item_category FROM Menu_Table where item_id  between 1 and 99";
                stmt.execute();
                data_list.dataProvider=new ArrayCollection(stmt.getResult().data);
                 sqlConnection.close();
                return dataList;
                      protected function datalist _creationCompleteHandler (event:FlexEvent):void  //executed when the List completes loading
                          getIteamCategory ();
                <b/fx:Script>
              <s:List id="datalist" x="10" y="10" left="0" right="0" top="0" bottom="0" width="1004"
                      height="500"
                      creationComplete="datalist _creationCompleteHandler(event)" enabled="true">
                  <s:itemRenderer>
                      <fx:Component>
                          <s:MobileItemRenderer label = "{data. item_category }"/>  // The Application is a mobile app
                      </fx:Component>
                  </s:itemRenderer>
              </s:List>
              Please suggest, I also included mx.swc file in the build path. Also seeing following several error message, pasting two of them
              1120: Access of undefined property ContainerBorderSkin.
              1172: Definition mx.skins.spark:ButtonSkin could not be found.          NewIndianCurryHous
              Thanks in advance.
